My truck has died.
Discussion in '1st Gen. Tacomas (1995-2004)' started by KevinButler35, Apr 21, 2014.
  1. Apr 21, 2014 at 8:16 PM
    KevinButler35
    KevinButler35 [OP] Active Member
    Charlotte NC
    1998 Single Cab Tacoma
    2.5'' Bilstein 5100 Lift Kit Limited 4runner seats
    So. My 2.7 L (1998 280K) has been acting up in the past few days. I was driving it one day and the truck just shut off. Before that incident i replaced the EFI relay on the fuse panel in the engine bay. When the truck died i immediately popped the hood and tried swapping those relays and that did nothing.
    After my friend pulled me home, i popped the hood this time and tested the contacts on the fuse panel and everything was good. I was receiving power from both contacts on the EFI relay. So this time i jumped the contacts with a small piece of wire and the truck started.
    HOWEVER, it will not stay running and i now have four trouble codes. (P0100 P0110 P1300 P1310).
    I am wondering what my next plan of attack is. I would like as most help as possible to try and solve this problem.
  2. Apr 21, 2014 at 8:23 PM
    KevinButler35
    Charlotte NC
  3. Apr 22, 2014 at 5:15 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    hope someone helps you
  4. Apr 22, 2014 at 5:22 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    fuel pump maybe
  5. Apr 22, 2014 at 6:32 PM
    Archer550
    Archer550 Well-Known Member
    Winnipeg
    04 xtracab TRD MT
    ARB for now
    I'll do my good deed for the day!
    I looked up all the codes for you in my FSM
    Before you jumped the terminals on the EFI relay socket did you have any codes or CEL?
    P0100: Mass air flow meter; (open or short is MAF circuit, MAF meter or ECM)
    P0110: Intake Air Temperature circuit; (open or short in IAT sensor circuit, IAT sensor built into MAF or ECM)
    P1300: Ignitor Circuit malfunction no. 1: (Ignition Coil No. 1 harness is open or shorted, Ignition Coil No. 1 circuit poor electrical connection, Faulty Ignition Coil No. 1, ECM)
    P1310: Ignitor Circuit malfunction no. 3: (Ignition Coil No. 3 harness is open or shorted, Ignition Coil No. 3 circuit poor electrical connection, Faulty Ignition Coil No. 3, ECM)
    Do you want the procedure for checking you coils? I can provide those if you want.
    Also check/clean your MAF its easy and could be some of the issue.
    Unfourtuneatly it sounds like this might all be culminating at the ECM though.
  6. Apr 23, 2014 at 9:33 AM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Theres a guy on youtube who has been a mechanic for 46 years. He's always answering people's questions. I would suggest messaging him on there or leaving a comment on one of his videos similar to your issue. His name is Scotty Kilmer. Really helpful guy
  7. Apr 23, 2014 at 1:32 PM
    KevinButler35
    Charlotte NC
    There is gas in the tank. filled it up about a week ago. There were no codes before this happened. The truck may have 280k but it runs like a champ. I also changed the fuel filter about a month or so ago.
    I would love to know how to check the Coils.
    I was thinking it was the ECM to, i just wanted to rule out any other possibilities.
    Thank you all for helping!
  8. Apr 23, 2014 at 2:18 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Is there a common connector in the harness that these things run through? I would at least trace the harness and clean up any connectors. Odd to have that many codes at once unless the ECM is wacky. I would reset all the codes and try it again, but I am leaning toward a bad connection somewhere or the ECM itself.
  9. Apr 23, 2014 at 8:48 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    You can access ecm easily. Just take glove box out and upper plastic. You can see and access all plugs in ecm. It's up to the left a bit. Can't miss it.
  10. Apr 29, 2014 at 5:58 PM
    KevinButler35
    Charlotte NC
    I have bought a new ECM and replaced the original one. That didn't solve the problem I was having... Still the sane issues.
    Now I'm thinking it's a bad relay. I have replaced the EFI relay under the hood.
    I found this relay under the dash (picture below)... Could this be the problem?
  11. Apr 29, 2014 at 6:03 PM
    KevinButler35
    Charlotte NC
    Here is the picture
  12. Apr 29, 2014 at 6:34 PM
    KevinButler35
    Charlotte NC
    The relay pictured is the Circuit Opening Relay.
  13. Apr 30, 2014 at 12:16 PM
    KevinButler35
    Charlotte NC
  14. Apr 30, 2014 at 1:41 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    maybe a bad ground somewheres?
  15. Apr 30, 2014 at 1:49 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Was thinking the same thing. Sounds like a electrical issue. Check all the wiring in engine bay.
  16. Apr 30, 2014 at 3:20 PM
    Andy.G
    Andy
    Virginia
    Under hood fuse box? I bypassed circuit opening relay. Power to fuel pump full time. You hear fuel pump as soon as you turn key. Starts but idles high. I bent a piece of copper wire into u shape to fuel pump circuit plug.
  17. May 31, 2017 at 5:39 PM
    moosebaker
    moosebaker New Member
    Michael
    1990 Toyota PU with a 3.4
    What happened with this? I have similar codes with a 3.4L and wont start really, hard backfire.
