My taco eats headlight bulbs..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sheepshead45, Mar 3, 2017.
  1. Mar 3, 2017 at 12:58 PM
    Sheepshead45
    Sheepshead45 [OP] Well-Known Member
    NC
    PreRunner SR5
    Seriously, I burn a bulb out every 3-4 months. I've replaced so many on my 2010 taco it's ridiculous. I get replacements at the various auto box stores; I've tried the $20 ones, then the dudes talked me into the $40 ones saying they would last longer. No dice, the $40 don't last a day longer.
    It's both sides too, so if it's a wiring/electrical thing it effects both.
    What gives? Anyone else??
  2. Mar 3, 2017 at 1:11 PM
    mashir
    mashir Well-Known Member
    Colorado
    2014 DCSB TRD Off-Road
    OME BP-51 full kit, SPC UCAs, FJ TRD Trail Team wheels in black, 255/85/16 Cooper Discoverer ST Maxx, All-Pro aluminum front bumper and IFS skid, Slee Off-Road silders and rear tire carrier bumper, Rigid and BD lighting, Baja Rack roof rack, Bruteforce Fab bed cage, CVT RTT
    I'm no expert, but I've read here that some Japanese makes, us included, run a higher-than-expected voltage to the headlights, causing some premium bulbs from non-OEM sources to burn out quickly. This was mentioned in threads about Sylvania premium bulbs. OEM replacements from a dealership might be a fix to try...
    SOSC and outlawtacoma like this.
  3. Mar 3, 2017 at 1:12 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    weird. ive been running the same headlights since 2011 and never had one burn out...
    uwu and Nickel like this.
  4. Mar 3, 2017 at 1:20 PM
    Sheepshead45
    NC
    PreRunner SR5
    I'll give that a shot, thanks.
  5. Mar 3, 2017 at 1:25 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    My 2013 still has original bulbs.
  6. Mar 3, 2017 at 1:26 PM
    jpneely
    Charleston, SC
    there may be a way to use an electrical tester to see if your system is putting out more juice than a normal system does. that would at least get you started on the path to a solution.
    tomwil likes this.
  7. Mar 3, 2017 at 1:28 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Are you changing both at the same time or just the one that burned out? You might try changing them both at the same time.
  8. Mar 3, 2017 at 1:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Are you careful to not touch the glass when installing? Maybe wear gloves.
    Do you replace both headlights at once? (As you are supposed to)
    Have you tried name brand 'long life' bulbs?
    Do you start your truck with the headlights on? (Not a good practice for bulb life)
    Do you always drive with your headlights on?
    PackCon, uwu, Nickel and 2 others like this.
  9. Mar 3, 2017 at 1:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    First check running voltage at the sockets. Are you using OE wattage replacements?
  10. Mar 3, 2017 at 1:45 PM
    Limbowhale
    Limbowhale Member
    PNW
    2016 Silver TRD OR DCSB V6 Auto 4X4
    Method wheels Bed mat Husky mats
    I had a similar problem with my 2002. I was always burning out taillights and especially headlights. I took it in to Toyota several times and they tested it and told me nothing was wrong. It got so bad that I decided to dump the truck and bought a 2016. But, just before I sold it I took it to a guy who was supposedly good with electrical and he fixed the problem. It turned out that I had a short in one of the rear taillight housings. He replaced both sides and the problem was solved. My neighbor bought the truck from me and its been over a year since the sale. No headlights or taillights have burned out. You might want to find someone good with electrical systems to check it out for you. I'd stay away from Toyota service though. The last time they charged me over 250.00 so their expert could check it out. I asked if I could speak with him before the service and after. I didn't get to talk to him at all. I just got a note on my seat that everything checked out
  11. Mar 3, 2017 at 4:55 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, do not touch the bulb glass with your bare hands.
  12. Mar 3, 2017 at 6:19 PM
    Fishbear11
    Fishbear11 Well-Known Member
    Do you have a small crack in your headlight? I had a subaru that would burn through bulbs on one side. Couldnt figure it out until I noticed some moisture in there after a really bad rain storm I was driving through. Got a new headlight and the problem went away.
    Blockhead likes this.
  13. Mar 3, 2017 at 6:36 PM
    Pigpen
    Dan
    Northwest Montana
    Touching the bulb with bare hands was my first thought too
  14. Mar 3, 2017 at 6:58 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    stock 2013 bulbs with 50k miles on the clock here. OP is doing something wrong.
    Also.... i start my truck with headlights on (and my main street motorcycle) and never have an issue.
  15. Mar 6, 2017 at 8:59 AM
    Sheepshead45
    NC
    PreRunner SR5
    A catch-all reply:
    I should note that my original bulbs lasted reasonably long, 2 years or so if I remember correctly. I do drive/start with my headlights on all the time. I'm sure that doesn't help, but I commute along a highway with countless entrances & people pull out and wreck nearly every day. I'm willing to burn a few for safety. Don't flame, this is what I do and will continue to do.
    I have been replacing with Sylvania replacements, using part numbers matching a '10 taco. Many bulbs ago I was instructed never to touch the bulb itself, so I'm OK there. I also always clean up the rubber cover and put some electric grease on the plug to keep water out. I've been buying the cheapest bulbs available ($20 each or so) until last Dec or so, when I talked to the autozone dude about this. He recommended the higher $$ versions ($40), said they should last longer. At that time I replaced them both. One lasted until a month ago, and I replaced with another high $$ one. Then the other crapped out last week.
    So I bought 2 replacements from the Toyota dealer this weekend, and put them both in. FYI these are like $35 each. We'll see; if they burn out quickly I'll report back.
  16. Mar 6, 2017 at 9:01 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Same story with my 2007
  17. Mar 6, 2017 at 9:01 AM
    Sheepshead45
    NC
    PreRunner SR5
    A final add, the bulbs from Toyota are noticeably dimmer than the high dollar sylvanias. Oh well...
  18. Mar 6, 2017 at 12:11 PM
    ryanbitt
    ryanbitt Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    This same exact thing has been happening to me for the last year! I've bought 3 or 4 2-packs of the sylvania silverstars over the past year. The first time I replaced them, they lasted 1-2 years but I've had this same issue with my 07 this past year. The only thing that looks bad is the factory bulb connector, it looks like it needs to be replaced so I got some off Amazon recently but haven't had time to replace them.
  19. Mar 6, 2017 at 12:54 PM
    jpneely
    Charleston, SC
    I, too start mine with the headlights on pretty regularly and run them all day, so I don't think that's attributing to the problem. as a refresher, my headlights had 5 years, and 95,000 miles on them.
  20. Mar 6, 2017 at 1:07 PM
    Sheepshead45
    NC
    PreRunner SR5
    I was thinking maybe it's the salt air here in Wilmington NC, but you just blew that theory!
