My Truck is doomed! Oil test results from 30k oil change. UPDATE: 110K!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Aug 11, 2017.
  1. Dec 15, 2017 at 2:39 PM
    #41
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Nice. I need to do this my next oil change for piece of mind on engine health if nothing else. I am paranoid that all my issues w/ lean/rich/CKP/etc., the first 10k miles of ownership caused long-term damage even though it's running well now. A couple of samples sent off with some good results would set me at ease beyond just confirming oil change frequencies. thanks for the update
  2. Dec 16, 2017 at 4:45 AM
    #42
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Lots of folks have some concerns about the 10k frequency. Kind of why I'm doing it.
  3. Dec 16, 2017 at 5:05 AM
    #43
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    A few questions. You use Mobil1 0-20 (in Baton Rouge)? Isn't that hot and humid? Why not 10w-30 or 10w-40? Also the analysis says Mobil1 was fine at a 10K mile interval?
  4. Dec 16, 2017 at 5:31 AM
    #44
    Woodrow F Call
    Colorful Colorado
    1. Yes
    2. Yes
    3a. It's what the manufacturer recommends. They actually test the crap out of the engines and oil and know what the clearances are and what viscosity works. If you work in a technical field, original numbers had lots of padding in them. As time goes on, we sharpen our pencils and get closer to the real number.
    3b. Humidity isn't an issue if the engine is running. It's going to cook out any moisture since it's running at over 200F.
    3c. Ambient Temperature also doesn't matter since the engine and oil is regulated at temps much higher than ambient anyway. If the cooling system can't keep up, you got a problem.
    4. The report says I should try 12,000 mile intervals since the oil is doing so well. So, yes. 10k is OK. This confirms the answers in 3a.
    Hope this helps.
  5. Dec 16, 2017 at 5:40 AM
    #45
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Great data!
    Then there will still be those who still insist/argue for 3K mile OCI's.
    :smack:
    SJC3081, Mtn Mike, bshammer0 and 2 others like this.
  6. Dec 16, 2017 at 5:47 AM
    #46
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    Good stuff here Woodrow, thanks for sharing. :hattip:
    Woodrow F Call[OP] likes this.
  7. Dec 16, 2017 at 6:08 AM
    #47
    bill8331
    bill8331 W9LSC
    bill
    central IN
    17 SR5 V6 4x4
    SCS F5, 5100, Kenwood-Kicker/Polk
    Real data is hard to argue with. Thats good info to know. Thanks for sharing OP.
  8. Dec 16, 2017 at 6:53 AM
    #48
    GTS Bruce
    GTS Bruce Well-Known Member
    W
    Rotella T6 0-40 full synth. Higher level of antiwear and detergent additives. Use it in everything. Cars,trucks,tractors,snow blowers,leaf blowers... Switch over once and see how much darker the used oil is being drained. Pull the cover off a small engine and see how much cleaner it looks.Everything runs quieter and smoother. People are using it in their race cars and track cars. I use it in my 575M. It is of course dry sump and takes 3 gallons plus one qt to fill. Has 2 oil filters too. Bruce
  9. Dec 16, 2017 at 7:43 AM
    #49
    Woodrow F Call
    Colorful Colorado
    @GTS Bruce why would I use it? I actually have lab data telling me that what I'm using is doing a great job.
    Also, that oil has a higher viscosity at operating temp than what Toyota says to use. That could increase wear and lower fuel economy on this particular engine. It Might work fine, but why risk it based on anecdotal information?
    Your telling me to try something because a bunch of other people are using it for different applications, but no empirical data to back it up. I don't understand.
  10. Dec 16, 2017 at 7:56 AM
    #50
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Because the ambient temperature difference of +20 degrees does not mean anything to your engine.
  11. Dec 16, 2017 at 8:01 AM
    #51
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Love this stuff. Thanks for posting your data. It’ll be good to link to the guys here swearing by 5k mile OCIs for no reason.
    OA
  12. Dec 16, 2017 at 8:02 AM
    #52
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Motor oil is a good source of calcium :)
    Thanks for sharing this, Vbpiper. Good info on this thread, Woodrow!
    Vbpiper and Woodrow F Call[OP] like this.
  13. Dec 16, 2017 at 8:19 AM
    #53
    Willbird
    Willbird Well-Known Member
    Bill
    Magnetic Gray Metallic 2017 SR5 Double Cab
    What I LOL about is how people think "if it is a good engine oil then hell use it on EVERYTHING.....door hinges, air rifles, shotguns....machine guns".
  14. Dec 16, 2017 at 8:32 AM
    #54
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    What does time do to motor oil? I typically only put about 6000 miles a year on my third gen but don't want to leave the oil in for more then a year so I do it in the fall and early summer.
    I have been changing every 6 months mainly because I get a good discount on oil, I'm not worried about cost. I use Mobil 1 and have used it since day one on my 1st gen also. That truck get used a lot more and I change that at 7000 miles or about twice a year also. I've never burnt a drop of oil in that truck even though it calls for 3500 mile oil changes, if I recall correctly.
  15. Dec 16, 2017 at 8:43 AM
    #55
    Willbird
    Bill
    Probably a complex question that has a highly individual answer. The low mileage in one case might mean driving 3 miles to work and 3 miles home, in another case it might mean that the vehicle was used as an airport shuttle that idled more than it was driven.
    My 2004 Silverado had an hour meter on odo, that could fill in a data point that might be helpful.
    My Ma had a car that was driven the 2 miles to work, sit 8 hours, driven 2 miles home. Alternators and batteries did not last long in her car.
  16. Dec 16, 2017 at 8:46 AM
    #56
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    These results make me feel good about going 10K OCI's. Especially since I'm using amsoil signature series which they rate for 25K/1 year.
  17. Dec 16, 2017 at 8:47 AM
    #57
    JoeyDel
    Joe
    South Jersey
    I only use the '16 on weekends or when I'm off work so it is typical miles per trip. No real short trips on a consistent basis. My '03 gets used for work and that is mostly 40+ mile round trips but it varies also.
  18. Dec 16, 2017 at 9:14 AM
    #58
    Woodrow F Call
    Colorful Colorado
    Time just allows for the additives to break down and increase the amount of time water is actually in the oil (when the engine is cooled down). Finally more time can mean more contaminants.
    I've got turbines with 10 years on oil.... but the oil is different, tested often, and occasionally sweetened with additives.
    Can you go more than 6 months? IDK, but you can test and find out. I drive too much.
    daddy_o likes this.
  19. Dec 16, 2017 at 9:42 AM
    #59
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Thanks for bringing some Real Talk about oil change intervals. Way too much anecdotal "evidence" on the internet about why people should change their oil every 3-5k miles. A friend of mine was trying to convince me to use a "thicker"oil and change it more often. Going to double down on nope to that! Thanks for the science!
  20. Dec 16, 2017 at 11:38 AM
    #60
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    Good info, thanks for sharing and updating
