My Tacoma just failed state emissions test - Please Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zeagle50, May 13, 2021.
  1. May 13, 2021 at 2:56 PM
    zeagle50
    zeagle50 [OP] Well-Known Member
    Please help! Thank you
    My completely stock 2017 TRD Sport Tacoma – 22,300 miles on it, which hasn't had the battery out at all, just failed emissions inspection today. - Local shop - not Toyota dealer.
    The Massachusetts inspection station told me and showed me the inspection that said:
    1. Miles since code clearing = 2
    2. Warm up since code clearing = 1
    3. Readiness result = FAIL
    The inspector asked me if I cleared the codes, disconnected the battery, had any work done to it recently, or jump started any one. I answered NO to all those questions. I don’t know how to clear codes, never disconnected the battery and not sure what Readiness result is. I drove my truck about 2 miles from work to the station. They did an oil change and then failed the inspection. Told me to drive it 100 miles then return.
    1. My question is how can the codes get reset or cleared when I did not do anything. - Miles since code clearing = 2
    2. He checked the battery terminals and they were tight. NO red engine light on. No signs of problems – always starts, runs and drives fine.
    Thank to any one that can help!
  2. May 13, 2021 at 3:01 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Where were you 2 miles before that?
    Is this a scam to get you to spend some money?
  3. May 13, 2021 at 3:04 PM
    zeagle50
    I drove from work - about 1 1/2 miles to the dollar store. Stayed in dollar store for 10 minutes, Came out of store and drove across the street to station that did the inspection
  4. May 13, 2021 at 3:05 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How long is the emissions system under warranty?
  5. May 13, 2021 at 3:05 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Maybe whoever changed the oil thought the maintance light was a check engine light and they tried to clear it. Readiness monitors are just monitors for the different systems on the truck. A certain criteria (milage, speed, etc) has to be met before the monitors can be verified. Drive it for a bit and maybe AutoZone can tell you if your monitors are set, then you can go through emissions again
    Chew, henryp, tonered and 11 others like this.
  6. May 13, 2021 at 3:06 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I thought emissions shit was lifetime....maybe it's 80k? I forget.
    hiPSI likes this.
  7. May 13, 2021 at 3:06 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    5yr I believe
  8. May 13, 2021 at 3:07 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    2017s have to do emissions testing in MA? Seems odd.
    Even in CA you have 8 years until you have to start doing that.
  9. May 13, 2021 at 3:07 PM
    rnish
    Tacoma 2nd gen
    Take it to the dealer, emission failed under warranty. :notsure:
  10. May 13, 2021 at 3:08 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Ahh! The nanny state!!!
  11. May 13, 2021 at 3:09 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I’m pretty sure emissions is 10 years 100k miles
    ORtoCOTaco likes this.
  12. May 13, 2021 at 3:09 PM
    zeagle50
    Dealer told me only catalytic converter has 84 month warranty - everything else 3 years 36000 miles
  13. May 13, 2021 at 3:09 PM
    eon_blue
    Azusa, CA
    Federal emissions warranty is 8 years/80k miles.
    ORtoCOTaco, tonered, SR-71A and 3 others like this.
  14. May 13, 2021 at 3:10 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    zeagle50[QUOTED][OP] likes this.
  15. May 13, 2021 at 3:12 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Emissions systems federal is 8 years /80k miles. Some states are more, like 10 years /120k miles.
    tonered and 71tattooguy like this.
  16. May 13, 2021 at 3:15 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    @zeagle50, this^^^^. Don’t panic. Just drive it for 100 miles
    tonered, Justinogo, HisDad and 4 others like this.
  17. May 13, 2021 at 3:15 PM
    zeagle50
    Thanks for all the responses -
    Federal emissions warranty is 8 years/80k miles. Toyota dealer told me no - only cat. converter was covered
    But why does the inspection say 1.__________ Miles since code clearing = 2
    How can the code get cleared if I never unhooked the battery and the battery isnt dead - All my preset stations on radio are still there
  18. May 13, 2021 at 3:16 PM
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    Federal emissions is 8/80k and typically only covers cats and ecu failures. Some cars have california emissions warranties on some components and can be anything from 7/70k to 10/150 I think for pzev vehicles. Not sure on what the Tacoma has but should be in owners manual. But it’s only for component failures. If you only drive short distances your monitors won’t ever run or if you never let your fuel level get low enough.
  19. May 13, 2021 at 3:17 PM
    ns3v3n
    ns3v3n Member
    I took my dad's Altima to do smog and he didn't drive the car much since last year. The smog guy plugged the machine into the car then 2 minutes later told me that it would fail the test. Told me to drive the car for 50-100 miles, if going on the freeway, do not go faster than 65 mph. He said something about the car have to complete a drive cycle. My dad changed battery about a year ago and he never drove it longer than 10 miles at a time. I took his car and drove it all week then brought it back and it passed the test. Your Tacoma might have the same problem but you said you haven't disconnected the battery before. Before you take it back to Tacoma, try driving it for a week and rack up some miles, take it back to your smog guy and run the test again, it should be free and result might be different and it will pass after driving it for awhile. 22k on a 2017 implies this truck does not get driven much so it's worth trying this.
  20. May 13, 2021 at 3:18 PM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    I would go to a different testing place.
    Hank Heel and Kev250R like this.
