My truck let me down in a big way
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fdbyrne, Jun 18, 2016.
  1. Jun 28, 2016 at 2:02 PM
    #61
    clord74
    clord74 Well-Known Member
    Nashville
    I read your complaint before I left on my trip then when it happened I went back to your information to see any updates
    fdbyrne[OP] likes this.
  2. Jun 28, 2016 at 2:05 PM
    #62
    fdbyrne
    fdbyrne [OP] Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Glad you got back safely. When you take it to the dealer, send me a PM and I'll give you my Toyota Corporate case number so that you can give it to them when they try to tell you that there haven't been any other reports of that same problem.
  3. Jun 28, 2016 at 2:05 PM
    #63
    clord74
    Nashville
    They are not going to be able to duplicate issue until they drive a couple hundred miles to get fluid hot . I also mention to my wife if she heard that humming type light Rumble noise also
  4. Jun 28, 2016 at 2:11 PM
    #64
    clord74
    Nashville
    Do you happen to have the number for corporate so I can file a complaint also
  5. Jun 28, 2016 at 2:16 PM
    #65
    fdbyrne
    Missouri
    800-331-4331
  6. Jun 28, 2016 at 2:19 PM
    #66
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Is everybody convinced that a worsening differential howl on a new vehicle isn't a safety issue? I'm not...
    Ch78 likes this.
  7. Jun 28, 2016 at 2:22 PM
    #67
    fdbyrne
    Missouri
    It could be, but I doubt it would fail catastrophically in a way that would lead to a crash. It would probably just continue to get louder and then start vibrating. It probably depends a lot on what you're doing at the time.
  8. Jun 28, 2016 at 2:38 PM
    #68
    clord74
    Nashville
    When I bring my to dealer I am going to authorize them to drive constant Highway for 200 miles. I called customer service they give me and case number 1606283089
  9. Jun 28, 2016 at 2:39 PM
    #69
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Are you going to Reliable Toyota?
  10. Jun 28, 2016 at 2:41 PM
    #70
    clord74
    Nashville
    Do you also smell clutch when you are starting to back up while on a hill, when you release your clutch pedal the trans brake holds then releases after a few seconds and while trying to back up you smell clutch
  11. Jun 28, 2016 at 4:04 PM
    #71
    fdbyrne
    Missouri
    Unfortunately so. My experiences with them in the past have ranged from disappointing to near criminal.
  12. Jun 28, 2016 at 5:59 PM
    #72
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Yep, typically before a differential decides to grenade, there will be noticeable vibration (for a while too). You will definitely feel it in the seat and the howling will become a very loud whirring noise starting at low speeds and increasing in pitch as your speed increases. My differential howls right now at ~5000 miles, most noticeable under light throttle at 59-60 mph. I will have the dealer make note of it, but if there is a serious problem with how the pinion bearing is situated in the differential or how the gears are meshed due to a manufacturing error, I guarantee it will not make it the 60,000 mile warranty without it becoming unbearable.
    The differential in my last truck went bad (pinion bearing) and the vibration was so bad that my rear view mirror was a complete blur at 65+ mph. It also sounded like I had a loud power drill strapped under the bed and turned on while I was driving. I am almost 100% certain the Tacoma differentials are in no danger of failing catastrophically with this amount of howling.
  13. Jun 28, 2016 at 6:16 PM
    #73
    andrew61987
    I guess I've been watching too much Fight Club.
    Narrator: A new car built by my company leaves somewhere traveling at 60 mph. The rear differential locks up. The car crashes and burns with everyone trapped inside. Now, should we initiate a recall? Take the number of vehicles in the field, A, multiply by the probable rate of failure, B, multiply by the average out-of-court settlement, C. A times B times C equals X. If X is less than the cost of a recall, we don't do one.
    Business woman on plane: Are there a lot of these kinds of accidents?
    Narrator: You wouldn't believe.
    Business woman on plane: Which car company do you work for?
    Narrator: A major one.
    Lawfarin likes this.
  14. Jun 28, 2016 at 6:22 PM
    #74
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    https://youtu.be/SMVkUgQR9NQ
  15. Jun 28, 2016 at 6:41 PM
    #75
    Joe333x
    Joe333x Well-Known Member
    Just for the hell of it, when it sticks maybe see if rev matching for the next gear with the clutch down allows for it to come free easily. Obviously not a solution but atleast maybr a way to deal with it and its always good to rev match anyway if you can. Personally ive been practicing double clutching my down shifts just for the fun of it.
  16. Jun 30, 2016 at 6:05 AM
    #76
    fdbyrne
    Missouri
    I just got off the phone with the Case Manager from Toyota as a result of the first woman I spoke to escalating my case. I spoke to the Regional Rep for the Kansas City region. His name was Danny Castro and he was the most rude, uncaring, and least helpful person that I've ever spoken to. He refused to do anything for me and told me that I wouldn't be allowed to speak to anyone else about this matter. He said that without my dealer not only replicating the complaints, but coming up with a solution they will do absolutely nothing.
    I'll bring it up again to the local dealer when I take it back to have the control arm howling TSB done next week. If that doesn't work, I'll have to explore legal options of some sort. I think I'd probably have a case for breach of contract and conducting business in bad faith since they aren't even trying to hold up their warranty responsibilities.
    I have never been this upset at a company before.
    I'm sure that this post will bring out the trolls, but I had to vent somewhere.
  17. Jun 30, 2016 at 6:09 AM
    #77
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Insist on a loaner and have them do the work while your at Disney. Pick it back up on your way home.
  18. Jun 30, 2016 at 6:30 AM
    #78
    Taco-ToDay
    Taco-ToDay Well-Known Member
    Scott
    Columbia, MD
    2016 Metallic Grey Tacoma SR5
    He has been home for about a week or so I believe
  19. Jun 30, 2016 at 6:31 AM
    #79
    fdbyrne
    Missouri
    Yes I have. I just didn't want to point that out since he's just trying to help. Also, I'm at the dentist getting a root canal. Pretty crappy day so far.
  20. Jun 30, 2016 at 6:39 AM
    #80
    bulldog
    SW MO
    2023 Pro
    I spoke with the same guy.
    If you are going to Reliable, talk with Gene. He's the service manger and worked with me and went on a test drive with me.
