My Truck is doomed! Oil test results from 30k oil change. UPDATE: 110K!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Aug 11, 2017.
  1. Aug 11, 2017 at 5:19 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I always find your comments helpful, keep up the good work!
    Cheers
    kgilly likes this.
  2. Aug 11, 2017 at 5:48 PM
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    See, if you are going to change your oil too often, this is how/why you do it.
    The hammer[QUOTED] likes this.
  3. Aug 11, 2017 at 7:49 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Mobil 1 has been crap for several years now. Especially in the shear/viscosity stability. I switched to Pennzoil platinum in my '04 WRX and had much better results. I believe they had a change of formulation back in the day. I forget the details, but I thought the dropped back from being a true group 4 as well. This after raising a stink with other oil companies for calling their < goup 4 oils "synthetic". Anyway...Ill use PP or most probably Castrol Syntec or any other synthetic before I touch M1 again.
    scocar[QUOTED] likes this.
  4. Aug 11, 2017 at 7:54 PM
    rjacobs
    rjacobs Well-Known Member
    yea mobil 1 isnt a group 4, its highly refined group 3 base stocks.
    Ive never understood the fetish people have with Mobil 1.
  5. Aug 11, 2017 at 8:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This OP is cool. The only interval which I can see for which is not accounted for here is the oil itself becoming carbonized and eventually becoming carbon deposits within the heads/ piston tops due to less frequent oil change intervals.
  6. Aug 11, 2017 at 8:10 PM
    The hammer
    Direct Injection is also notoriously known for carbon deposits. Audi's come to mind for some reason.
  7. Aug 11, 2017 at 8:29 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Calcium? It's a salt, and water soluble, but typical anyway evidently.
  8. Aug 11, 2017 at 8:55 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I like to use Blackstone on my vehicles too, always like to read the comment section too where the write stuff.
  9. Aug 11, 2017 at 8:57 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Technically - calcium is a metal. I don't remember materials that well from college, but when I went down the rabbit hole on my own Blackstone results, I found that it's used as a detergent for engine oils. 2000 ppm is typical and means the oil can continue to do the job of reducing deposits.
    OA
    davidstacoma, rlx02 and hiPSI like this.
  10. Aug 11, 2017 at 8:58 PM
    scocar
    scocar hypotenoper
    Yeah I changed to PP some time ago after seeing better data.
  11. Aug 11, 2017 at 9:04 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    Thanks for sharing, these engines are exceptionally clean burning.
  12. Aug 11, 2017 at 9:47 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Excellent post and comments man! It's good to see fact instead of opinion every now and then.
  13. Aug 12, 2017 at 6:32 AM
    Woodrow F Call
    Colorful Colorado
    I put in Mobil 1 this go around..... I guess I'll be looking to do this again for sure.... probably update this post with the info.
  14. Aug 12, 2017 at 6:33 AM
    Woodrow F Call
    Colorful Colorado
    If I ever overhaul the engine, I'll definitely look for this.
    12TRDTacoma[QUOTED] likes this.
  15. Aug 13, 2017 at 5:46 AM
    #35
    Woodrow F Call
    Colorful Colorado
    Probably because it's used in stock sports cars like the Vette.
  16. Aug 13, 2017 at 7:16 AM
    #36
    shackley
    Makes sense, yes.
  17. Aug 13, 2017 at 9:02 AM
    #37
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    Because it's a consistent, quality, proven product that is available at every corner auto parts, convenience or mega store across the US at a great price. It's hardly the crap oil that some on the internet make it out to be. Change it and your filter every 7-10K miles like you should be and everything will be fine.
  18. Aug 13, 2017 at 1:30 PM
    #38
    rjacobs
    I never said it was bad oil, I just dont get peoples infatuation with it.
    xxTacocaTxx likes this.
  19. Aug 13, 2017 at 2:15 PM
    #39
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Mostly marketing. I think they use the same marketing firm that Ford uses.
  20. Dec 15, 2017 at 2:34 PM
    #40
    Woodrow F Call
    Colorful Colorado
    Updated op with 40k info.
    Omar RVA and bshammer0 like this.
