My Take on a Trail Gear Bumper
Discussion in '1st Gen. Tacomas (1995-2004)' started by MatthewMay1, Aug 5, 2013.
  1. Aug 5, 2013 at 9:31 PM
    MatthewMay1
    MatthewMay1 [OP] I'm an amateur professional.
    Matthew
    Lone Star Republic/NW Arkansas
    '01 TRD Off-Road
    Lots 'o stuff. Look at my build! -->
    I had always dreamed of a plate bumper. I really wanted an Elite, but I could not afford it. I then looked at the All Pro APEX bumper, but still couldn't afford it. I then decided to go with a Trail Gear Low-Profile bumper with the light hoop. After looking at other people's trucks with the bumper, I decided to put some diamond plate on the top to fill it in. The rest is history!
    Here is the bumper when I brought it home!
    First thing on the agenda was to get the light bar welded on.
    Next, came the top plates. I don't have a picture of my mock up cardboard, but here's this.
    Driver side:
    Passanger side:
    Now was about the time when i started getting ideas. I didn't like being able to see the washer fluid container and didn't want to modify it. More plate!!! But first, mock-ups!
    After doing all that to both sides, i had tons of plate left. I decided to fill in the smaller triangles on the front. I forgot to take close-up photos of those at the time. They can be seen in the finished product photos. Here, we are welding in the plate permanently.
    Now the bumper is all finished! Some before powder coat glamour shots...
    Off to the powder coater! I decided to take my wheels at the same time since the paint I put on them last year had started to flake off and they looked really bad.
    Everything is finished! I went with a light textured black for the bumper and a non-textured satin black for the wheels. Great combo in my opinion.
    Got everything mounted back up! I love how it all turned out! And yes, I know the skid plate isn't there. I have to find some new bolts to mount it up with.
    Got a little dirty!
    And just because i can.......
    I also did the "fog light mod"...sort of. I moved my turn signals to the corner lights and secured them with plastic weld and epoxy. Pics to come later. I also trimmed the plastic inside the wheel wells that extended too far. Thanks for looking!
    EDIT:
    Here are some pictures showing my turn signal switchbacks. This is the guide I used to do it. http://www.tacomaworld.com/forum/1st-gen-tacomas/186115-free-blinker-light-relocation-mod.html
    Just got my LED fog lights installed. Wired them to a Toyota fog light switch in place of a blank. They are so bright!
    They are just as bright as the reflection of the sun off the hood!
    UPDATE:
    I got my Warn XD9000i installed! Did quite a bit of trimming in order to get it to fit.
  2. Aug 5, 2013 at 9:59 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    looks good man im in the process of building mine at the moment.. one thing im not a huge fan of is the diamond plated metal but thats all personal preferance. looks good man
  3. Aug 5, 2013 at 10:02 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    looks good! Im not a diamond plate fan but it looks great
    I wanna see your corner blinker switchback reroute because thats what ill be doing here in a few :anonymous:
  4. Aug 5, 2013 at 10:07 PM
    JuansTaco
    Juan
    gilbert az
    ya me too on the corner swap.. i was thinking about using led turn signals somehow mounted to bumper
  5. Aug 5, 2013 at 10:36 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
  6. Aug 6, 2013 at 9:00 PM
    MatthewMay1
    Matthew
    '01 TRD Off-Road
    I added some photos to the OP. The bulbs were a little long for where I put them. I had to trim the inside of the lens on the ridge where the yellow insert is in the side of the corner light. It fits perfectly now. You can probably avoid this issue by putting the socket in at a different angle. Only problem is that once you cut the hole, you're pretty much stuck with it. That is why I had to trim a little. On the bright side, it is not noticeable and still looks good.
  7. Aug 7, 2013 at 12:44 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    more pics of the front end?
  8. Aug 7, 2013 at 12:46 PM
    Fester
    Fester Well-Known Member
    Roy
    Louisiana
    NOT YET
    Looks bad ass.
  9. Aug 7, 2013 at 4:20 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    Love Trail Gear, nice job on the top plating.
    Not much of a fan of the lower winged plating...looks bulky.
    That's just me... As long as you love it, it is all that matters.
  10. Aug 7, 2013 at 4:32 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Good job op :thumbsup:
  11. Aug 7, 2013 at 7:06 PM
    MatthewMay1
    Matthew
    '01 TRD Off-Road
    Just overall? Anything in particular?
  12. Aug 7, 2013 at 7:11 PM
    MatthewMay1
    Matthew
    '01 TRD Off-Road
    That was my exact mindset.
  13. Aug 7, 2013 at 7:13 PM
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
  14. Aug 8, 2013 at 5:37 AM
    MatthewMay1
    Matthew
    '01 TRD Off-Road
    Thank you!
  15. Aug 9, 2013 at 8:37 AM
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    :spy:
    Looking good
  16. Aug 10, 2013 at 10:57 PM
    MatthewMay1
    Matthew
    '01 TRD Off-Road
    Thanks man!
  17. Aug 11, 2013 at 1:45 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    A little lift & some extra steel....
    Bumper looks sweet!
  18. Aug 11, 2013 at 7:17 PM
    sk8rjess
    sk8rjess bonafide
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    nice man! idk how i feel about that side plating though, but +1 for being different!
  19. Aug 12, 2013 at 5:31 AM
    MatthewMay1
    Matthew
    '01 TRD Off-Road
    Thanks!
  20. Aug 14, 2013 at 12:26 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Same! Want a plate; specifically an Elite; but, don't want to upgrade the suspension for the extra weight; and yeah, the $$ too
    I plan on getting a TrailGear and will probably end up, at least, plating up the spaces in front too. And I happen to love diamond plate; so, thanks for these pictures. Great job!
