My truck is shaking between 20 to 30 mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ecko380, Nov 20, 2022.
  1. Nov 21, 2022 at 7:45 AM
    #41
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    how many times have you greased your driveshaft? If the answer is never, or its part of your lube techs multi-point inspection (also never), I'd start there.
  2. Nov 21, 2022 at 7:52 AM
    #42
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    is the shake during acceleration, decel, or coasting? we need more info
    i think there's a TSB for that but if you haven't had this issue since recently, i don't think that's the problem
  3. Nov 21, 2022 at 7:54 AM
    #43
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    multi-point inspection is code for "we didn't really do anything but we want to make you feel better about your vehicle. our master tech kicked your tires a couple times"
  4. Nov 21, 2022 at 10:45 AM
    #44
    Ecko380
    Ecko380 [OP] Well-Known Member
    Rafael
    2016 Blazing Blue Pearl Tacoma TRD Sport
    Vinyl decal to glove box, sill protector front and back and TRD pro shift knob.
    What shims? Do you have pictures and parts number?
  5. Nov 21, 2022 at 11:02 AM
    #45
    Ecko380
    Rafael
    I did try the draft shaft and it cannot be moved at all, there is no wiggle room, or any play in it.
    G2.M6[QUOTED] likes this.
  6. Nov 21, 2022 at 11:04 AM
    #46
    bettywhiteoneseven
    bettywhiteoneseven Member
    Tony
    Modesto CA
    2017 White Toyota Tacoma TRD OR
    3.5" IronMan4x4 Suspension Lift Kit. #3" BFGoodrich tires on 17" Series 60 Vintage Matte Black wheels. Apex Fabrications rock sliders. Southern Style OffRoad Stage 2 Slimline Hybrid bumper. Hooke Road roof rack. KFFab Voodoo Max Modular 13" bed rack.
    After lifting my truck 4", I had heavy vibration issues. Shims under my leafs fixed that, and the other vibration issue I had was when I damaged my drive shaft a few weeks ago. A new drive shaft fixed that. With the leaf shims, I also needed a carrier bearing spacer when I put the lift in. If it's not the needle bearings or tires, you'll want to start looking at your drive train. My vibrations were all self induced.
    Ecko380[OP] likes this.
  7. Nov 21, 2022 at 11:04 AM
    #47
    Ecko380
    Rafael
    I would say acceleration and deceleration.
  8. Nov 21, 2022 at 11:07 AM
    #48
    Ecko380
    Rafael
    Never / part of your lube techs multi-point inspection I did not know this had to be done.
  9. Nov 21, 2022 at 11:19 AM
    #49
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Shims are not a standard part number, rather an aftermarket component often installed in the rear with a lift. Many companies that will sell you a lift kit can also sell you shims, to help correct the change in driveshaft geometry from the lift. A carrier bearing drop kit also aims to correct that geometry but in a different area of the triangle.
    Neither should be necessary if your suspension is stock.
    Ecko380[QUOTED][OP] likes this.
  10. Nov 21, 2022 at 11:25 AM
    #50
    Off Topic Guy
    It does, and its outlined in your owners/maintenance manual. I understand nobody ever truly goes by the book, but once in a blue moon is always better than never. And bc I know it will come up, anyone else reading this, OP has a 2016; yes, it needs to be greased. Newer models are sealed and cannot be greased, we know.
    Because its never been greased, I'd start there. If that doesn't help any/the damage is already done, you can address it then. Do you have a grease gun?
    Here ya go:
    Check Your U-Joints | Tacoma World
  11. Nov 21, 2022 at 2:59 PM
    #51
    Ecko380
    Rafael
    Yes, my suspension is still stock.
  12. Nov 21, 2022 at 3:01 PM
    #52
    Ecko380
    Rafael
    Yes, I do have a grease gun.
  13. Nov 21, 2022 at 3:06 PM
    #53
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    You just eliminated your u joints then.
  14. Nov 21, 2022 at 3:12 PM
    #54
    G2.M6
    Fort Collins CO
    Let's revisit that transmission change now. Did you do it? If you did, correct fluid? If you paid jiffy lube I'd go back and ask what they used.
    cryptolime likes this.
  15. Nov 21, 2022 at 3:31 PM
    #55
    Ecko380
    Rafael
    I’ve never greased my U joints before I never even knew this existed until now. The transmission oil change, I had a dealership do that for me.
  16. Nov 21, 2022 at 3:55 PM
    #56
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Unless his springs are failing.
  17. Nov 21, 2022 at 4:24 PM
    #57
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    And then, the solution is to replace the leaf springs. Not add shims.
  18. Nov 21, 2022 at 5:01 PM
    #58
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Wow everyone is going on some crazy tangent here lol. One step at a time . Once the OP does the rotation and if it’s still there then we can go into crazy mode. Most things like this end up being a simple obvious fix .
  19. Nov 21, 2022 at 5:05 PM
    #59
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Torque converter shudder maybe
    Ehahn84 likes this.
  20. Nov 21, 2022 at 6:07 PM
    #60
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    U joints often go tight before they go loose. The only actual way to check U joints is to remove the shaft and articulate the joint.
