My Tacoma is a work truck, over heating.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustinJ, Jul 15, 2012.
  1. Jul 15, 2012 at 7:40 AM
    dustinJ
    dustinJ [OP] Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    I drive all day long every day. About 300 miles a day. Lots of stops and idling. On these hot days, really anything over 90 my A/C stops blowing cold ( unless I rev the engine to 1500 rpm) while sitting and idling for any more than a few minutes.
    I'm putting on my lift and wheels and tires tomorrow and was wondering while I was at it if I should throw on an electric fan to help keep it cool during the summer. Coolant looks good but maybe I should have it flushed. Very hot and dry here and I'm on dirt roads all day in the oil field.
    Suggestions
    Thanks
    Dustin
  2. Jul 15, 2012 at 7:45 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    the way you worded the title, I thought your trucks engine was overheating...
    As for the coolant flush, check your users manual for correct intervals. It doesn't hurt to change it early, but not necessary.
  3. Jul 15, 2012 at 7:49 AM
    dustinJ
    Dustin
    Amarillo tx
    I sat and watched it yesterday. It was 98 here and the temp guage got real close to the red before I jumped on the road to cool it off. It cools just fine going down the road. I just expected it to cool better while idling. I'm going to wash out the radiator today. Maybe something got between the condenser and rad.
  4. Jul 15, 2012 at 8:41 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I wouldn't be all that concerned with it being a newer truck. Unless you have a blow over through the over flow tank.
    Last week the temps here where over 100 and I noticed with my scangauge the truck temp was running anywhere from 188 to 213. My normal temp without a/c is 193. I think the coolant will not boil until something like 250-260 degress.
    I have noticed the a/c is just about useless at idle. I think this is how newer a/c systems work.
    Get a coolant tester to make sure your coolant is working correctly.
  5. Jul 15, 2012 at 8:44 AM
    06sr5prerunner
    06sr5prerunner DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    I can see the pump jack in the back! wooo i know your feeling im ou in the fields too. i recommend anything thats gonna keep you fresh in that truck. im sure you work loooong days out in the oil fields! anything to keeps us cool.
  6. Jul 15, 2012 at 8:44 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Maybe the AC needs to be recharged. To keep the truck from over heating, use the heater to take the heat off of it. Perhaps your thermostat is bad.
  7. Jul 15, 2012 at 8:49 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    How long are you idling and how much time is actually spent driving? These trucks do not cool very well when idling.
  8. Jul 15, 2012 at 8:50 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I'd clean out the condenser first before a coolant flush, especially on dem oil fields roads
  9. Jul 15, 2012 at 1:25 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Do you hear the fan kicking up? If it's at full lock for the temp, it would roar like a beast (it's that massive roar when first starting the truck cold, as the silicone fluid is all drained out of the working area and it's turning at full lock until its pumped back).
  10. Jul 15, 2012 at 1:33 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    x2. the fins need to be cleaned to transfer the heat, and it wouldnt hurt check the hoses like singlecabgay said. oh i mean guy:D
  11. Jul 15, 2012 at 1:38 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I had plenty of heat problems on cars when I lived in TX. Most of my cars, I took the thermostat completely out. They would run a little cooler in the summer, but in the winter the heater would take longer to get up to temp because of that. You can also reroute the coolant hoses going to the throttle body to bypass it and just connect to eachother. These are small no cost things to try to keep cooler. Cleaning out all the dirt and dust from the radiator and ac condenser on a weekly basis is also helpful. Since you idle alot, an electric fan will push more air than the machanical fan, but that is the only advantage of eletric on cooling. Once you get moving, the mechanical fan will out perform the electric on cooling. Checking the charge on the AC isnt a bad idea either, just be careful not to overcharge it, you'll get poor performance and maybe leaks. Then window tint also makes a huge difference on interior temps, and even when you are sitting idling, put a sun shade in the front window. Hope this helps keep you a little cooler.
  12. Jul 15, 2012 at 1:55 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    He has a 2011... if his AC needs a recharge, he's got a warranty issue.
    AC systems are sealed and they don't need routine recharging.
    Modern AC systems using R134a, and it's replacement, R1234yf, are simply not as efficient as the old R12 systems.
    When ambient temp climbs, the AC temp will climb.
    BUT...
    The OP's comment on the temp gauge getting close to the red is disturbing. I sit in heavy traffic on the way home, and it's been 100 degrees, UG is showing intake air temp of 115, and I'm idling with my AC running and the engine is just sitting between 199 and 204.
    Even in Vegas, I've never seen it above 204, and my AC always blows cool or cold.
    I suspect he may have an issue with his fan clutch, or perhaps the fan shroud is damaged or missing.
    Yes, if that's the case, an aux electric fan will certainly help, but it should not be needed on a 2011.
  13. Jul 15, 2012 at 1:57 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +10,000... but do NOT use a pressure washer.
    I found out the hard way that a pressure washer will bend the fins over. Cost me a new radiator.
    Just soak the whole thing down with water, sprayed in from behind, then soak it with Simple Green, and flush with water.
  14. Jul 15, 2012 at 2:40 PM
    JustMe
    JustMe Active Member
    You have a 2011 right, take it in for warranty work. Something is not right on your truck, my 2009 had no issue with 124 in Death Valley, AC worked great and the engine temp was barely above normal..the needle barely moved.
  15. Jul 15, 2012 at 2:49 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Warranty won't cover cleaning out a dirty rad, if that is the culprit. I would make sure the rad and condensor are clean, and if the problem persists, then for sure, warranty, unless over milage. I'm betting it won't persist.
  16. Jul 15, 2012 at 3:51 PM
    JustMe
    No way the rad on a 2011 would be that dirty, unless it was taken into a deep mud hole. I put 200k on my old 92 Toyota PU and the rad was never cleaned other then the spray from a normal wash and it still very clean just a few dents in the fins. My 2009 is still clean and I do a lot of trail driving.
  17. Jul 15, 2012 at 4:02 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Depends on the conditions its operating in. It certainly is possible. Either way, I would be checking it, or be prepared for a bill from the dealer.
  18. Jul 15, 2012 at 4:15 PM
    dustinJ
    Dustin
    Amarillo tx
    Thanks for all the ideas guys. I washed out the between the condenser and rad today and topped off the coolant. Checked all the hoses. It was pretty dirty. Well see how that works tomorrow.
    Thanks for all the replys.
    Dustin
  19. Jul 23, 2013 at 12:03 AM
    bruce1271
    bruce1271 Well-Known Member
    Any update on your overheating issue? Mine is starting to act up. Did you find anything that helped/needed replaced?
    Thanks
  20. Jul 23, 2013 at 7:54 AM
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    Newer vehicles really don't like being run without a thermostat. They depend on it being hotter for proper combustion. If you can't fix it and want to go real radical, put some vents in your hood.
