My taco eats headlight bulbs..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sheepshead45, Mar 3, 2017.
  1. Mar 6, 2017 at 1:08 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    haha yep, just down the road from you! that does blow though, I wish you the best!
  2. Mar 6, 2017 at 5:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Ouch. The factory bulbs are just Osram long life bulbs, you can buy these online or at an autoparts store for a fraction of that price. Long life bulbs are dimmer than most but designed to last significantly longer.
    Try turning your headlights off when you turn off your truck, so that you are not getting the fluctuating voltage to the bulbs when cycling the starter. Then turn them on once the truck is running.
    Drainbung likes this.
  3. May 1, 2017 at 6:42 AM
    ryanbitt
    ryanbitt Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    I've been doing this ever since with no problems or need for replacement yet... but it hasn't really been that long. But I am also thinking of doing the ultimate headlight upgrade at some point this year so that will be interesting to see the results and if I have any more issues with bulbs blowing prematurely. TBD...
  4. May 1, 2017 at 8:11 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Mine chuggs gas :bananadance:
    bluezzy likes this.
  5. May 4, 2017 at 3:10 PM
    jmoreau
    jmoreau Well-Known Member
    Josh
    Baton Rouge, LA
    '11 MGM DC TRD Sport 4x4
    Yes! Ever since the stupid burn-in on the DRL's, I always drive with my headlights on. Mine will go out every few months. I've had much smarter mechanics change them out recently bc I thought it was something I was doing wrong. Just last week, I had my driver's side changed out, and no lie, 2 days later, the passenger side went out. I was hoping to get on here and have the answer in some magic bulbs that never burn out, lol. Let me know if you find some that really last awhile!
  6. May 22, 2017 at 8:26 AM
    jmoreau
    Josh
    Baton Rouge, LA
    What type of aftermarket headlights does everyone recommend?
  7. May 22, 2017 at 8:39 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Run a new ground, after checking that the voltage is correct.
  8. May 22, 2017 at 9:24 AM
    rjlem
    rjlem Well-Known Member
    Rick
    Franksville, Wisconsin
    2011 Reg Cab 4WD 2.7 A/T Bought used
    Int. Wipers, OEM Cruise, Fiamm Horns, Access Cover, Bed Mat, WeatherTech Floor Mats,
  9. May 22, 2017 at 9:34 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    My 2010 Prius would eat headlights like a fat man eats hotdogs!!! I carried spares in the glovebox.
  10. May 22, 2017 at 9:44 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    A few basic things to check if standard halogen headlight bulbs are burning out prematurely (Silverstar and other similar "high performance" bulbs have notoriously short life anyway, a characteristic of them)
    Battery terminals - be sure they are clean and tight, with no corrosion.
    Body ground connections - same as above
    Battery condition - have it load tested.
    Charging voltage - it should be 14.5 volts max even with engine RPM increased to 2000 rpm or more.
    ryanbitt likes this.
  11. May 22, 2017 at 12:38 PM
    jmoreau
    Josh
    Baton Rouge, LA
    Like a Tundra drinks gas? :rofl:
  12. May 22, 2017 at 1:27 PM
    justdoit
    Colorado Springs
    The Tundra gets better MPG's than me o_O
  13. May 22, 2017 at 2:54 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Did not read the whole thread .... so just my 2 cents. Can you get a hold of a 0 scope?? Perhaps your Diode bridge and or any filtering caps are bad. IT will give a real choppy 12v wave instead of a decent DC. Hook it up and check for the charge wave for Idle and under higher RPM with/without load (turn on lights, AC Compressor Clutch, etc. Spikes and voltage drift can raise hell on the high end lights.
    Isn't there a little Johnny joke about his Dad eating a Light bulb?
  14. Jun 17, 2017 at 11:31 AM
    GC1965
    GC1965 New Member
    2014 Red Tacoma
    I've got a 2014 Prerunner and the first bulbs I replaced was after owning it for about two years. After replacing it with a Sylvania brand, the bulb went bad after only a month or so--seriously. I took the bulb back to Wal-Mart and they replaced it. A couple of months later, the other side went bad. This has occurred on several occasions and I have replaced both bulbs at one time and have always used gloves to prevent me from touching it. Today, I have to go out and get another bulb, because my front left went out again. Surely, this has to be an electrical short of some kind. I can't imagine every replacement bulb I've installed are defective.
    dziner likes this.
  15. Jun 17, 2017 at 6:49 PM
    #35
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Nom nom nom
    Fitz235 likes this.
  16. Jun 18, 2017 at 6:57 AM
    #36
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it were an electrical short it would blow the fuse....
    Get some OEM Bulbs and install them and call it a day.
  17. Jun 27, 2017 at 9:07 AM
    #37
    jmoreau
    Josh
    Baton Rouge, LA
    Someone asked if there were cracks in my headlights, and there are. I just noticed moisture on the inside the other day, but it gets so hot in South Louisiana that it evaporates quickly. I'm looking at replacing the whole headlight on both sides and see if that fixes it. Mine is a 2011 so they're getting old and discolored anyway.
  18. Jun 27, 2017 at 9:16 AM
    #38
    98tacoma27
    Ben
    Not Beech Creek
    My 05 Tundra is like that too. Bulbs last 6 months to a year. I am also one to leave the lights on though. I recently bought some LED's from a member that I am going to try out.
    dziner likes this.
  19. Jun 27, 2017 at 10:13 AM
    #39
    Canufixit
    New England
    Ok here is a thought. Hot humid Air gets into the headlight area behind the lens. Temperature drops and the humidity condenses on the inside lens AND the bulb. If the bulb get energized/hot when it still has moisture in it's surface - it boils off and cracks the bub due to uneven surface temp.
  20. Jun 27, 2017 at 10:22 AM
    #40
    98tacoma27
    Ben
    Not Beech Creek
    Might be some validity to this because I don't ever recall having to change a bulb in the winter (Central PA). It's usually in the spring/summer.
    dziner likes this.
