My truck is wimpy...
Discussion in 'Towing' started by kucelkj, Sep 23, 2011.
  1. Sep 23, 2011 at 3:33 PM
    kucelkj
    kucelkj [OP] Member
    Ken
    Ambridge, PA
    2011 SR5
    ARE cap, bed rug matt, Weather Tech floor mats, Toyota skid plate up front, kick butt flashlight and a 38 snub nose.
    I recently towed a 6x12 trailer with 3 quads on it. The back end of my truck was sagging worse than an old set of tits. Can someone let me know what to do about it. New springs? Will the truck ride hard afterwards?
    2011 4 dr 4x4 taco
    Thanks,
    -Ken
  2. Sep 23, 2011 at 3:33 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    look up spring TSB
  3. Sep 23, 2011 at 3:35 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    this is a good idea, it wont be the solution though.
    you may need some aftermarket bumpstops or some air bag helpers if you plan on hauling all that weight often, or get a WD hitch
  4. Sep 23, 2011 at 3:42 PM
    97yota4wd
    Eric
    Mesa, AZ
    that is the reason for the TSB springs
    and yeah air bags will help but not needed unless your towing over 5klbs imo
    the tsb leaf springs will handle hauling 3 quads just fine
  5. Sep 23, 2011 at 3:45 PM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    2016 4Runner
    Ome leaf pack.
  6. Sep 23, 2011 at 3:46 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Yup
    But be aware it lifts the rear 2 1/2" - 3"
  7. Sep 23, 2011 at 3:50 PM
    pudge151
    Sean
    Connecticut
    im not sure if you have a 2nd gen, but i have an 08, i did the TSB, it barely helped at all with hauling a load, i cant put 400 lbs in the back without bottoming out the rear susp, pre and port TSB, when I have 4 adults in the truck and go over bumps in the road it bottoms out. thus i got air bags and im very happy to say, no more bottoming out
  8. Sep 23, 2011 at 3:53 PM
    kucelkj
    kucelkj [OP] Member
    Ken
    Ambridge, PA
    2011 SR5
    What's the deal with air bags? Are they shock replacements? What brand? Where do I get em?
  9. Sep 23, 2011 at 3:57 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    oh dang. i guess will se what mine does with a 7X12 and a side by side and 1 atv. think im going riding tomorrow.
  10. Sep 23, 2011 at 4:01 PM
    kucelkj
    kucelkj [OP] Member
    Ken
    Ambridge, PA
    2011 SR5
    I'm down with the bags. Thanks everyone!!!!
    Bags beat sagging tits any day.
    Go riding everyone!!!!
  11. Sep 23, 2011 at 5:14 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    You should find out what the tongue weight is first. Sagging does not depend on the weight of the trailer towed, but the tongue weight. A simple solution would be to move the quads back on the trailer if the tongue weight is too high.
    Air bags are not really the solution. They just make it feel / look better, but they do not change the weight added to the rear or the weight removed from the front. Only better weight distribution or a WDH will do that.
  12. Sep 23, 2011 at 7:25 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I'm installing Firestone Ride Rites tomorrow... baggin is where it is at. :D
  13. Sep 23, 2011 at 7:36 PM
    sechsgang
    Make sure you also practice how to climb out of a ditch and turn your truck / trailer back over if airbags is all you rely on to increase your towing capacity! LOL. :D
  14. Sep 23, 2011 at 7:41 PM
    tx_shooter
    I grew up towing... not an idiot. The bags are just going to help my truck not look like a little bitch draggin its nuts on the pavement when I hook up a trailer to it. They are going to help support the added weight since I still have the stock 3 leaf pack. I bought the truck used after the 36k mile mark.
    As for how air bags have shit to do with my truck flipping and ending up in the ditch; care to explain that one? :cool:
  15. Sep 23, 2011 at 7:49 PM
    sechsgang
    This is kind of funny, but what air bags have to do with it is that people believe that air bags help them tow more because they make it look right. But that is wrong, unfortunately.
    Measure your tongue weight, and get a WDH if your truck looks like a little bitch draggin its nuts on the pavement.
    And if your tongue weight is just plain too much for a Tacoma (which unfortunately can't take much), get a bigger truck or tow less.
  16. Sep 23, 2011 at 7:50 PM
    pudge151
    Sean
    Connecticut
  17. Sep 23, 2011 at 7:51 PM
    sechsgang
    LOL, I agree.
  18. Sep 23, 2011 at 7:52 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Airbag helpers sounds like it should do the trick!
  19. Sep 23, 2011 at 7:53 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
  20. Sep 23, 2011 at 7:55 PM
    tx_shooter
    Yeah, because something that helps stabilize your truck's body while under load can't be good for it. That excessive body roll and sag is fine... you're right. Air bags are a farce... the whole air support industry right up to big rigs are a farce. For the record, I belive in Santa Clause and the Easter Rabbit. :cool:
    If my truck's "sag" was the measure for how much it can haul/pull then it seems that 200 lbs would be the limit.
