My Tacoma just failed state emissions test - Please Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zeagle50, May 13, 2021.
  1. May 13, 2021 at 3:46 PM
    #41
    eon_blue
    Azusa, CA
    Damn I didn't think anywhere could be more strict than here, guess I was wrong.
    Where we really get screwed is on the whole CARB thing, if an aftermarket part (emissions or engine related) isn't CARB approved, then you'll fail your visual inspection every other year. CARB is nothing but a money grab, costs a ton for a company to apply for it and get approved.
    Rock Lobster[QUOTED] likes this.
  2. May 13, 2021 at 3:50 PM
    #42
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Get the truck hot well before the test and do not shut off the engine while waiting for the test. Good luck!
  3. May 13, 2021 at 3:59 PM
    #43
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    Unless you bought out of state. :)
    Other than a battery issue, I'm thinking more of an odd glitch during the test. All they do is hook up an ODB II Scanner and run it.
    I'd have the battery and alternator tested. Most auto parts places can do that for you. 2017 may be due for a new battery.
    If it still fails, take it to the dealer to be inspected. Just keep your mouth shut, pay them for the inspection. If it fails is an EPA Emission issues
    From EPA website.
    https://www.epa.gov/transportation-...frequent-questions-related-transportation-air
    Specified major emission control components are covered for the first 8 years or 80,000 miles (whichever first occurs). The specified major emission control components only include the catalytic converters, the electronic emissions control unit or computer (ECU), and the onboard emissions diagnostic (OBD) device or computer. If you are a resident of an area with an Inspection and Maintenance (I/M) program that meets federal guidelines, you are eligible for this warranty protection provided that:
    • Your car or light-duty truck fails an approved emissions test; and
    • Your vehicle is less than 2 years old and has less than 24,000 miles (up to 8 years/80,000 miles for certain components); and
    • Your state or local government requires that you repair the vehicle; and
    • The test failure does not result from misuse of the vehicle or a failure to follow the manufacturers’ written maintenance instructions; and
    • You present the vehicle to a warranty-authorized manufacturer representative, along with evidence of the emission test failure, during the warranty period.
  4. May 13, 2021 at 4:13 PM
    #44
    zeagle50
    zeagle50 [OP] Well-Known Member
    ROCK LOBSTER - THANK YOU I PRINTED THE INFO YOU GAVE ME AND WILL ALSO LOOK IT UP IN MY OWNERS MANUAL - I DID CHECK THE BATTERY - I USED A DIGITAL METER AND READ 13.6 WHILE RUNNING AND UNDER LOAD AND 12.6 WITH ENGINE OFF. I BELIEVE THIS SHOWS THE BATT. AND ALTINATOR OK BUT WILL GET IT CHECKED ANY WAY
    THANKS TO ALL FOR THE HELP!
  5. May 13, 2021 at 4:17 PM
    #45
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Was the 12.6 volts right after you shut the truck off?
  6. May 13, 2021 at 4:18 PM
    #46
    zeagle50
  7. May 13, 2021 at 4:18 PM
    #47
    zeagle50
    12.6 right after i shut truck off
  8. May 13, 2021 at 4:26 PM
    #48
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    And, the next comment will be something like, "wait an hour for the voltage to settle, and check again"...
  9. May 13, 2021 at 5:06 PM
    #49
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    :D
    Yeah... Pretty much. If it holds at 12.6, it still has some life in it.
  10. May 13, 2021 at 5:09 PM
    #50
    Flyersfan36
    Flyersfan36 Well-Known Member
    Yep in PA you have to get emissions to pass inspection. Doesn't matter if it's new.
  11. May 13, 2021 at 5:19 PM
    #51
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    Pennsylvania Vehicle Emissions and Maintenance Program
    Who must participate?Motorists with gasolinepowered cars, vans and light-duty trucks (9,000 lbs. or less gross vehicle
    weight), with a model year 1975 and newer registered in Allegheny, Beaver, Berks, Blair, Bucks,
    Cambria, Centre, Chester, Cumberland,Dauphin, Delaware, Erie, Lackawanna, Lancaster, Lebanon, Lehigh, Luzerne, Lycoming,Mercer, Montgomery, Northampton, Philadelphia, Washington, Westmoreland and York counties are required to participate in Pennsylvania’s Vehicle Emissions Inspection & Maintenance (I/M) Program.
    Flyersfan36[QUOTED] likes this.
  12. May 13, 2021 at 5:22 PM
    #52
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    100% correct advice......
    It has nothing to do with the emissions. The various system monitors need to be properly activated. This is done by driving the vehicle for a day or two.
    tonered, zeagle50[OP] and HisDad like this.
  13. May 13, 2021 at 5:23 PM
    #53
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    It sounds like you didn't drive it long enough for the engine and exhaust to reach full operating temperature. The inspection guy I use told me to drive for at least 20 minutes before coming in. I wouldn't panic until I drove it the 100 miles and went back for another try.
    zeagle50[OP] likes this.
  14. May 13, 2021 at 5:23 PM
    #54
    CG256
    CG256 Well-Known Member
    '19 TRD OR
    VWs have an elaborate cold start/idle/accelerate/cruise/decelerate dance to speed along the emissions readiness.
    The TDIs are the ones that had a special mode where if they detected only the front wheels spinning with 0 degrees of steering input to go into smog check mode, but that wasn't exactly legal.
    SR-71A likes this.
  15. May 13, 2021 at 5:27 PM
    #55
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Drive 'long' miles - not 10 trips at 10 miles. Try 4 trips at 25 miles or 2 trips at 50 miles.
  16. May 13, 2021 at 5:40 PM
    #56
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're battery voltage dropped too low. You're Taco started, but the hard start reset the DTCs. That distance was not good enough to set all of rhe Readiness Codes. Get a new battery and drive 40mi to 50mi.
    jayuu and Kev250R like this.
  17. May 13, 2021 at 5:45 PM
    #57
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
  18. May 13, 2021 at 5:47 PM
    #58
    dalemats
    dalemats Well-Known Member
    dale
    2017 Tacoma Limited 2WD
    2017 MGM Limited 2WD DCSB, bed mat, wheel, spare & tailgate locks, Gen 2 running boards, tri-fold cover, ShiftSense Pro v2, LED interior lights, Bracketeer fire extinguisher bracket, Pop & Lock power tailgate lock,
    Wow, didn’t know you had to drive a bit before the test. Interesting.
  19. May 13, 2021 at 6:00 PM
    #59
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    OP where are you in mass? Is this regionally or a relatively new thing? Never had to have an emissions test (that I know of) during inspection but wouldn’t surprise me if it’s a new mandate in our lovely state.
  20. May 13, 2021 at 6:02 PM
    #60
    zeagle50
    Thanks TONERED - this makes sense - I did test the battery under load - 13.6 v running - 12.6 not running - I thought I had a good battery but it is the original one
    tonered likes this.
