My truck feels loose while driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jameyh, Feb 15, 2014.
  1. Feb 15, 2014 at 10:51 PM
    Jameyh
    Jameyh [OP] New Member
    Tupelo Ms
    02 PreRunner TRD
    Hi guys, I recently bought a 2002 prerunner and when I'm driving, it likes to wander all over the road. This is my 3rd tacoma and the other 2 felt real tight in the steering wheel almost like a jeep. I bought it cheap to be a beater that I could drive back and fourth to work, but it has turned into a really solid truck. It has 225k on it so what should I replace in the front end? Thanks for any help
    Ps: sorry if this is in the wrong place. I'm new to the forum and haven't figured it out yet
  2. Feb 15, 2014 at 10:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Many things can contribute to this feel.
    More info besides mileage will help to identify potential trouble spots. Got a lift? Type? Stock or oversized tires?
    A quality alignment shop can tell you a lot about your front suspesion.
  3. Feb 15, 2014 at 11:03 PM
    Jameyh
    Tupelo Ms
    02 PreRunner TRD
    Thank you. No it's completely stock but it was a teenagers first truck and he was rough on it. It need tlc when I bought it
  4. Feb 15, 2014 at 11:05 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Easiest is to check the alignment.
    If the caster is off, it will wander.
    Next step (and they'll likely look for this when you have the alignment done) is to look for worn parts... control arm bushings, ball joints, wheel bearings, tie rods, steering rack....
  5. Feb 15, 2014 at 11:14 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Check ball joints, tie rods, steering rack, steering rack bushings.
    The rack bushings are cheap and simple to do in your driveway.... while you're at it, lift the front up til the tires are off the ground and attempt to 'steer' the tire manually back and forth and see if the inner ends of the tie rods deflect up/down to see if the rack is still good or if the outer end deflect then replace the rod ends. You'll also be able to see if the ball joints at the top or bottom of the spindle have play.
  6. Feb 15, 2014 at 11:14 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    check your tire pressure, mine wanders a little if my pressure is too low at freeway speeds.
  7. Feb 15, 2014 at 11:23 PM
    Jameyh
    Tupelo Ms
    02 PreRunner TRD
    Thank you guys very much. I'm going to check it out soon
