My Transmission Feels Terrible
Discussion in '1st Gen. Tacomas (1995-2004)' started by CarlosinFL, May 14, 2013.
  1. May 14, 2013 at 11:12 AM
    CarlosinFL
    CarlosinFL [OP] Mildly-Attractive
    Carlos
    Orlando, FL
    02 PreRunner SR5
    My 2002 Tacoma single cab truck for some time now has had a weird jolting when you give it some gas on the highway. It's gotten way worse in the past month and now I have a check engine light showing on my instrument gauges. I really notice my MPG is totally hideous and when I give my truck gas from a stop or if I need to get some torque, it's very very laggy and jumpy.
    Does anyone know what could be causing this based on my description above? I have not taken the truck in yet to have the CEL code read but in my experience, they're generally very generic anyways. Anyone know or have any suggestions?
    I'm just over 150.5K miles on everything.
  2. May 14, 2013 at 12:01 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    nope, get the code. that is the starting point
  3. May 14, 2013 at 12:05 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    torque converter? ^x2 though.
  4. May 14, 2013 at 2:04 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    with no code, may as well ask this:
    (this is the cheapest, easiest, and very likely solvable problem that can cause the
    described symptoms)
    when is the last time you got a can of maf cleaner
    and blasted the maf sparkling clean, reset ecu, and put maf back in ?
    anyhow, your truck blew a code and despite your experiences, all OBDII codes matter a LOT
