My taco stinks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Riddler79, Jan 10, 2018.
  1. Jan 10, 2018 at 4:17 PM
    Riddler79
    Riddler79 [OP] Member
    My 08 taco starts but runs real rough. The other day it would shut off and the gauges would go all wonky then it would work again. Thought it was ground cause my battery terminals were green. Cleaned them up and the next morning went to start it and it runs real rough almost like it is out of time or coils arent firing properly. Anyone have this issue or know something about it
  2. Jan 10, 2018 at 4:20 PM
    Kotah
    Kotah Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    Check your battery voltage, i had a battery that showed good but was bad, truck run real shitty when the right voltage wasnt get put out, it took a couple of days before it showed bad, especially if it is slow turning over
    Riddler79[OP] likes this.
  3. Jan 10, 2018 at 4:23 PM
    Riddler79
  4. Jan 10, 2018 at 4:25 PM
    Riddler79
    You know... We load tested the battery the other night and it was showin a constant drain when we loaded it up. And it is turning over slowly. I gotta try a new battery anyway so hopefully thats the case. Thanx i appreciate the response
  5. Jan 10, 2018 at 4:27 PM
    Riddler79
    Thanx ill try that. Appreciate the response
  6. Jan 10, 2018 at 4:28 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    If you were female that would be best thread title ever.
  7. Jan 10, 2018 at 4:28 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    what about the smell tho?
    WSW3, Shwaa, PackCon and 1 other person like this.
  8. Jan 10, 2018 at 8:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When you disconnected the battery all of the ECU Settings were lost and the truck has to be driven a bit to relearn.
  9. Jan 10, 2018 at 8:25 PM
    Pigpen
    Dan
    Northwest Montana
    Ooooooooo, that smell. Can't you smell that smell?
