My Taco shaking really bad after being lifted
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dannypham1994, Jun 28, 2019.
  1. Jun 30, 2019 at 5:42 AM
    #61
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Considering the knowledge of trucks and lifts of the OP, assuming based of his posts, the best advice is to take it back to the shop.
    Dont get me wrong, it's great TW is giving advice, but more troubleshooting info is probably confusing the guy even more.
  2. Jun 30, 2019 at 5:42 AM
    #62
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I can't imagine cutting the frame of such a new truck, seems like a project for an old beater.
    Hopefully the shop explained specifically, nearly permanent frame modifications were part of the transformation, of what probably was a perfectly good truck.
    Bigger is not always better. Sometimes less is more. Etc
  3. Jun 30, 2019 at 6:15 AM
    #63
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    I read through all these posts and wont comment as there has been enough ideas, both good and bad shared. But I will add this maybe it will help your piece of mind. If it comes back from the shop and still has vibe issues (typically 45-65 is pretty much wheel balance), put your stock wheels and tires back on and road test it, if the vibration goes away you can eliminate wheel balance as an issue and deal with the suspension mods.
    monkeyface and smw62891 like this.
  4. Jun 30, 2019 at 6:24 AM
    #64
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Stock wheels wont fit on a drop bracket lift alot of times.
  5. Jun 30, 2019 at 6:47 AM
    #65
    rpkole
    rpkole Well-Known Member
    Fort Worth, TX
    2014 MGM 4x4 DCSB
    Which part of Texas are you from? reason I ask is if they dont make it right I might can point you to someone who can.
  6. Jun 30, 2019 at 6:50 AM
    #66
    CVOTRDSPORT
    How is that? The hubs or rear drums weren't changed were they? Im not familiar with drop kits, but usually wheel/hub patterns never change.
  7. Jun 30, 2019 at 6:55 AM
    #67
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    The spindles are sometimes changed.
  8. Jun 30, 2019 at 6:56 AM
    #68
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    should have left it stock
  9. Jun 30, 2019 at 6:59 AM
    #69
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    The stock backspacing will not work unless you run spacers. The tires would rub the new spindles that come with the DB lift
  10. Jun 30, 2019 at 7:02 AM
    #70
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Makes sense
  11. Jun 30, 2019 at 8:12 AM
    #71
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Crappy theory eh? Ah well . . . . just trying to figure out why a Gen1 Tundra was smooth, Gen2 Tacoma had driveline vibes. They have a lot of similarities, the glaring difference was steel bed vs composite bed. When the 3g Taco came out Sweers said the driveline vibes were gone, problem was "manufacturing tolerances" with the 2g Tacoma.
    Stocklocker[QUOTED] likes this.
  12. Jun 30, 2019 at 8:18 AM
    #72
    monkeyface
    Colorado
    Watch the install vid. A chunk of the front crossmember gets cut out so the front driveshaft can be lowered, therefore not stressing the drivetrain. That's all the cutting that is done.
    https://www.youtube.com/watch?v=dqQQ-lWoPBA
  13. Jun 30, 2019 at 8:25 AM
    #73
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    1st Gen Tundras are awesome rigs. Not much to compare them to. Small truck with a nice smooth V8. I think they were a superior design to the present Tundra.
    A good friend of mine just totalled his 1st Gen V8 Tundra, in an accident that was not his fault, and dude was literally in tears.
  14. Jun 30, 2019 at 8:49 AM
    #74
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    That cross member didn’t grow there organically. At one time it wasn’t there, then it was welded in (at the factory) then it was cut out. To go back, weld it back in. Simple really. People modify chassis all the time. So yes, you can go back.
    monkeyface and Dr. Emmett Brown like this.
  15. Jun 30, 2019 at 10:41 AM
    #75
    BillsSR5
    bill
    2014 SR5
    singletrack_ftw likes this.
  16. Jun 30, 2019 at 12:01 PM
    #76
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I love the looks of a lifted Tacoma, but after reading mass quantities of threads about vibrations, clunks, bangs, rattles, shakes, and alignment issues...I'll be rolling stock, and just admire other peoples lifted trucks.
    I'm wondering how many people have installed a lift kit and never had any issues? I guess the only people that post threads are the ones with problems.
    Inferno! likes this.
  17. Jun 30, 2019 at 1:14 PM
    #77
    monkeyface
    Colorado
    When the 3G Tacoma was rumored to be a fresh design my first thought was just make it like a Gen1 Tundra and you're golden.
  18. Jun 30, 2019 at 1:55 PM
    #78
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
    People who don’t lift their trucks because other people have had bad experiences .. make me laugh. :rofl:
    That’s like saying ... I won’t have sex because
    Other people have contracted HIV.
    Just.
    Do.
    It.
    Right.
    And never go cheap.
    In both situations.
    :spending:
    Jaggerbub and Inferno! like this.
  19. Jun 30, 2019 at 3:52 PM
    #79
    HoboInNV
    HoboInNV Well-Known Member
    Seattle, WA
    '17 Super White TRDOR DCSB 4x4 w/prem, tech + JBL
    Bilsetin 6112/5160 + Icon 1.5" AAL, 265/75R16 KO2s, 16x8 Method NVs
    This. I had mine lifted by Rogue Off-Road in Vegas and it hasn't caused me any issues. Getting it done by reputable people is a good first step.
    Dannypham1994[OP] likes this.
  20. Jun 30, 2019 at 4:12 PM
    #80
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Saddest thing I've seen
