My Tacoma is a jackhammer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shwaa, Oct 7, 2016.
  1. Oct 7, 2016 at 5:46 PM
    Shwaa
    Shwaa [OP] Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Let me preface this by saying that my 55k mile Tacoma has been trouble free and that I had a breakfast burrito this morning in Mono Lake, CA that was not worth the price....
    I went on a 1000 mile road trip this past week in the Sierra's, starting in the Bay Area and going to Tahoe, Mono Lake, June Lake and Mammoth areas. There were a LOT of hills and mountain ranges I went through, the truck performed great EXCEPT on downhill mountain ranges. It felt like I was holding a jackhammer and pounding into concrete. Extreme vibration from either the A. steering wheel or B. both the steering wheel and brake pedal. On flat surfaces it was "Ok", little vibration but nothing bad. On the downhill though it become ridiculous, and at times was difficult to maintain control of the truck
    I think I remember this being discussed here.....is this most likely a rotor issue? warped? I am wanting to wait until 60k mile service to have it looked at, but I want to know what the possible issues are before bringing it in.
    Up until now I have only noticed slight vibration occasionally in the steering wheel when braking at 30-50mph....
    Any ideas?
    Thanks
  2. Oct 7, 2016 at 5:49 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If its happening when you brake then its defintiely the rotors. Get new ones along with new pads and do the break in procedure to help cure them. It will help keep you from getting the pulse feeling later on.
  3. Oct 7, 2016 at 5:50 PM
    Shwaa
    Bay Area, CA
    Makes sense but when I last had service done on the truck there was "plenty of " brake pad left. Is it still worth replacing both pads and rotors?
  4. Oct 7, 2016 at 6:00 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You have uneven brake pad material deposited onto the rotor surface, thus causes the jerky feeling and vibration.
    You can sand it off, have the rotors turned or try and re-bed the brakes.
  5. Oct 7, 2016 at 6:03 PM
    Shwaa
    Bay Area, CA
    thanks Jimmy!
  6. Oct 7, 2016 at 6:14 PM
    TexasInfidel
    TexasInfidel Well-Known Member
    It only takes acouple hard power brakes on new stuff to warp a rotor.
    Running from 50mph and braking to a stop in 100 feet like alot of drivers do will indeed twist your sht.
    If you dont drive like the genric idiot? my guess would be a junk st of BFG rubbers
  7. Oct 7, 2016 at 6:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    Lord Helmet and Shwaa[OP] like this.
  8. Oct 7, 2016 at 7:07 PM
    moondeath
    Pa, Gardners
    You should always replace as a set.
  9. Oct 8, 2016 at 6:47 AM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Engine braking is your friend.
  10. Oct 8, 2016 at 9:17 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Don't wait too long to replace your pads and rotors. The longer you drive this way the more damage you do to your steering components and wheel bearings.
  11. Oct 8, 2016 at 9:28 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    I'd first try sanding down both faces of the rotors by hand, see if that knocks down any high spots created by pad deposits &/or glazing. If that fails, or isn't worth your time, new rotors & pads are pretty cheap. I got these on Amazon warehouse for about $130 out the door https://www.amazon.com/gp/aw/d/B005FKS28C/ref=yo_ii_img?ie=UTF8&psc=1
    Brake feel is sublime, zero pulse or shudder. Had my 1st panic stop on the freeway this week. I was prepared to eat their rear bumper but surprisingly stopped with 1 car length to spare.
    Edit to add: while I had the front in the air I'd also wiggle the front wheels to see if there's play. Could be loose lugs or bearing play.
  12. Oct 8, 2016 at 12:23 PM
    moondeath
    Pa, Gardners
    Sanding and creating dust from any of the brake components is always to be avoided. Some brake manufacturers still use asbestos in the linings. Its simply not worth it. Having the rotors ground down at a shop would be the safer way if you choose not to replace them.
    Lord Helmet likes this.
  13. Oct 9, 2016 at 4:26 AM
    TexasInfidel
    The air you breath is more contaminated already.
    A little asbestos wont hurt anything.
    That is if can still find brakes still made with it.
    Most assume that its still being used,actually not
  14. Oct 9, 2016 at 5:26 AM
    moondeath
    Pa, Gardners
    Thats real fucking good advice. :facepalm:
    Jimmyh and Crosis like this.
  15. Oct 9, 2016 at 5:52 AM
    moondeath
    Pa, Gardners
    While most oem brake pads are asbestos free, there are still companies that make asbestos lined brakes and clutches. The only way you know for sure is when you buy the brakes and the box says NAO, Non Asbestos Organic.
    This is quoted from the Toyota Parts Center website.
    There are some after-market brake pad manufacturers that still use asbestos as a brake pad filler material. What's more, there are no regulations requiring that brake pad manufacturers disclose the presence of asbestos. This is more than a bit disconcerting, as inhaling asbestos brake dust can have serious health repercussions. Therefore, it's a good idea to buy pads that are labeled "NAO", which stands for "non asbestos organic." Again, all Toyota OEM brake pads are asbestos free. The risk of asbestos exposure is limited to after-market pads (at least as far as Toyota is concerned).
    Finally, it's a very good idea to wear a mask and/or use a wet brake cleaner of some kind whenever you change your brake pads. It's likely that all brake dust is bad for you, even if it doesn't contain asbestos.
    Jimmyh likes this.
  16. Oct 12, 2016 at 7:48 PM
    Shwaa
    Bay Area, CA
    So my neighbor took a look at my rotors/pads. He does all his own maintenance in his Nissan truck and
    motorcycles. He said my rotors and pads are fine (he showed me, rotors were smooth and pads have plenty of life). He also pulled on some of the suspension components to make sure there isn't any "play"
    he thinks I may need an alignment. Could that also be causing this? If it's not that and not the rotors I'm not sure what else it could be.
  17. Oct 12, 2016 at 8:02 PM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    So I had the same concern rotors fine, bearing and all joint good to go, so right after buying a new set of firestones. Felt like I was driving a bumper car, rear leaf springs recall fixed a lot of the road wobble, but still had vibration. The place doesn't balance correctly or align well. Took to dealer, balanced properly and aligned by dealer fixed all issues with control and vibration.
  18. Oct 12, 2016 at 8:07 PM
    Shwaa
    Bay Area, CA
    Interesting. I got new tires in April and haven't had the truck aligned since, maybe i need to. Thanks
    08tacobear[QUOTED] likes this.
  19. Oct 12, 2016 at 8:12 PM
    08tacobear
    Glad to share. Another time it was just bad rubber like a previous poster stated. They called it "throwing a belt or belt shift" aka "bad rubber" and the tire dealer replace the offending tire. Then all was well again.
