My truck looks pissed!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd, Mar 18, 2008.
  1. Mar 20, 2008 at 11:52 AM
    #41
    nd
    nd [OP] Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Probably never will. I dont care about making it louder. if i ever get exhaust it will be after i pay it off and it will be part of a whole airflow upgrade (headers, intake, and exhaust). but i wont do exhaust unless i do everything.
    thats true, at this very moment my truck woudl completely dominate you're offroad :) Can you drive yours at all right now?
    Thanks Mark, i cant wait for the rims either :)
  2. Mar 20, 2008 at 11:58 AM
    #42
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Nope. I don't even have a gas tank yet. The poor thing hasn't been started since September of last year! :(
    I have been driving around in a 1995 Honda Civic that I picked up for $500. I'd put that up against your truck simply because I have the "I don't care" factor going for me! :D
  3. Mar 20, 2008 at 12:32 PM
    #43
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    It's a Civic.... Who would really care anyway? :laugh:
  4. Mar 20, 2008 at 1:08 PM
    #44
    nd
    Nate
    Greenville, SC
    unfortunatley for me i have that same mentality. i dont think i need to remind you of how i got my truck stuck the night after buying it or how i recklessly slammed it into a tree.... not to mention all the other random scrathes all over it
  5. Mar 21, 2008 at 10:52 PM
    #45
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I'm not following the more compressed and harsher ride part? I'm looking at pictures, but it seems you get the lift by moving the shock body down by where the ring is set in relation to the coil. But the bottom of the coil to the top attachment point shouldn't change, as in compression of the coil, should it? I mean the piston or movement part of the shock is between the collar on the shock body and the upper attachment point and the coil length shouldn't change as I see it. If I'm looking at this wrong it's just my company tonight, Mr. Jim Beam. Later ;)
  6. Mar 22, 2008 at 6:34 PM
    #46
    4x4x4trd
    North Texas
    Thanks for spending my money too. I ordered all four from Down South for $259 to the door. I don't know if I'll try this install myself as I'll need an alignment afterwards anyway. I'm guessing that you used your stock coils in this setup with the 5100's? Thanks and later. ;)
  7. Mar 24, 2008 at 8:26 AM
    #47
    nd
    Nate
    Greenville, SC
    Yes i did use stock coils. Let me explain the compressed spring since i didnt understood how it worked until i actually started playing in the wheel well. There are 4 grooves pre-cut into the shock with an aluminum c-ring that you can move up and down the shock to adjust the height. At STOCK height, that c-ring is closest to the bottom of the shock. the coil seat plate then simply slided down the shock and rests on teh c-ring, and that plate is where the bottom of the spring rests. if you want to go higher, you move the c-ring UP the shock. when you do this there is less room for the coil to extend. Every time you move the c-ring, and seat plate up, you are decreasing the amount of space that your coil can occupy, therefore making it more tightly coiled and more "loaded". its kind of hard to explain while typing. it would be much easier if i could draw this out. But to summarize, to increase height, you move teh coil seat UP the shock. every time you do that you are compressing the space where the coil sits. Make sense at all? Like i said, i didnt understand how this works until i started playing with it myself. although i didnt install the shocks myself. i started to (i actually spent 4 hours inside my wheel well trying to figure out how to do it without the right tools) but ended up taking it to a local shop to have it put in. even though i didnt do it myself, i had plenty of time to get aquainted with how everything works.
  8. Aug 10, 2008 at 1:30 PM
    #48
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
  9. Aug 10, 2008 at 2:57 PM
    #49
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    lol,30 days on the wagon isn't enough to cover t/c uca's. :) How ever,60 or 90 days would.:D
  10. Aug 10, 2008 at 3:27 PM
    #50
    Jumpmaster
    Jumpmaster Proudly Serving
    USAG Humphreys, Korea
    Remember, even if you don't want or need to raise the front of your Taco up the full 2.5 you don't have to. Heck, you can keep the stock setting if you really want to, but what I like is you get a much better overall shock/strut then OEM (Bils). These are a bit stiffer, but they really help reduce nose dive during braking and body roll when hitting thos off ramps ;). I had a set of 5100s on my F150 FX4 and noticed a big differance over the crappy OEM ones. So I looked at it like killing two birds with one stone. Raised my front a couple of inches and recieved a better ride overall compared to the OEM shocks. Food for thought brother.
  11. Aug 10, 2008 at 4:46 PM
    #51
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
  12. Aug 10, 2008 at 8:05 PM
    #52
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Thanks for the help but I'm way ahead of the game compared to 5 months ago when I posted that. ;)
  13. Aug 10, 2008 at 8:51 PM
    #53
    Wood
    Wood Well-Known Member
    That's where mine are set.....looks just right. Also gotta remember your rear may settle some time after getting the TSB done.
  14. Nov 4, 2015 at 8:17 AM
    #54
    dtay4197
    dtay4197 Well-Known Member
    Dustin
    silver 2007 trd offroad
    2.5 bilstiens, colormorph retrofit halos and fogs, urd maf cal, Urd tcai, 20x12 mo962, 33x12.50x20 iron man mts
    Could I do 5100s in front and just not touch the back?
  15. Nov 4, 2015 at 8:24 AM
    #55
    mjp2
    NJ
    Wow you found an OLD thread here, but yes to your question about the 5100s.
    dtay4197 likes this.
  16. Nov 4, 2015 at 8:48 AM
    #56
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    For the HORDE!!!!!!!
  17. Nov 4, 2015 at 8:57 AM
    #57
    Gutierrez90
    Gutierrez90 Well-Known Member
    San Diego
    2007 fj cruiser TRD
    In progress
    Hahahah
