My truck is stuck in ''park''
Discussion in 'Technical Chat' started by gasgu, May 30, 2009.
  1. May 30, 2009 at 11:36 AM
    gasgu
    gasgu [OP] New Member
    Laval Québec
    09 tacoma 4x4
    Please...help me!
    My brand new Tacoma is stuck in park and cannot mouve!
    It's a 2009 Tacoma crew cab 4x4 with 3000km on it.
    The dash show ''''ABS '' and the display of slippy road(pictogram of truck and 2 big ''SS'')
    The engine start normally but the transmission cannot mouve from park!
    It was running fine ,my employee park it in front of the customer house and when he want to quit , the transmission blocked!
    Thank's!
  2. May 30, 2009 at 11:39 AM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    umm... there a little remove tap next to the shifter, open it up and press on it then pull it in gear....
  3. May 30, 2009 at 11:41 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You do have your foot on the brake when attempting to take the truck out of park, right?
    If so, try what tc2008 said.
  4. May 30, 2009 at 11:45 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i had the same problem before. romove that little cap next to your shifter and press it down while shifting.
    Check your fuses in the cab. I blew one and thats why mine wouldnt shift out of park
    11Bguy and tacoma08brandon87 like this.
  5. May 30, 2009 at 11:46 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    yea the little plastic cap to the left of the shifter pry it up and there is a button at the bottom and it will allow u to put it in gear. sometimes a dead light bulb will trigger this to happen.
  6. May 30, 2009 at 6:05 PM
    gasgu
    Laval Québec
    09 tacoma 4x4
    Thank's!!
    It's work now!
    If i understand well...we cannot install an after market wiring kit for the trailer...we must use the Toyota harness...i'm right?
    Anyway...sincerely..thank you!
  7. Dec 13, 2009 at 2:34 PM
    squidler2
    squidler2 New Member
    Utah
    2001 4-door Tacoma
    Wanted to thank everyone for their posts. I had a problem where my truck would not go into park after a snowstorm in 4x4. Read this thread. Held that button down and it went into park. Thanks again for the knowledge.
    11Bguy likes this.
  8. Dec 13, 2009 at 3:37 PM
    spp
    spp OC, Kalifornia
    OC California
  9. Dec 13, 2009 at 3:43 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Welcome to TW, good to see you got'tr go'n.
  10. Dec 14, 2009 at 8:46 AM
    pretzel
    pretzel Well-Known Member
    TX
    2010 Tacoma 4 cyl
    +1 check your fuses.
    In my '97 4runner after about 2.5 hr drive towing trailer, pulled past a ranch gate, put in park, then got out to close gate behind me. Got back in, but couldn't shift from park. After *much* head scratching, my friend suggested checking fuses - sure enough the fuse for brake light was burned (due to faulty trailer wiring)! Apparently this is a safety feature they don't tell you about in the manual :eek:
  11. Feb 5, 2015 at 9:13 AM
    MattRRT
    MattRRT Well-Known Member
    Concord, NC
    2009 Tacoma TRD Sport
    5100s, BGF TA KO2, Trifold Tonneau Cover, Weathertech window visors, window tint,
    Thanks guys.
    I was trying to wire the brake light for my cap. Even after I disconnected everything it was still stuck. However once I hit that release the ABS and traction light went out and it was fine.
    Now to figure out how to wire that light!
    Taco-Grinder likes this.
  12. Apr 10, 2017 at 8:23 AM
    3 Rivers Bob
    3 Rivers Bob Member
    2011 Tacoma
    Thanks to all with the remedy for "stuck in park" and associated warning lights. I immediately knew the trailer light culprit causing the problem and quickly corrected that. With the fuse replacement I'm back in normal business. You're a great help!
  13. Jun 23, 2017 at 5:29 PM
    Icecold
    Icecold New Member
    2005 Tocoma SRS 2WD
    Couldn't move my truck after installing a backup camera. Found this page, checked my fuses and sure enough my ignition fuse bow out. My truck can move, many thanks!
  14. Jun 24, 2017 at 5:35 AM
    gearcruncher
    Canadain bumper technician
  15. Nov 28, 2017 at 2:21 PM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    I'm locked into parking gear on my 08 tacoma why does it do that also can it be a Blown fuse if so whuch fuse would it be
  16. Nov 30, 2017 at 4:26 PM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
  17. Nov 30, 2017 at 4:28 PM
    gearcruncher
    Have you not read any of the posts the guys replied with ?
    What have you tried so far
  18. Nov 30, 2017 at 4:32 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Thread necromancers
  19. Jul 5, 2018 at 7:26 PM
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    This just oddly enough happened to me today. My truck would start but I couldn't shift out of park. And also my SRS light was on. I was pulling a trailer and I ended up hitting a rainstorm. I'm assuming some of the trailer wiring shorted something out with in my truck because the one of the ignition fuse (10amp) blew two different times. I'm not exactly sure why but this is actually the 4th time using this trailer. But it was the first time I used it in the wet rain. But I know that the shifter lock should release it from getting out of park. After I pulled that cover off and tried to depress it it would not even depressed. While holding the brake and pushing that lever along with trying to move the gear shifter it wouldn't budge at all, any ideas to why the shift release lock would not work?
