My tie rod is rubbing my rim!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RB87, Jan 14, 2011.
  1. Jan 14, 2011 at 7:32 AM
    RB87
    RB87 [OP] Active Member
    Ricky
    Stafford va
    05 Tacoma
    6" pro comp stage 1 lift
    I just installed a 6" pro comp suspension lift and when i drive down the road anywhere from 40 on up and i get about a 1/8 into the throtle it starts to rub anyone have any ideas as to why its doing this and a way to fix it??
  2. Jan 14, 2011 at 7:35 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    are they stock wheels? if so that is the problem. The new spindles with the Procomp lift require after market wheels due to the larger size.
  3. Jan 14, 2011 at 7:36 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    no there 17'' rims
  4. Jan 14, 2011 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    New wheels with a different offset/ backspace, or wheel spacers should stop that.
  5. Jan 14, 2011 at 7:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Then you need a smaller BS rim or spacers.
  6. Jan 14, 2011 at 7:43 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    where is a good place to find wheel spacers
  7. Jan 14, 2011 at 7:43 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    SpiderTrax.com.
  8. Jan 14, 2011 at 7:44 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    thank you
  9. Jan 14, 2011 at 7:47 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    ok dumb question do i need 4 of them
  10. Jan 14, 2011 at 7:48 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    only if you want rear to match front width.
  11. Jan 14, 2011 at 7:48 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    would that be the best way to go
  12. Jan 14, 2011 at 8:00 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    No real need to match front width with rear. Many long-travel setups end up with wider track in the front.
  13. Jan 14, 2011 at 8:02 AM
    4X42HEL
    4X42HEL Don't really understand 2WD trucks....
    Albuturkey
    Hot Wife
    The Pro-Comp kit says it requires 18" rims to 20" rims or the tie rod will rub.
    Says that in the instructions. When I called ProComp, they said it's an absolute must.
  14. Jan 14, 2011 at 8:05 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    the instructions i have say 17's
  15. Jan 14, 2011 at 8:06 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    i even called pro comp myself cause i had a couple questions they said do you have 17's or bigger
  16. Jan 14, 2011 at 8:13 AM
    4X42HEL
    Albuturkey
    Hot Wife
    You may have a different kit. But the 2007-2009 with VSC kit, states this in the instructions I am reading this as I type:
    IMPORTANT!: 18” OR LARGER WHEELS WITH 4 3/4”
    MAXIMUM BACKSPACING MUST BE USED IN CONJUNCTION
    WITH THIS LIFT KIT!
    Found at this link:
    http://www.procompusa.com/downloads/PDFs/is/57396_57396MX.pdf
    What year/model all that stuff is your ride? Also, what is the Kit number?
  17. Jan 14, 2011 at 8:16 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    ive got a 2005 without vsc
  18. Jan 14, 2011 at 8:16 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    57096
  19. Jan 14, 2011 at 8:17 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    the tie rod only rubs on the passenger side
  20. Jan 14, 2011 at 8:22 AM
    4X42HEL
    Albuturkey
    Hot Wife
    OK, then they are right, that kit states (online):
    17” OR LARGER WHEELS WITH 4.5” MAXIMUM
    WITH THIS LIFT KIT!
    But i know in the VSC kit, it does also state that in SOME cases, you still have to trim up to 1/4" off the tie rod thread and "shorten" the throw.
    Didn't read your instructions, but dollars to donuts says you are in the same boat.
    How much is it not clearing by? if its anywhere up to 1/2" you may just need to trim some of the threading off by that amount. If it's more than that, something is wrong.
    Either way, great choice on the kit, i want(ed) to do the same kit (hence I have the instructions memorized) but with gas prices, I've pretty much given up on that route.
    let me know.
