My truck IS "bogging" down.. (Horrible power loss & MPG's)
Discussion in 'Performance and Tuning' started by RJALLDAY702, May 14, 2013.
  1. May 14, 2013 at 2:10 PM
    RJALLDAY702
    RJALLDAY702 [OP] U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Right, Ill be sure to give it a good :smack: when I get off work
    I just cleaned it, thoroughly. How can I tell if its gone bad?
    I used 100% toyota spark plugs.
    Im getting a code thrown on my truck that the charcoal canister is going bad, or is already bad.
    Seafoam was my next idea, Im going to check the exhaust system as well
  2. May 14, 2013 at 2:51 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Have had intermittent boggin when coil on plug coil was starting to go bad without it throwing CEL or misfire codes on a car I had before. And the only time I had a cat be clogged enough to cause the vehicle to bog it was glowing red and was not intermittent. Good luck with it.
  3. May 14, 2013 at 2:54 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I've been fighting mine for years, next is replacing fuel filter/pump with a walbro one from URd
  4. May 14, 2013 at 3:07 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Got it! Ill do more research on that one.
    let me know how it goes!
    Does this sound like the same thing you are experiencing?
  5. May 14, 2013 at 3:17 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Check coil, wires, then your cat. Converter.
    Take 02 sensor off before cat, and take for drive.
    See how your power is then.
  6. May 14, 2013 at 3:20 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    What exactly should I be looking for when I check the Coils?
  7. May 14, 2013 at 4:30 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i doubt its the charcoal cannister....mines toast and i get the codes too...but i dont have any bogging
  8. May 14, 2013 at 7:10 PM
    Mad Man Marty
    Marty
    PA
    Go to youtube,type how to check coil on plug. Pick the videos by realfixesrealfast. He does a great job of showing u what u need.
    If there is still a problem check your cat. When they break up or start to clog, it will give all of the symtoms u have. One last thing, at no point are u throwing bad codes? Check engine light? Keep us informed. Good luck.
    QUOTE=RJALLDAY702;6888391]What exactly should I be looking for when I check the Coils?[/QUOTE]
    Check the charcoal canistor vent tube, and filter.
    Do a search in TW for charcoal canistor. Read all threads
  9. May 15, 2013 at 3:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I forgot to mention this earlier, but after you clean the throttle body, disconnect the battery for a good 10 minutes. That way you reset the learned parameters in the ecu.
    Un-bolt the TB and you can thoroughly get to both sides of the butterfly, flap, TB valve, or whichever you would prefer to call it. Lol.
    Unless the charcoal canister is cracked (you would know best) it could be a vacuum leak or connector causing it issue.
    A clogged fuel filter can assist in bogging, but not near as bad as clogged cats. At the same time, if the ecu cannot go through all of its warm up cycles due to say a really dirty TB, that can have serious side effects as well.
  10. May 15, 2013 at 7:06 AM
    anthony250f
    Anthony
    San Diego, CA
    To bad you cant get the cannister without lifting the bed or dropping the tank
  11. May 30, 2013 at 5:06 PM
    Mad Man Marty
    Marty
    PA
  12. Dec 14, 2013 at 9:09 AM
    OlDirtyTaco
    OlDirtyTaco Active Member
    Wilmington, NC
    2011 Tacoma PreRunner v6 Access cab
    Im having similar issues - started all of a sudden last night. Serious bogging, can't go more than 25 MPH, misfiring, glowing red cat. Cleaned my MAF really well this morning - did nothing. What's next? After reading this, I will go clean my TB, air filter housing etc. Should I take out the o2 sensor and run it? Should I drop the cat and run it? Thanks for all the great info so far - any help would be greatly appreciated.
  13. Dec 14, 2013 at 11:39 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I know this might sound simplistic...
    ...but check for a vacuum leak. Bogging down and hot cat are indications of an intake air leak, like a hose to the intake manifold that's disconnected or cracked.
    Don't ask me how I know... :rolleyes:
    Greg
  14. Dec 14, 2013 at 12:11 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Check your cabin filter for marijuana residue buildup...
  15. Dec 14, 2013 at 11:54 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How many miles are on your truck?
    What Tooter said is very possible as well.
  16. Dec 15, 2013 at 4:47 AM
    #36
    stroked383z
    stroked383z Well-Known Member
    2012 Spruce Mica DC SR5 TRD Offroad
    A glowing red cat is probably the cat clogged up. Are all the cats glowing, or just one?
  17. Dec 15, 2013 at 8:34 AM
    #37
    OlDirtyTaco
    Wilmington, NC
    Thanks for the replies guys. The truck is just getting broken in at 212K. Emphasis on broken....
    Not sure what you mean by "all the cats" - I just looked underneath and the whole cat looked like a nuclear waste site. Will check for vacuum leak as well.
    Also, I am by no means a mechanic, so when someone says it's running lean, how do I adjust this?
  18. Dec 19, 2013 at 11:54 AM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you changed you fuel filter, and if so how long ago?
    Have you run Redline's fuel system cleaner. Redline's, not others.
    When is the last time you have had your injectors cleaned?
  19. Dec 19, 2013 at 12:20 PM
    #39
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    13 4x4 DCLB tacoma V6 TRD Sport
    5100 Bilstiens set at 1.75, progressive leaf pack, BFGs, All-Pro rear Bumper(white), Storm troopered out
    Same thing happened to my 05, I put an aftermarket Cat. on it and it helped alot, still havent got it fixed, new spark plugs fuel system cleaner, nothing seems to fix it. im thinking it needs to be rebuilt completely (get the grime out). Good luck fixing it up.
  20. Oct 27, 2018 at 11:44 AM
    #40
    Ryan1620
    Ryan1620 New Member
    ryan
    2015 Tacoma TRD sport
    Hey super old thread but im legit having this same exact issue on my truck. 70,000 miles, just installed a magna-flow exhaust, plugs done 3k ago, MAF cleaned last serviced same with EFI. Any tips or ideas ?
