My Tacoma does not shift to high gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkamali, Mar 19, 2016.
  1. Mar 19, 2016 at 5:04 PM
    bkamali
    bkamali [OP] New Member
    Hi,
    Yesterday I noticed that both engine check light and slip light, on my Tacoma 2010 6 cylinder access cab, turned on together when I started the truck.
    I also think that the truck doesn't shift to the higher gear when gear is in "D". Because RPM keeps rising up to 3000 RPM at 120 km/hr.
    Any suggestion?
    Thanks
  2. Mar 19, 2016 at 5:54 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    edited for being stupid and misreading!
  3. Mar 19, 2016 at 5:59 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    ...he has a 2010
  4. Mar 19, 2016 at 7:29 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Last winter our Honda started shifting funny suddenly. We had been out of town for a long weekend. It ran fine when we left, but acted weird when we got back. I was able to drive it to a transmission shop where they found mice had built a nest on top of the transmission and chewed through a wire. A wiring harness was all it needed, but that was more expensive than I thought it should have been. Hopefully your problem is an easy fix too.
  5. Mar 19, 2016 at 7:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Do you have a mini-VCI cable and a bootleg copy of Toyota Techstream? If so, see if there are transmission-related fault codes. If not, take it to the dealer or a good independent shop that can diagnose properly.
