My truck just hit 160000 miles. What to do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tucker771, Jun 12, 2016.
  1. Jun 12, 2016 at 8:51 AM
    Tucker771
    Tucker771 [OP] Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    Hey all. My truck just hit 160000 miles a few days ago and I was wondering if there's anything that I should do to care for it. Regular oil changes have been made and I got the gear oil changed about 20k miles ago. Thanks!
  2. Jun 12, 2016 at 8:55 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    keep on keeping on! Maybe a fuel filter change.
  3. Jun 12, 2016 at 8:57 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Did you ever change the timing belt/water pump?
  4. Jun 12, 2016 at 8:57 AM
    Tucker771
    Tucker
    Raleigh, NC
    Yeah about 30k ago
    DustStorm4x4[QUOTED] likes this.
  5. Jun 12, 2016 at 8:58 AM
    Tucker771
    Tucker
    Raleigh, NC
    How long do those last? Cause I did that when I did the gear oils
  6. Jun 12, 2016 at 8:58 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Hmm what about the suspension? I'm sure the stock suspension would be tired by now.
  7. Jun 12, 2016 at 8:59 AM
    Tucker771
    Tucker
    Raleigh, NC
    Nothing stock about this suspension :bananadance:
  8. Jun 12, 2016 at 11:36 AM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    You finally broke it in, good job.
    Tucker771[OP] likes this.
  9. Jun 13, 2016 at 10:17 PM
    BrianButler
    BrianButler New Member
    Brian
    2003 Green SR5 Tacoma 4v4 TRD Double Cab
    Stock
    I am at 170k and have been wondering same thing. I was having a issue where my truck would lose power when I let off the gas, then went back on to it. I talked to a guy at a local shop and he said to check my TPS sensor. We took it out and cleaned it and problem is gone. The thing is, is all around my truck seams to have better power response, better acceleration and just generally running a lot smoother. I didn't even realize how much power I was loosing. So maybe check your sensors to make sure your getting all your air and fuel correctly, you might be surprised how much better it runs with good feedback to the cpu and you might not even realize you have lost the power.
    I have done timing belt and water pump and rear diff oil around 120k but have not done suspension and have a new fuel filter, just need to install once i get on my feet again. (ACL replacement surgery)
    If I am going to replace my suspension should I go with OEM or after market? I have TRD and do some off roading during the summer months. No real 4 wheeling just smashing logging trails in the mountains. Thing is it is still my daily driver for work which is usually a 50mi round trip depending on where the jobsite is. I was trying to hold out till I can get me a company truck before doing suspension as well as other stuff too so I could do some real 4 wheeling but that will have to wait.
  10. Jun 13, 2016 at 10:34 PM
    Tucker771
    Tucker
    Raleigh, NC
    Hm I'll have to look into that! Many people swear by the Bilstein 5100 for this truck I've never used them though. I've had the rancho quick lift and they were great until I added the heavy bumper and winch which the struts didn't like much. I'm now running the Toytec boss system and loving it!
  11. Jul 3, 2016 at 3:34 AM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    Transmission, and grease the zerks on the drive shaft regularly
