My timing belt broke.....How do I set my timing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allenayres83, Apr 27, 2017.
  1. Apr 27, 2017 at 5:36 PM
    Allenayres83
    Allenayres83 [OP] Member
    I have an 02 Tacoma with a 3.4l V6. My timing belt broke and I am trying to figure out how to get my timing right when I put the new belt on. Here is my plan: set both cams and the camshaft to the timing indicators, then put on my belt and rotate the crankshaft twice. If all the indicators are still line up then I will consider everything good. If they don't line up then I will remove the belt, set the cams back to their indicators and then rotate the crankshaft once and line it back up with it's indicator. Then rotate twice again and see if everything lines up. Is this the correct process or am I missing something?
    NICODON likes this.
  2. Apr 27, 2017 at 5:42 PM
    dochaser
    dochaser Active Member
    Andrew
    Titusville, FL
    2015 Taco TRD Offroad
  3. Apr 27, 2017 at 5:59 PM
    Allenayres83
    That's a great video and actually watched it for help while taking everything apart. But in my case with a broke belt I'm in a different situation as far as timing because I am not in time right now.
  4. Apr 27, 2017 at 6:28 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    this should help
  5. Apr 27, 2017 at 6:30 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Change the water pump, idler pulley and tensioner pulley while your there. You'll regret not doing it later
    TRDSport10 and dochaser like this.
  6. Apr 27, 2017 at 8:40 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Didn't open the PDF mechanicjon attached but just line the cam marks back up with the mark on the rear timing cover and put the crank on 0*.
    Exactly it.
    Damn right.
    TRDSport10 and cruxofthebisquit like this.
  7. Apr 27, 2017 at 9:45 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    How many miles are on your truck?
  8. Apr 27, 2017 at 10:33 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    The belt also has lines on it that help time it.
    cruiserguy likes this.
  9. Apr 28, 2017 at 8:29 AM
    Allenayres83
    My truck has 213k miles on it. And I bought a kit that has the water pump idler and tensioner.
    TRDSport10 and mechanicjon like this.
  10. Apr 28, 2017 at 8:42 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    What you described is exactly right.
    It makes no difference if the belt you buy has marks on it or not.
    cruxofthebisquit likes this.
  11. Apr 28, 2017 at 8:50 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    No it doesn't have to have marks
    But its another way to confirm your timing it correctly.
    Dalandser, cruiserguy and Dirty Pool like this.
  12. Apr 28, 2017 at 9:01 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The belt lines help account for a new belt "seating", same reasoning behind accessory belts having two tension specs. One for new and one for used, used being in use for 5 minutes or more. Pay special attention to the vid starting at 8:53 if you want the job done correctly.
  13. Apr 28, 2017 at 10:11 AM
    Corvette Guy
    Corvette Guy Member
    Northern California
    2000 Tacoma 5 speed 4X4 V6 TRD
    I agree with the above with one caveat. Make certain your #1 piston is at top dead center on compression. Just because your crank pulley is on the timing mark DOES NOT MEAN the engine pistons are in the correct position. Not to be a naysayer, but are you certain that broken belt did not cause any engine damage?
  14. Apr 28, 2017 at 11:18 AM
    Corvette Guy
    Corvette Guy Member
    Northern California
    Cancel what I just said. The belt broke thus the piston position will be correct with the timing mark on "0" period. I wasn't thinking.
  15. Apr 28, 2017 at 11:23 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I was just getting ready to ask that....
    :rofl::argue::boink::drunk:
  16. Apr 28, 2017 at 12:15 PM
    Allenayres83
    I'm putting the water pump on now. The old water pump had a groove all the way around the pump but the new one I got doesn't. The gasket I got is just a regular paper gasket ( not rubber or metal). Do I need to put some rtv sealant on this or not?
  17. Apr 28, 2017 at 12:20 PM
    Glamisman
    Glamisman Well-Known Member
    as a friendly reminder... the jiggle valve on the thermosat goes on the bottom... in a previous post of mine I noted that mine was installed incorrectly but TW member point out where I was wrong, live and learn.
  18. Apr 28, 2017 at 12:29 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    AND remember after you're through and spinning everything around checking marks and worrying (just kidding, I know you just want it right) the painted marks on the belt are NOT going to line up again.....they would eventually.....but not for many revolutions.
    After that first roll over you're only going off of the timing marks of crank/block and cam dots.
    That made my head hurt the first time I used a belt with marks built in. It's only for showing how many cogs apart each component is when correct.
    mechanicjon likes this.
  19. Apr 28, 2017 at 12:41 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    From factory the valve comes on the TOP.
  20. Apr 28, 2017 at 12:47 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    bottom
    crakumskull likes this.
