My Tacoma just failed state emissions test - Please Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zeagle50, May 13, 2021.
  1. May 13, 2021 at 3:19 PM
    zeagle50
    zeagle50 [OP] Well-Known Member
    My fuel level is always at least 1/2 tank full. I did not know that could effect emissions inspection
  2. May 13, 2021 at 3:20 PM
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    You can’t trick the machine it get plugged in and reads the ecu, if the monitors haven’t run or the code has a dtc currently present you fail. Has nothing to do with the guy doing the test.
    Chew, tonered and SR-71A like this.
  3. May 13, 2021 at 3:21 PM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    So the machines never fail?
  4. May 13, 2021 at 3:22 PM
    Timmcc02
    Tim
    2017 TRD OR
    So emissions monitors will only run between 1/4 tank of fuel and 3/4 tank of fuel. There is a preset list of driving circumstances that need to be fulfilled to achieve an emission drive cycle which will run the emissions monitors.
  5. May 13, 2021 at 3:22 PM
    Schidtbrick
    Schidtbrick Member
    James-Anthony
    2019 MGM TRD OR DCSB
    you could try idling at 2500 RPM in park for 2 minutes. I had to do that a year ago with a Benz to get the drive cycle to update.
  6. May 13, 2021 at 3:22 PM
    Timmcc02
    Tim
    2017 TRD OR
    The machines either work or they don’t which means they can plug it in and do the test or not.
  7. May 13, 2021 at 3:23 PM
    HVLA
    Idaho
    Interesting.
  8. May 13, 2021 at 3:27 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Just take it for a good drive this weekend and see if it passes. No one on here can tell you for sure why it reset, or even if it really did reset.
    I wouldn't worry until it happens again.
    Chew, skiploder, Kev250R and 2 others like this.
  9. May 13, 2021 at 3:29 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Could someone have flashed your truck while you were in the dollar store? :burnrubber:
    All joking aside, what @whatstcp said. Just drive it around for a week, and go back. If it does it again, then perhaps your battery is compromised, causing your ECU to lose memory. :notsure:
    whatstcp and Skydvrr like this.
  10. May 13, 2021 at 3:32 PM
    zeagle50
    Ok I will try driving it 100 miles and see what happens - Inspection station told me its probably going to fail because something is clearing codes - report read - Miles since code clearing =2 which he said meant battery was disconnected or codes were erased. I dont know how to erase codes and truck has original battery - never disconnected
    Hope driving it works - I will find out in 3 days - Thanks to all
    ABA180 likes this.
  11. May 13, 2021 at 3:34 PM
    zeagle50
    Thanks - I will also check battery - that I know how to do with a meter. Also I will check with truck running - alternator charging battery
  12. May 13, 2021 at 3:34 PM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    In PA, emissions are required every year in the metro areas like SE PA.
  13. May 13, 2021 at 3:35 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I feel like that's a German or European thing. I think on VW you can force a drive cycle in the bay as well.
    SR-71A likes this.
  14. May 13, 2021 at 3:36 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It's probably realistically like 10-15 miles in some cases. 100 miles is just boilerplate to ensure its actually done.
    whatstcp likes this.
  15. May 13, 2021 at 3:37 PM
    #35
    RyanDCLB
    4/19 DCLBOR
    If you're on a 4 year old OEM battery, chances are it's toast. :notsure:
  16. May 13, 2021 at 3:38 PM
    #36
    zeagle50
    I JUST FILLED MY GAS TANK RIGHT BEFORE THE EMISSIONS TEST - I DID NOT KNOW THIS - THANKS
    RyanDCLB likes this.
  17. May 13, 2021 at 3:40 PM
    #37
    eon_blue
    Azusa, CA
    Even for new vehicles though? I just meant that over here you don't have to start getting tested until the vehicle is 8 years old (then you go in every other year for a test).
    It seems weird they'd require emissions testing annually on brand new vehicles
  18. May 13, 2021 at 3:42 PM
    #38
    Timmcc02
    Tim
    2017 TRD OR
    It doesn’t matter for the actual test. It’s for the monitors to run, typically monitors will stay completed once they’ve run unless the vehicle sits for extended periods of time without being driven or battery disconnected or codes cleared.
  19. May 13, 2021 at 3:43 PM
    #39
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Texas starts on the 2nd year of new car ownership, then it's annually thereafter.
    They give you a pass on the 1st.
  20. May 13, 2021 at 3:44 PM
    #40
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    If you have a ScanGauge, you can check the readiness monitors as part of the scanning. When I was chasing a CEL in my C5 right around inspection time I was using my ScanGauge from my truck to check readiness.
    tonered and davidstacoma like this.
