My Tacoma tried to attack my garage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by machec, Mar 2, 2013.
  1. Mar 2, 2013 at 12:45 PM
    machec
    machec [OP] Member
    Hey guys, I have a 2012 Tacoma with barely 3000 miles on it, all stock. It was mid 40's here today so I hose off all the salt on it and let it dry off outside. I get in it to drive the flat 25 feet into my garage and as I step on the brake to slow down to park it the ABS flips out and all the wheels start clicking but the truck is still fricking driving forward even though my foot is crushing the brake pedal. By sheer luck and instinct I was able to throw it into park before I drove through the back of my garage.
    I searched around here but don't really know what to search for. I've read about the ABS issues and VSC but haven't come across anything where the truck is still actively driving itself while braking. I'm in NH so some strange ABS behavior is not new to me and I haven't really had any issues this winter but this new and I really don't need to be driving into people at a stop light.
    Thanks for any info or link to an appropriate thread.
  2. Mar 2, 2013 at 12:48 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    welcome, and did you get a good amount of water on the brakes maybe? think it maybe froze on the disc?
  3. Mar 2, 2013 at 12:55 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i know garages can be very slick when wet. i suspect your concrete is smooth instead of brushed like the driveway.
    i had my old 92 eat my workbench. i had the seats forward to access my tools in the back, and assuming it was in neutral, pushed the clutch start cancel button and started the truck through the open window. well, she started right up and crept right into the bench as i tried to yank the door open and fold the seat back so i could get in to shut it off. turns out she was not only in gear, but also in 4lo. whoops. no considerable damage though. glad it was the bench and not the wall
    dont feel bad, at least yours was out of your control instead of a stupid mistake :)
  4. Mar 2, 2013 at 1:09 PM
    machec
    machec [OP] Member
    tostidos - thanks, rinsed the heck out of it but it was outside for a few hours at 45 before I drove it in so no freezing
    92dlxman - yup it's smooth and there was snow on the tires but I was just coasting the few feet to the garage on flat ground. No different than getting into it coming home driving through six inches of snow.
  5. Mar 2, 2013 at 1:22 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  6. Mar 2, 2013 at 1:27 PM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    i wouldnt worry about it. if it does it again you have a problem. probably slick tires due to snow/water/ice, truck was cold as you said it sat out for a few hours at 45* rpms were higher due to the fact it was cold. may have lurched a little bit and caused the abs to kick in when you were smashing the brakes.
  7. Mar 2, 2013 at 1:46 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    There's been a lot of reports that the 2nd gen ABS does more harm than good when the conditions are icy/slick.
    Did you say that you slammed the shifter from drive, through neutral and reverse, into park, while still moving forward/wheels spinning?
  8. Mar 2, 2013 at 2:10 PM
    machec
    machec [OP] Member
    Garage was pretty dry, just some slush on tires from moving the truck, nothing out of the ordinary. Running blizzaks also.
    Was nearly fully into the garage when it started, foot on brake, ABS on and clicking, wheels weren't spinning but the truck was certainly moving forward all by itself. Yes, from drive to park.
    Gotlift - that seems about right. My problem with it that I can't remember the last time I had a car without ABS, and there's been many, and absolutely none of them did anything like this. I would have thought this ABS would be more, um, "polished" I guess would be the word for it.
  9. Mar 2, 2013 at 2:19 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Some people will discount your story but I don't doubt you. The ABS on our trucks sucks.
  10. Mar 2, 2013 at 2:27 PM
    BillyP
    BillyP Well-Known Member
    Billy
    Cedar Point, NC
    13 DBL Cab TRD-OR
    I'd have that truck into the dealer to have it checked.
  11. Mar 2, 2013 at 3:27 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I tried something with my truck. We had some freezing rain and sleet But it was not solid ice on the road. I stepped on the brakes doing 10 mph and the abs kicked in and would not stop. I went at least 50 ft before I came to a stop. I yanked the ABS fuse and tried again. Stopped in less than 10 ft no sliding.
  12. Mar 2, 2013 at 3:42 PM
    machec
    machec [OP] Member
    That's my point. Doesn't it worry you if you have to second guess your ABS? Just the fact that there's threads about how to disable it is troubling. Before this truck I had an 04 F250 for 6 years, never had an issue with ABS. In fact never even thought about ABS, which is the way it should be. It should just work.
  13. Mar 2, 2013 at 3:43 PM
    6L PSD
    6L PSD Well-Known Member
    North Pole, AK
    '11 4x4 DCSB OR TXP
    Fogs anytime, locker anytime, Moose lights (Lightforce), Randy Ellis Design light bar
    Had the VERY same thing happen last winter! I parked the truck outside while working on another in the garage, it was about 15* out. After a couple hours I put the truck back in the garage. I stopped a little short, so eased up on the brake to just idle forward and there we go...brakes hard as a rock and still going! It took out a toolbox and a lightforce. Never had it happen since, but you can bet your ass I have hand on the shifter when parking!
    I told my bud about it since his wife had just bought a new 2012. Not two months later, same set of circumstances, he got to buy a new replacement grill!
  14. Mar 2, 2013 at 3:55 PM
    machec
    machec [OP] Member
    Hey that sounds pretty spot on. Do you remember if you were at high idle? It probably was if it was a cold start. Strange thing is that mine will do random high idle during driving even when the engine is at temp, be going down hill and it will down shift then rev up for some reason. Very weird.
    Billy - going in next week for sure
  15. Mar 2, 2013 at 4:00 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    mine did that once on a rainy misty morning...just 101% humidity. first time
    on the brakes felt like it was trying to clear ice off the rotors or something...for
    10 feet. then wham, lockup...hasn't done it since
  16. Mar 2, 2013 at 4:02 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    Typical Tacoma ABS in my opinion.. These trucks suck that way.. Slap it in neutral quickly has helped me in the past..
    This summer I will disable it..
    If I don't trade it off on another MegaCab.. I really miss my MegaCab..
  17. Mar 2, 2013 at 4:36 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Not another "my ABS sucks" Mine works fine must be OK stops better then any other trucks in it's class.
  18. Mar 2, 2013 at 5:38 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    good for you bub
  19. Mar 2, 2013 at 6:34 PM
    6L PSD
    North Pole, AK
    '11 4x4 DCSB OR TXP
  20. Mar 25, 2013 at 9:20 AM
    Jaws9760
    Jaws9760 Active Member
    Northern Idaho
    2013 V6 4x4 DCLB TRD Sport MagGrey
    Bed liner shovel mount, head rest vertical rifle mount, console .380 holster. Tailgate hose clamps & washers. Green LED dome light, Disabled seat belt chime.
    Hey Hugh, I'm thinking about pulling my ABS fuse but I'm a wee bit paranoid about unintended consequences or cocking up my new pickup.
    Did you pull ABS No2, the lower amp fuse? Did you get a dash light?
    I keep getting referred to the switch methods but I don't want a switch and I don't want to fool w/ the wiring, just want to pull the fuse and call it a day. Thanks in advance.
