My truck is crooked?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sherlock18, Oct 9, 2021.
  1. Oct 12, 2021 at 12:50 PM
    jeminyned
    jeminyned Well-Known Member
    Jerry
    2013 4 Dr Black Tacoma TRD Offroad
    Seat Covers and just getting started!
    Oooh...ok, now I know what y'all are talking about! Thanks for clearing that up for me!:thumbsup:
  2. Oct 12, 2021 at 12:51 PM
    eon_blue
    Azusa, CA
    A bent axle shaft inside the rear axle would cause all kinds of nasty vibrations when driving down the road, you would definitely feel that.
    If the rear axle isn't sitting on the spring perch correctly on one side (the leaf spring center pin should be in the hole on the perch) then it would cause the whole axle to be sitting askew. That would be my first thing to check. Otherwise you might have a tweaked frame, hopefully not. But if its not too bad a frame shop would know how to fix it.
    SR-71A and jeminyned like this.
  3. Oct 12, 2021 at 12:51 PM
    eon_blue
    Azusa, CA
    There is no alignment to be done on the rear axle, only the front end
    jeminyned likes this.
  4. Oct 12, 2021 at 12:53 PM
    Jensonbt
    Jensonbt Well-Known Member
    Beckler
    Idaho
    2012 gray tacoma DCLB
    Just enough to look kinda cool.
    Yeah, “taco lean” happens because the battery, driver, and fuel tank is all on the drivers side of our trucks. When I had 2 odyssey batteries on the divers side that weighed close to 100 lbs total I had almost a 1.5” difference driver to passenger. But I swapped out to optimas that totalled maybe 60lbs it almost went away.
  5. Oct 12, 2021 at 12:55 PM
    Jensonbt
    Beckler
    Idaho
    If it’s leaf springs there’s a tiny amount of play between the leafs and the centering pin so yes there actually is a tiny amount of alignment one can do. I’ve had to do it to an f150 that’s why I know it’s possible.
  6. Oct 12, 2021 at 1:02 PM
    eon_blue
    Azusa, CA
    At home yeah but an alignment shop isn't going to do that as part of an alignment
  7. Oct 12, 2021 at 1:04 PM
    eon_blue
    Azusa, CA
    But yeah I've had to do the same thing after leaf spring install, I torqued one side down after install at a time and ended up having to ratchet strap the axle to the frame to line them up better afterward. Had one wheel sitting further ahead in the wheel well than the other.
  8. Oct 12, 2021 at 1:05 PM
    Jensonbt
    Beckler
    Idaho
    I worked at an alignment shop, I think it more depends on the shop and the tech doing the actual alignment.
    b_r_o, jeminyned and a2lowvw like this.
  9. Oct 12, 2021 at 1:06 PM
    Hautian
    Hautian Well-Known Member
    Upper Peninsula, Michigan
    2016 Silver TRD OR - sold / 2022 4Runner
    When I put dakar leaf springs on my last Tacoma I didn’t get the pins in the same spot on both sides and my truck dog legged a little. I knew something was up though because my wheel had to be turned slightly to drive straight down the road. I was able to loosen the u-bolts and slide the axle back on one side and all was good. There should be a little bit of adjust on the pin holes.
  10. Oct 12, 2021 at 1:10 PM
    Jensonbt
    Beckler
    Idaho
    So OP find out if the rear leafs are factory and where the “cosmetic” damage was because if it was a front end accident it might not be something to worry about but if it was rear ended or hit from the side it could have shifted that rear axle or worse bent the frame.
  11. Oct 12, 2021 at 1:19 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    1) Find your wheelbase measurements online
    2) Make sure front wheels are pointing straight
    3)Measure your wheelbase from center of ea wheel on ea side of your truck
    Whatever side of your truck shows a difference in wheelbase is the side that have either a bent or broken leaf spring centering pin or damaged suspension or even frame damage
    You can also have someone follow you as you drive down a street and they can see what direction your truck is dog tracking
    SR-71A and Jensonbt like this.
  12. Oct 12, 2021 at 1:25 PM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    we need pictures
    lynyrd3 likes this.
  13. Oct 12, 2021 at 2:49 PM
    Sherlock18
    Sherlock18 [OP] Well-Known Member
    2008 Access Cab 4x4 OR
    I'm honestly going to wait for my results Tuesday. The shop is owned by a friend who rebuilds salvage vehicles. If anyone can find the issue he should be able too. Up to and including bent frame. It's honestly not terrible, I'm just picky. Very well could be the center pin being off center/broken. I'll keep the thread posted. Nicest truck I've ever owned otherwise.. lol
    winkel, Jensonbt and Toyko Joe like this.
  14. Oct 12, 2021 at 5:18 PM
    lynyrd3
    Bill
    East Central Upstate NY
    :worthless:
    Jensonbt likes this.
  15. Oct 19, 2021 at 5:41 PM
    #35
    Sherlock18
    A local shop put my truck on the alignment machine and said the frame is slightly bent (has some diamond). I'm taking it to another place for a second opinion tomorrow. I don't know what to do at this point. I might be the proud new owner of a really nice piece of junk.
  16. Oct 19, 2021 at 7:26 PM
    #36
    Toyko Joe
    Toyko Joe Here for the pictures
    Should be able to stretch it square frame shops pull frames into square all the time!
  17. Oct 19, 2021 at 7:29 PM
    #37
    Sherlock18
    Think it will lose much strength? I'll probably go ahead if that's an option.
  18. Oct 19, 2021 at 10:32 PM
    #38
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What it is:
    https://www.youtube.com/watch?v=4cJ18D-r1BY
    Real life image:
    https://www.youtube.com/watch?v=jMFTdjNVPGE
  19. Oct 20, 2021 at 7:19 PM
    #39
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    If the frame is truly what is called diamond, unless it is by a small amount it cannot be fixed.
  20. Oct 20, 2021 at 8:33 PM
    #40
    Sherlock18
    Update.. took it to another larger shop for a second opinion. They are saying that the rear axle has likely shifted and that they see no evidence of the frame being bent. I'm inclined to believe them as the truck has no record of significant accidents. And the body seems pretty straight. The bed and cab are perfectly parallel for example. He didn't charge me for the opinion, and will attempt to fix it next week.
    SR-71A likes this.
