My Tacoma An I Need Ur Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma_TRD01, Oct 6, 2008.
  1. Oct 6, 2008 at 2:43 PM
    Tacoma_TRD01
    Tacoma_TRD01 [OP] New Member
    Maine
    01 Tacoma SR5
    3 inch body lift
    I have a 2001 Toyota Tacoma, an the other day, I was about to down shift to make a turn, I pushed in the clutch, an it wouldn't come out of gear (5th gear) So, I keep on going down the road, trying to pull it out of gear, an it finally comes out, so I try to put it into another gear an it won't go in, but it's acting like its in netural, so I try the gas, an it goes like its still in gear, well cause it is, so my big question is, what could be wrong? I been told alot of things, from Bad Pressure Plate, Jammed Forks, to Bad Syncros (spelling), I'm pretty use that the gear oil was either low, or really old, cause I would drive a few hours non stop an when down or up shifting into 3rd gear it would grind a lil, but if I was just out an out for a lil bit, it would go right into gear no prob, so please someone, anyone, HELP!
  2. Oct 6, 2008 at 5:46 PM
    mudjunkie
    mudjunkie Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    i had the same proble i first tried bleeding my cluth it was a temp fix i then replaced my clutch master cylinder fixed it i would check your fluids it sound like you cluth master cylinder or your slave cylinder 50 dollar part its is a fairlt simple fix
  3. Oct 7, 2008 at 3:35 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    sounds like you have air in your lines. Bleed it.
  4. Oct 7, 2008 at 3:49 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    I would do a few things.
    Try bleeding the clutch.
    Check your fuild level in teh gear box.
    if it is low you have a leak.
  5. Oct 8, 2008 at 2:48 PM
    Tacoma_TRD01
    Maine
    01 Tacoma SR5
    3 inch body lift
    it was was a broken fork!
