My truck likes to twerk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stags863, Mar 18, 2016.
  1. Mar 18, 2016 at 7:00 PM
    Stags863
    Stags863 [OP] Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    So.......I just put some 5100's up through the front coils. Set the 5100's at the 1.75 setting. Took my truck to a local Goodyear shop and had them check/align everything back to spec because I was messing with the suspension. On my way home I noticed that the trucks rear end likes to bounce up and down. It's not violently doing it but definitely noticable. Only happens between the speeds of 50 and 55 mph. There aren't any steering vibrations at all from 0 to 75 mph. Just that weird bouncing up and down between 50 and 55 mph in the rear. As of right now I just have the 5100's up front and stock suspension in the back. Since the front now sits 1 inch higher in the front then the back would a 1 inch block or progressive AAL in the back fix this issue?
    Looking for someone that's had a similar experience.
  2. Mar 18, 2016 at 7:05 PM
    Stags863
    Florida
    Sorry I'd also like to add that I now have Goodyear Wrangler Authorities on the truck now. They are 265 70 r17's.
  3. Mar 18, 2016 at 7:08 PM
    Pigpen
    Dan
    Northwest Montana
    one of the rear tires is not properly balanced.
    Mobtown Offroad likes this.
  4. Mar 18, 2016 at 7:09 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Being higher in the front that in the back (the non-truck look) won't cause twerking. Adding a block or leaf to the rear won't fix anything. I'd take it back to the shop. Did they also install and balance those tires? Something's off. Tell them to fix it.
  5. Mar 18, 2016 at 7:16 PM
    Stags863
    Florida
    Thanks! I'll have them looked at. I purchased the 17 inch wheels that come on the Sport off of a guy I know. Had Walmart install the Authorities on the 17's. Then put them on my truck the same day I put the 5100's on which was about 2 weeks after Walmart put the tires on the wheels.
  6. Mar 18, 2016 at 7:20 PM
    Pigpen
    Dan
    Northwest Montana
    Yeah, I always change 2 or 3 things at the same time. It makes finding the new problems more interesting.
    digitaLbraVo likes this.
  7. Mar 18, 2016 at 7:31 PM
    Stags863
    Florida
    Oh I bet! I'm sure it can make it pretty frustrating.
  8. Mar 18, 2016 at 8:16 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    When I read the title I was hoping for some college girls on spring break shaking it in the bed of the truck but nope I got unbalanced tires....:oops:
  9. Mar 19, 2016 at 5:45 AM
    Stags863
    Florida
    Hahaha :rofl::rofl:
  10. Mar 19, 2016 at 6:07 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Have the tires road force balanced. Toyota did all 4 of mine for $40. Got rid of my ko2's twerking.
  11. Mar 19, 2016 at 8:22 AM
    Stags863
    Florida
    I'm at my local tire shop right now to get them balanced. Guy came out and was like whoever mounted/balanced these tires put the weights all in the wrong spots. Thanks Walmart!
  12. Mar 20, 2016 at 3:32 PM
    Stags863
    Florida
    So not only were all 4 tires out of balance.....One of them were out of round. Deemed as a defective tire per McGee Tire. Took my truck back up to Walmart and they replaced the tire under the factory warranty.
  13. Mar 20, 2016 at 3:33 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Hell yes!
    Stags863[QUOTED][OP] likes this.
  14. Mar 25, 2016 at 8:18 AM
    Stags863
    Florida
    Update - I had the one tire replaced by Walmart and took it back up to McGee to have that one tire balanced. Leave the tire shop and the back end still bounces up and down between 50 and 55 mph. Took the truck back up to McGee and had them balance again. Leave and the truck still bounces up and down between 50 and 55 mph. I honestly don't know what to do at this point. McGee seems to balance them differently each time I go up there. Weights are being placed in different spots on the tires then they were before they were rebalanced again. I know because I've marked where the weight originally is before they move it. Does this mean McGee doesn't know what they are doing or does this mean that the tires are just defective. It's not like I'm putting a ton of miles on the between visits to McGee. I'm honestly debating on contacting Walmart and seeing if I can be refunded for the full amount of these tires because they are causing me such a pain in my arse!
  15. Mar 25, 2016 at 1:00 PM
    Stags863
    Florida
    What would y'all recommend? Do you think it could still be a balancing issue or tire issue or could it be something else?
  16. Mar 25, 2016 at 7:10 PM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    Maybe they had in their head to replace the rear shocks and loosened the stem bolts. The shock's stem could be moving freely in the mounts. Reach under and see if you can shake either of the rear shocks.
  17. Mar 26, 2016 at 4:16 AM
    Stags863
    Florida
    Thanks! I'll check that this morning.
  18. Mar 26, 2016 at 5:52 PM
    Stags863
    Florida
    So it's not the shocks. Took my truck back up to McGee and told the manager I wanted to watch all the tires turn on the balancer. They were all balanced correctly according to the machine. However.....1 of the 4 were out of round. Meaning when I had Walmart put them on 2 of the 4 were out of round. Took my truck back up to Walmart and had them replace the tire under the factory warranty. Truck rides perfect now!!
    bigfoote13 likes this.
  19. Mar 26, 2016 at 5:54 PM
    Stags863
    Florida
    Not to mention in the midst of all this I met my wife at the Toyota dealer and added a new addition to the family. 2016 4Runner.
    ChadsPride and bigfoote13 like this.
  20. Mar 27, 2016 at 7:28 AM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    Jeez... sounds like a "stay away from GY Authorities" story. Great to hear the problem was found.
