My truck IS "bogging" down.. (Horrible power loss & MPG's)
Discussion in 'Performance and Tuning' started by RJALLDAY702, May 14, 2013.
  1. May 14, 2013 at 12:43 PM
    RJALLDAY702
    RJALLDAY702 [OP] U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Hey guys, I come to you in total confusion..
    About a year ago I noticed an extreme drop in my trucks power/tourue as well as an extreme drop in MPGs.. The weird thing is.. it only happens a couple times in a day. When I notice it happining (Need to pass someone, so it get OTG and the power is just not there.) Ill shift my truck into neutral and rev it to find that at about 2k RPMS my truck bog's itself really bad & very noticeably (for about 2 or 3 (sometimes 4) revs).. After I let it roll in neutral for a bit I rev it again and it rev's normal..
    And as said before my truck seems to be getting shit gas mileage (worse than what normally would be for the 35s)
    Any thoughts or ideas? Please share.
  2. May 14, 2013 at 12:47 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Any codes thrown? MAF sensor clean? Throttle body clean? Crap in the fuel maybe (probably not if it's been happening for a year)?
  3. May 14, 2013 at 12:48 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    First off, any mods that you have done "performance-wise" shortly before you started noticing the issue aka any splicing int ot eh stock harness? How many miles on the truck? When's the last time you replaced your spark plugs?
    The things coming to mind for me are fuel filter clogged, bad ECU connections, throttle body not functioning properly, bad MAF, spark plugs... Hmm I need more info.
  4. May 14, 2013 at 12:49 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Just did the MAF a few days ago.. Same problem. Going to get to the throttle body at the end of the day. Spark plugs were done 6k ago. What do you mean by wires?
    EDIT:
    No related codes, I am having trouble with my Charcoal canister.
    The only thing I can think of is exhaust. Flowmaster Super 40. Going to be replacing that soon to see if thats the culprit. My truck has roughly 67k.
    Can a bad charcoal canister do something like this?
  5. May 14, 2013 at 12:50 PM
    memario1214
    Colton
    Missoula, MT
    Wires going to the shock plug thingies... Doesn't seem to be as much of an issue on newer vehicles, but there might be a poor connection somewhere.
  6. May 14, 2013 at 12:51 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    what mpg are you getting? I get 13ish on 33s
  7. May 14, 2013 at 12:54 PM
    stroked383z
    stroked383z Well-Known Member
    2012 Spruce Mica DC SR5 TRD Offroad
    Fuel filter, cat converter clogging up?
  8. May 14, 2013 at 12:57 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Right, So check all wires and where they connect to. Will do.
    The charcoal canister is going bad. How can I narrow it down to my cats?
  9. May 14, 2013 at 1:01 PM
    memario1214
    Colton
    Missoula, MT
    Yeah, new ignition coils are less susceptible to damage and wear over old ones as everything is less open to the elements.
  10. May 14, 2013 at 1:08 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Smells like coil issue, and not from the wiring harness supplying the juice.
  11. May 14, 2013 at 1:12 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    What brings you to this conclusion?
  12. May 14, 2013 at 1:17 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    I just lol'd
    +1
  13. May 14, 2013 at 1:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Seems to me something similar to what Nofords was just dealing with.
    Clean your throttle body thoroughly. Including opening the butterfly and cleaning the backside.
    Next, how many miles does your truck have?
  14. May 14, 2013 at 1:36 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    lol at charcoal canister too...........
  15. May 14, 2013 at 1:38 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    If none of these things fix your problem one thing that it might also be is your catalytic converter starting to go bad if your mileage is starting to get up there.. Usually when they do you start to feel a major power difference like it is getting clogged or even notice a rattle in them sometimes.
  16. May 14, 2013 at 1:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    On second thought, it's your 6" spacer lift. You should probably take that off. o_O
  17. May 14, 2013 at 1:45 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Roger that. Will do, Im not to familiar with the butterfly valve.. any tips?
    Oh by the way. I meant no offence. I am just trying to learn about this stuff, just wanted to know where your mind was going with that one
    i have 67k on my truck. Nope start up sounds very normal.
    But thats how I get all the bro hoez :pout:
  18. May 14, 2013 at 2:02 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  19. May 14, 2013 at 2:06 PM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    Due do the intermittent nature of your problem, I would not suspect the converter is clogged unless if you smack it with your fist it rattles badly the catalyst inside could be loose, very unlikely. Did you replace the MAF sensor or just clean it? You stated you have replaced plug wires a while ago, did you use good parts or the cheap Autozone red ones? What is the issue with the charcoal canister?
  20. May 14, 2013 at 2:08 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Clean TB/MAF/Air filter.
    If that doesn't work....
    Seafoam.
    Change spark plugs or at least re-gap all of them.
    If all else doesn't work....
    Take off the catalytic converter for a day and see if it may be clogged.
    If all that fails start taking offers on the truck.
