My truck is on its 4TH REAR DIFF
Discussion in '3rd Gen. Tacomas (2016-2023)' started by benevichi, Aug 21, 2020.
  1. Aug 27, 2020 at 1:42 PM
    #41
    jetfishn
    jetfishn Well-Known Member
    Ding! Ding! Ding! "soft metal gears" that answer could be a winner. But I suspect a misaligned carrier bearing housing machine work.
  2. Aug 27, 2020 at 1:44 PM
    #42
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If this was a jeep forum, misaligned carrier housing would of been the first and only reply.
    jetfishn[QUOTED] and US Marine like this.
  3. Aug 27, 2020 at 1:44 PM
    #43
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    All oem differentials "axles" from a auto mfg are mass produced by machines or robots . No human interaction is involved so there's imperfections / flaws during the assembly
    A driveline shop that has someone assemble a differential by hand will last much longer and be noise free
    Lord Humongous likes this.
  4. Aug 27, 2020 at 1:48 PM
    #44
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I had a set of US gears , 3:73 ratio in my Camaro that would howl at 50-70 mph . Replaced them with a higher end set and noise went away . Found out later the US gears were soft metal and found alot of similar complaints online
    Carrier bearings would produce a low frequency rumbling sound not a high pitch whine
    ovrlndkull likes this.
  5. Aug 27, 2020 at 1:56 PM
    #45
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    I wish a perfect pattern and perfect setup would produce no noise. I have an excellent pattern, preload at 15 in-lbs, backlash at 0.006 and I still get coast noise between 55-65mph (on Nitro 5.29s). This is right around where I got nose on OEM gears too. Like I said previously, Toyota has determined this noise to be normal but has released a TSB to "dampen it" from entering the cabin for lack of a better term.
    US Marine likes this.
  6. Aug 27, 2020 at 2:00 PM
    #46
    therealprotaco
    Gilbert, AZ
    Here is the TSB. It only applies to 2016-2017 vehicles. I got it done on my 2017 OR, it did help. Not sure if it has been expanded to any other years or not.
  7. Aug 27, 2020 at 2:40 PM
    #47
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    For what it’s worth, my diff is perfectly quiet. Reading this thread makes me think I’m the only lucky one of the bunch. ;>
  8. Aug 27, 2020 at 2:56 PM
    #48
    therealprotaco
    Gilbert, AZ
    No, you probably have the same problem but likely already have some version of the TSB parts from the factory in your 2020.
    MOC221_ likes this.
  9. Aug 27, 2020 at 3:10 PM
    #49
    OffroadThinker
    OffroadThinker Well-Known Member
    Andy
    San Diego
    2019 DCSB 4X4 OR
    Good luck OP
  10. Aug 27, 2020 at 4:04 PM
    #50
    Itchyfeet
    Itchyfeet Well-Known Member
    Is that what you think? I walk through a large plant every month and shit gets tacked in jigs by humans before it is even moved over for robotic welding.
    Yes they sometimes have defects in the scrap bin.
    US Marine[QUOTED] likes this.
  11. Aug 27, 2020 at 4:15 PM
    #51
    gudujarlson
    Minnesota
    I think you are on the way to a solution. Good luck.
  12. Aug 27, 2020 at 4:53 PM
    #52
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Technically the differential is just housed inside the carrier.
    But in a Toyota axle the entire gear, carrier, differential assembly is a drop out third member. The carrier bearings are affixed in the third member, not the axle housing. The entire 3rd member bolts into the axle housing.
  13. Aug 27, 2020 at 4:59 PM
    #53
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Back in the day when i setup a 12 bolt chevy posi differential with 4.56 zoom gears, it would howl pretty good. Asked if this was normal for zoom gears... was told it it is, just the nature of what they are.
  14. Aug 27, 2020 at 5:01 PM
    #54
    2020cement
    2020cement Active Member
    Isn’t this normal? Mines been doing it for about 4000 miles.
  15. Aug 27, 2020 at 5:12 PM
    #55
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    I would bet it has something to do with bearing preload and gear backlash as well.
  16. Aug 27, 2020 at 5:34 PM
    #56
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    Didn't read everything here but at this point I'd think you have a bent or defective axle housing? I'm not %100 sure but I believe dealers just swap the whole third member with rear gear problems (the whole clamshell with the front) which would rule out a bad tech lol.
    I'd like to see the carrier/side bearings on these diffs.
    xxTacocaTxx likes this.
  17. Aug 27, 2020 at 5:40 PM
    #57
    Lord Humongous
    AZ
    wait... are you running twin turbos and a 3500 rpm stall converter? If no never mind lol.
  18. Aug 27, 2020 at 7:21 PM
    #58
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    did U but truck new / used ??
    the line mechanic/dealer guy is into the void of just switching out parts
    as opposed to having a discerning look & assessing what is wrong
    NOT knowing & simply replacing is stepping in the SAME pile
    9 out o 10 mechanics dont KNOW How to ' set up ' the many types o differentials
    fewer still that are experts
    the set up on the pinion .............
    the actual axle housing could be tweaked
    id take to a Real Axle shop
  19. Aug 27, 2020 at 9:01 PM
    #59
    Jmac2408
    Jmac2408 Well-Known Member
    Justin
    Southern California
    18 TRD Off Road 4x4
    Crazy they are replacing the rear diff.. NVH from the rear diff is normal on these trucks. Well documented
  20. Aug 27, 2020 at 9:01 PM
    #60
    ShimStack
    Ben
    NC
    A lot of people are quick to jump on the "not setup" thing because gears make noise. The fact is some gears and some gear cuts make more noise than others and some vehicles amplify that noise into the cab rather than attenuate them. At this point we've realized gear whine in these trucks is common and normal and not a sign of a mechanical problem or pending failure. Not to say there aren't other noises that could be problematic, however.
    For those that think that gear whine means there is a mechanical problem it's important to understand gears make noise and some of the stronger methods of manufacturing and installing gears creates loud, unavoidable gear whine and many OEM gears are actually weaker designs in the interest of reducing noise. So sometimes gear noise = strength and it's just not so simple to assume noise equals problem unless you consider the noise alone the problem, which is justifiable in this day.
    I'd bet the OP is just at a dealer willing to chase their tail on a problem that technically isn't one. Not every person/tech/dealer is clued in to all issues or nuances in the same way.
    ryan760, gmtech and Jmac2408 like this.
