My Taco's driver's seat has become a real pain in the butt!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChadVKealey, Jul 17, 2022.
  1. Jul 17, 2022 at 6:49 PM
    ChadVKealey
    ChadVKealey [OP] Well-Known Member
    Philadelphia, PA
    2017 Silver Sky Tacoma SR5
    None (yet)
    Over the last year or so, spending any more than an hour or so driving has lead to soreness and numbing in my lower back and posterior. I've tried the limited lumbar adjustment as well as small travel pillows but nothing seems to help.
    Now, it's 5 years old, so maybe I've just worn down the cushioning. Or, could also be I'm just getting too damn old.
    Anyway, I'm looking for different options. Anyone had success with any particular type or brand of add on cushion? Does anyone sell aftermarket replacements for the factory seat cushions? Are the seats from higher trim models (TRD or Limited) any better/more supportive than the SR5's seats?
  2. Jul 17, 2022 at 6:51 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    look into risers. They are quite popular around here. You can either lift up the back or the front or both to see what relieves the most discomfort
  3. Jul 17, 2022 at 6:54 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Have you tried installing Seat Jackers? I had the same problem you did when I first got my Tacoma. Turns out the problem was my thighs/hips were the root cause of my pain.
    They were very easy to install, and solved all my problems. Oh, and I'm almost 6' 3", but they didn't cause a headroom issue for me.
    Xx_Evilvirus_xX and AJKlug1 like this.
  4. Jul 17, 2022 at 7:26 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I'll second the Seat Jackers. I'm on the shorter end but I felt the lack of thigh support was causing my discomfort. Try different combinations with the front and rear until you find relief. Well worth the $$$.
  5. Jul 17, 2022 at 7:31 PM
    ChadVKealey
    Philadelphia, PA
    None (yet)
    Did you install the front or rear ones? Seems like a lot of money for what's basically a chunk of aluminum, but if it ends the numbness, I'll try them.
  6. Jul 17, 2022 at 7:34 PM
    Borracho Loco
    DFW, Texas
    I installed only the front ones. It slight lifted the seat, but didn't raise the height of the seat overall. With my long legs, the elevation really helped my thigh/hip pain when I would drive for long periods of time.
  7. Jul 17, 2022 at 7:44 PM
    123taco
    123taco Well-Known Member
    Greg
    14 SR5 AC 4X4
    When I do extended time I put around a 2 inch pillow, towel whatever on seat. Helps me and easy fix.
  8. Jul 17, 2022 at 7:45 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I love my seat jacker. The front put too large of an angle but I used about an inch worth of washers and longer bolts in back to even it out and it completely changed the feel. The price is borderline crazy but it would be really hard to rig something safe up front. The back just requires properly rated bolts and some washers.
  9. Jul 18, 2022 at 5:49 AM
    ChadVKealey
    Philadelphia, PA
    None (yet)
    Thanks for the tip on the jackers. Ordered a set last night and hopefully they arrive this week. Next Monday we're driving from home (just north of Philly) to Portland, ME, so that's a whole lot of seat time.
  10. Jul 18, 2022 at 6:05 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    You might also try one of the gel seat cushions. Amazon, ebay, etc. have them.
    https://www.amazon.com/Purple-Cushion-Sitting-Nonslip-Cover/dp/B08P3TRZS5/
