My Tacoma Lags
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sslavale95, Nov 6, 2019.
  1. Nov 6, 2019 at 1:44 PM
    sslavale95
    sslavale95 [OP] New Member
    Sam
    2014 Silver Tacoma 4x4
    Soo, I have a 2014 tacoma SR5 4x4 long bed. I've done a couple things to it, such as adding a K&N 77 series intake. As well as a flowmaster series exhaust. My tacoma kicks now which is nice but it still lags. And idk if thats the right terminology but when I put my foot down its takes a minute before the truck responds. I was told that a bigger performance throttle body could fix this problem. Does anybody know if thats true or if not that, what else could work ?
  2. Nov 6, 2019 at 1:45 PM
    Matt_DCSB
    Matt_DCSB Well-Known Member
    NM
    Sounds like you need a pedal commander or HP tuner
    Thuguon2.7 likes this.
  3. Nov 6, 2019 at 1:47 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Sounds like you have an oiled K&N Intake. I recommend cleaning the MAF sensor with CRC MAF sensor cleaner. May take away some of that "lag" if the sensor is dirty. Dry filters are recommended for these trucks
    Chunk, TACOMA2NDGEN and whatstcp like this.
  4. Nov 6, 2019 at 1:51 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Kicks but lags ? which one is it,stock setup is the best option.
    Thuguon2.7 and EatSleepTacos like this.
  5. Nov 6, 2019 at 2:16 PM
    81shark
    81shark Well-Known Member
    drive by wire and slush boxes are great combo's for instant reaction times
    i recommend planning 3 moves ahead
  6. Nov 6, 2019 at 2:26 PM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    pedal commander or tune is your only fix
    DGXR likes this.
  7. Nov 6, 2019 at 6:41 PM
    3Dog
    3Dog good boy
    Rocky Mountain high...
    2015 Tacoma 4x4 auto TRD Sport DCSB
    x2
  8. Nov 7, 2019 at 7:48 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    If it's just city driving put the gear shift in 4th.
  9. Nov 7, 2019 at 8:01 AM
    sslavale95
    Sam
    Thanks guys, appreciate the help
  10. Nov 7, 2019 at 8:05 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    I'd definitely start with this before going any other route! If it isn't your issue than yea maybe a tune or other option!
    BassAckwards[QUOTED] likes this.
  11. Nov 7, 2019 at 9:09 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Poor performance on throttle tip-in... I think it's just inherent in the stock configuration. You won't get drag race launches out of these trucks, not with an automatic transmission. The drive-by-wire software is very conservative, meaning it doesn't open the throttle valve as much as your right foot is requesting, until you get to WOT inputs. And I agree the pedal commander is your best bet for a more responsive throttle. Not sure about the oiled filter effects, but I'm thinking it can't be good. Use a standard air filter or at least something that is not oiled.
