MY TRUCK BED LOOKS OUT OF ALIGNMENT, HELP!!
Discussion in 'Suspension' started by Taco227, May 17, 2012.
  1. May 17, 2012 at 5:55 PM
    Taco227
    Taco227 [OP] Well-Known Member
    Maryland
    TRD Sport
    3" Pro Comp suspension kit, 1.25" front wheel spacers, tinted clearance lights, 4 pioneer speakers, Sony head unit, Custom Sub enclosure with 10" MTX, dash kit, wicked flow exhaust, Firestone Airbags.
    Hey everybody,
    Ever since I installed an AAL on my truck, the truck bed looks out of align. The measurements taken from the cab to the bed is different on both sides of the truck. Also, I have about 2 inches less lift on the left side of the truck than on the right measuring from the ground to the inside wheel well. My truck pulls to the right a little bit. No vibration on the steering wheel. Tires are wearing evenly. Any suggestions? The dealership said all of the tacomas have a driver side lean. That sounds ridiculous...why would Toyota sell a truck with a driver side lean? Anyway, does any one else have this problem and what did you do to fix it?
    I am about to just take the aal out and inspect the springs. The rear leaves are about shot in this truck. Please help!
  2. May 17, 2012 at 5:57 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Loosen the bed bolts and you can slide it around! Be careful nt to strip the trox bits cause mine where rusted in! Think its #55!
  3. May 17, 2012 at 5:59 PM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    As for the bed you should be able to loosen the bolt in the bed and shift it a hair. I don't think you can move it much but it might be enough to fix the bed. As for the other stuff hopefully someone else will chime in.
  4. May 17, 2012 at 6:00 PM
    Blueanimal
    06 Prerunner Sport
    Nvm. I got beat to the punch.
  5. May 17, 2012 at 6:02 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Welcome to the Tacoma Lean.
    +1 to the dealer for actually knowing his stuff.
    the lean is because all heavy items are on the driver side - gas tank, battery, primary occupant... plus the rear springs are historically weak.
  6. May 17, 2012 at 6:04 PM
    DrewH
    DrewH Well-Known Member
    A 2 inch difference isn't right... are your add-a-leafs the same?
  7. May 17, 2012 at 6:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Welcome
    Toyota springs = crap
  8. May 17, 2012 at 6:05 PM
    OZ-T
    Peter North
    British Columbia
    True dat
  9. May 17, 2012 at 6:09 PM
    Taco227
    Maryland
    TRD Sport
    yea the springs suck! I was hauling 2 yards of mulch the other day and I was very close to the bump stops. As for moving the bed around...I don't think that would fix the ride height difference? And yes the add a leafs are the same. Should I go ahead and take them apart? My dad was driving behind me the other day and said it looks like my truck was doggy walking to the right a little... It's very noticeable when looking at the back of the truck.
  10. May 17, 2012 at 6:11 PM
    OZ-T
    Peter North
    British Columbia
    Have you checked to make sure you don't have a broken leaf on the low side ?
  11. May 17, 2012 at 6:12 PM
    DrewH
    There is definitely something not right..... ever in an accident? Take some pics of both sides if you can.
  12. May 17, 2012 at 6:15 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ya, broken leaf or you def need a new leaf pack! Moving the bed helped me with about 3/4" forward as I was rubbing at full stuff but it worked!
    You def have a bigger issue going on though!
  13. May 17, 2012 at 6:16 PM
    Taco227
    Maryland
    TRD Sport
    The leaf doesn't look broken. I can post more pics tomorrow when I have some light. Truck has never been in an accident. I feel like its been like this since the lift has been installed.
  14. May 17, 2012 at 6:18 PM
    Taco227
    Maryland
    TRD Sport
    Now that I think about it....having a broken leaf could be the problem. I have no noises coming from the springs though. Hang on...I'm going outside to check. :/
  15. May 17, 2012 at 6:18 PM
    DrewH
    It's just the rear, right?
  16. May 17, 2012 at 6:19 PM
    Taco227
    Maryland
    TRD Sport
    Yea, just the rear left is lower than the right.
  17. May 17, 2012 at 6:19 PM
    jandrews
    '09 FourDubDee TRD OR
    Beds on these trucks have a tolerance. Them being off some from side to side isn't uncommon.
  18. May 17, 2012 at 6:20 PM
    OZ-T
    Peter North
    British Columbia
    The leaf can be broken between the U bolts , so it is hard to see
  19. May 17, 2012 at 6:29 PM
    Taco227
    Maryland
    TRD Sport
    Leafs aren't broken. I have looked at each side about 50 times trying to compare them haha
  20. May 17, 2012 at 6:30 PM
    OZ-T
    Peter North
    British Columbia
    What do you have up front for lift ?
