My truck and all its problems....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Feb 17, 2010.
  1. Feb 17, 2010 at 2:12 PM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    I bought my truck in Dec. 2007 with 27K miles on it. I am the third owner, the second owner bought my truck as a certified pre-owned and then sold it it a few months later.
    As of late my truck just seems to be full of weird noises and issues and I'm quite honestly getting pretty damn fed up. Thinking about just trading it for another Tacoma. I'm taking it to Toyota this weekend (had to secure a car to take me to work before this) and I'm gonna have them check it out.
    These are the problems I'm having:
    • Rattle/Grind noise when cruising/decelerating. This is my newest noise and just started today after my truck was parked for 3 hours at school. It's coming from the front right wheel well and it's pretty damn loud.
    • The loud squeel/squeek I posted in video earlier this month. It went away for a week or two, but now it's back yet slightyl different
      • goes away with no pressure on gas pedal
      • doesn't make sound when rev'd in park or neutral
      • usually makes this sound from 1200-1800RPM
      • above 25mph
      • doesn't always do it, however I can't find any circumstances to force it to make the noise
      • can be barely audible to extremely loud, with no reason I can figure to cause it
    • vibration from 10-20MPH
    • Occasionally I hear a thud when letting off the gas when going under roughly 40MPH
    Those are the things I can't explain. I know it needs an alignment and regular service, but these other things I simply just think WTF. It of course has other odd rattles in the interior but I've attributed that to the mass of random crap that has accumulated in my backseat.
    I'm not interested in starting a bash on Toyota thread. I've grown up with Toyota's and even if I got rid of this truck, I'd probably end up buying another Tacoma or a Tundra. I'm hoping someone has an idea as to WTF is going on with my truck. I don't have a place to work on it, nor do I have the tools or general knowledge to try and fix it myself.
  2. Feb 17, 2010 at 2:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Alex....sounds like you got bad wheel bearing up front......and maybe the torque converter isnt working properly.
    anyway.........since you've brought it up before.......get rid of it....trade it for another tacoma.
  3. Feb 17, 2010 at 2:26 PM
    Khaos
    Bryant
    Nostalgia and taxes keep me from wanting to get rid of it. If I can get my truck fixed up and running how I think it should, I want to keep it. I love the truck but sometimes I get frustrated with it.
  4. Feb 17, 2010 at 2:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it can be fixed........its just a matter of them finding out what the hell it is. everything is frustrating once in a while. im frustrated with my truck for now myself........but it'll get squared away and be good to go.
  5. Feb 17, 2010 at 2:49 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Check your U-joints - driveshaft thats what you would get with U-joint or driveshaft slip Its TRD truck so expect somebody went mudding with it
    Not a big deal needs grease or new ujoint. :D
  6. Feb 17, 2010 at 2:53 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
    What problems ? Seems to me you just have one, a bad u-joint. Should be an easy fix. Also check your rear transmission seal, the PreRunner's tend to leak but there is a TSB. The PreRunner's u-joints cannot be greased, they are sealed so replacement is the only option. I replaced my front u-joint at 50k miles. Good Luck and hope everything works out.
  7. Feb 17, 2010 at 3:05 PM
    BlueT
    NorthEast
    Yep U-joints are like hot girl... both needs to be greased often and with plenty :D
  8. Feb 17, 2010 at 3:10 PM
    Asgard
    BTW the u-joint can fail and your driveshaft will end up on the pavement, so get it fixed ASAP. Sounds to me like you've been driving around with a bad u-joint for quite some time.
  9. Feb 17, 2010 at 3:17 PM
    Khaos
    Bryant
    It's been making that sound on and off for roughly 800 miles. If its really just the U joint then thats damn good news.
  10. Feb 17, 2010 at 3:21 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    x2 on the wheel bearing, oh, and umm...
    Maybe take better care of her, and she'll take better care of you :p
  11. Feb 17, 2010 at 3:31 PM
    Khaos
    Bryant
    The sad thing is, I haven't even taken it off road in maybe a year.
    Towing package was done by previous owner, dented bedside by a less than careless driver at Walmart (found more scrapes today on the opposite side, guessing someone scarped into me when I was at work last night), and the hood and whatnot happened somehow when my truck was parked at Jax beach for the 4th of July. This trucks luck is pretty rough.
  12. Feb 17, 2010 at 3:41 PM
    BlueT
    NorthEast
    When was the last time you greased u-joints ?
    EDIT: One of them may be u-joint other could be wheel bearing (two separate issues)
  13. Feb 17, 2010 at 4:28 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Its a Pre Runner - as stated above, the u joints don't have zerks for greasing. Only 4x4 Tacomas have zerks.
  14. Feb 17, 2010 at 5:37 PM
    Khaos
    Bryant
    Just drove it again to Walmart (needed razors and food), sounds where half as loud as they where on the way home from class. it's a surprise everytime I drive the truck!
  15. Feb 17, 2010 at 6:01 PM
    cjh
    cjh Well-Known Member
    10 doublecab
    Have no idea if this is relavent, but on my old 01 I had a squeaking noise that was intermittant. Would come and go with no reason at all. Ended up being the slip yoke on the rear drive shaft needed grease. After a liberal amount of grease, no more squeaking. Not sure if this helps, but worth a shot. Just re-read your post and saw you said it is coming from front end. I guess that would rule out the rear drive shaft. Sorry.
  16. Feb 25, 2010 at 10:34 AM
    Khaos
    Bryant
    Well guys, dropped the truck off at 11:45 @ Toyota this morning.
    Within an hour my service adviser (worked with for years, with 3 different vehicles, I know he's a good guy), he called back about 20 minutes ago and said that all three of my U Joints are trashed. They're saying its from my tire size.
  17. Feb 25, 2010 at 10:36 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
  18. Feb 25, 2010 at 10:46 AM
    BlueT
    NorthEast
    No way in hell, asked them if they can replace them with ones that have grease zerks so you can lube them
  19. Feb 25, 2010 at 2:30 PM
    Khaos
    Bryant
    Well, my truck has gotten its 60K service, new U Joints and they say the rattle I was hearing as a loose intake bolt, which was something I had suspected. That's all they found wrong with the truck...
    Waiting for my Dad to get off work so I can hitch a ride up to Toyota and pick the Taco up...
    A day without my Taco sucked.
  20. Feb 25, 2010 at 5:20 PM
    Khaos
    Bryant
    Got the truck back.... Fucking happy as all hell right now. Not only is it running perfectly, its clean.
    Also may be getting a job @ Toyota.... :D
