My tires have expired
Discussion in 'Wheels & Tires' started by greyeyezz, May 19, 2023.
  1. May 19, 2023 at 4:06 PM
    greyeyezz
    greyeyezz [OP] Well-Known Member
    Make a long story short got the Michelins in 2012, inherited a 25 mpg car in 2016 and mainly drove that for economic reasons. Tacoma was driven occasionally like trips to my place one state over and around town.
    Time rolls by fast, I never would have considered replacing these just looking at them, 6/32 tread 36K but I just realized they're ten years old.
    Think I could hold out a year or two or should I be safe?
    [​IMG]P1000837
    [​IMG]P1000833
    davidstacoma likes this.
  2. May 19, 2023 at 4:09 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    No - change them immediately. After 6-7yrs the rubber deteriorates rapidly regardless of tread condition
    it’s just not worth the risk
    AR15xAR10 and TacomaUSA like this.
  3. May 19, 2023 at 4:09 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    Could you around town, yea...should you is a different answer (no) since those obviously have quite a bit of cracking and definitely a hard pass for me one state over, assuming highways, etc.
    I have a vehicle a barely drive with Michelin PSS that are 9 years old and 50% tread, no cracking..i decided to remove them 2 weeks ago since i didn't want to deal with a failure on the road.
    doublethebass likes this.
  4. May 19, 2023 at 4:22 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    My tire dealer told me this is pure bull shit . When this first came out.
    Just a market ploy to sell more tires.
    michelin sidewalls have always cracked like that.
    Go by the overall condition of the tires . Yes being exposed to the sun is hard on the tires.
    I have brand new tires I bought in the eighties.
    your call do what you think is right.
    Rusty66 likes this.
  5. May 19, 2023 at 4:32 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Any signs of cracking due to age?
    If not drive like you stole it. The compound doesn’t suddenly melt when it hits an expiration date. It’s aging that matters and you can see it.
    Update: I zoomed in on the last pic and see the cracks. I would replace fairly soon but no need to panic.
  6. May 19, 2023 at 4:35 PM
    Bishop84
    Bishop84 Well-Known Member
    Cracking on the tread edge or tread surface is a much higher concern.
    I'd say another year easily on those tires. I usually like to have more than 5-6/32nd on any truck tire anyway.
    TnShooter likes this.
  7. May 19, 2023 at 4:39 PM
    davidstacoma
    David
    NC
    Side wall cracking is significantly more dangerous than losing tread. Ever have a sidewall blowout?
  8. May 19, 2023 at 4:47 PM
    MGMDesertTaco
    Definitely replace. 5-6 years is the max irregardless of mileage. Michelin/BFG are known for using very soft rubber compounds.
  9. May 19, 2023 at 4:48 PM
    MGMDesertTaco
    They look like may-pops to me. :rofl:
  10. May 19, 2023 at 5:29 PM
    greyeyezz
    Now that I think of it those tiny cracks have been there quite some time. There is zero cracks anywhere above one inch from the rim.
  11. May 23, 2023 at 9:14 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    The deterioration is cased by both sunlight and ozone. If you lived in Los Angeles and parked outside, your tires age faster than if you live in a rural area and park indoors.
    The calendar age is a useful indicator, but a visual inspection is important. If you are seeing lots of cracks, time for new tires.
  12. May 24, 2023 at 11:16 AM
    greyeyezz
    Well I just bit the bullet, 4 Cooper Discoverer AT3 4S 265/65R17. Question, what pressure do you run at, door says 29 but I find that rather mushy. Ran my Michelins @ 34-35 and that worked out well for twelve years.
  13. May 24, 2023 at 11:31 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I run 32 in front and 34 in rear.
    I have 265/70/16 tires.
    I tow frequently, if you don’t tow often maybe try 32 psi.
    To be honest, I have 35 psi in all of them now. But that’s because I have life time rotation on my tires. I told the tires shop to just do 34 all around to make it easy in them. My gauge says 35 on a cold tire.
    So……that’s what I left it at.
  14. May 26, 2023 at 6:55 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Look like regular old Michelins' to me:notsure:
  15. May 31, 2023 at 1:09 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I’m not usually a fear-monger but I would be hesitant to run those tires with those cracks. Not because of the age, but because of the cracks.
  16. May 31, 2023 at 2:45 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Those tires are on their way out with the sidewall cracking and this is coming from a guy that just replaced 30 year old [original tires] on his 93 vehicle. They were also totally unchecked [cracked] anywhere, sidewall or in the tread area. Car spent it's life in garages if not being driven. New rubber [10 years old is new compounding] will never go that long, they removed some of the more expensive materials [carbon black] that made them last longer because they now don't care about longevity since the government gave them a 6 year and a free pass due to age out.
    I would have had no issues driving the 30 year old tires on my ride across country, those tires I would have an issue with doing the same thing.
  17. May 31, 2023 at 5:57 PM
    greyeyezz
    I had to run out to my property in PA so didn't have time for a proper photo op. lol
    Not enough mud to give a real traction assessment but on dry hills they are fine. They sure ride nice and 17.5 mpg on 70% freeway driving. And I lost a hubcap. And I need new rims.
    Discount Tire and 3JOH22A like this.
  18. May 31, 2023 at 6:00 PM
    Bishop84
    I had at34s's they were really impressive for the price. Ultimately they couldnt handle the abuse I gave them (daily gravel roads), but for a daily driver and limited offroad they are an amazing choice.
  19. May 31, 2023 at 6:07 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Iirc Michelin has one of the higher recommendations at 10 years for replacement and you’re at ~11. It’s time.
  20. May 31, 2023 at 8:11 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    What’d you go with for the abuse?
