My Truck Overheats Help!
Discussion in 'Technical Chat' started by robbie2013, Jul 2, 2014.
  1. Jul 2, 2014 at 6:26 PM
    robbie2013
    robbie2013 [OP] New Member
    I have a 2013 TRD with a 6 speed manual.
    Hey can anyone offer some holiday help?? I am traveling from Canada down to Nevada and at highway speed 75mph with the air conditioner on and the outside temperature in the 90s my temp gauge is climbing pat the ¾ mark.
    If I keep the air off and do 65 ish I can keep the temp gauge slightly above normal??
    Any thoughts??
    Thanks for your help!!
  2. Jul 2, 2014 at 6:31 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I remove the rubber gasket under the hood near the base of the windshield to let the hot air out (or cooler air in) during the summer.
    I think as long it the temp doesn't go into the red, you are ok.
  3. Jul 2, 2014 at 6:31 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    could be a thermostat..
  4. Jul 2, 2014 at 6:39 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^This.
    Also check:
    Is your coolant level low?
    Is the radiator fan spinning at full speed when you first start the engine (indicated by loud fan noise)?
  5. Jul 2, 2014 at 9:43 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    I live in Arizona and have driven my truck doing 85 MPH with air on full blast in 110 degree temp without overheating. Something is up with your truck.
  6. Jul 2, 2014 at 10:13 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    My Ultragauge is always between 199 and 204, and the temp is not dependent on ambient temp or speed or AC use.
  7. Jul 3, 2014 at 6:38 AM
    robbie2013
    Thanks Everyone,
    I am trying to get it into a dealer today and see. I am running regular gas and was wondering if anyone thinks this may contribute? In Calgary we are 3500 feet above sea level so it may not have affected me up there?
    Thanks!!
  8. Jul 3, 2014 at 7:00 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Do you play in mud? is your radiator clean? Only first hand issues Ive seen with overheating were due to clogged radiators.
  9. Jul 4, 2014 at 7:41 AM
    robbie2013
    Ya I do play in the mud but the rad was the first thing I tried. I found a Toyota dealer in Helena MT and it turns out my rad cap is bad and my thermostat is bad and I was low in coolant but because of the bad rad cap it was not pulling it out of my overflow.
    It’s a cheap fix but they don’t have parts and because of the holiday it will not be fixed until Wednesday. So we carry on in a rental.
    Thanks for your ideas.
  10. Jul 4, 2014 at 7:43 AM
    XXXX
    sKiP
    05 Prius
    Oh that sucks, but at least it's not a major issue. Glad to hear the trip continues on!
  11. Jul 4, 2014 at 10:22 AM
    Tmill
    Tmill Well-Known Member
    Tyler
    Florida Panhandle
    07 Sport Black DCLB
    Isn't it warrantied?
  12. Jul 4, 2014 at 2:53 PM
    KenLyns
    Belly of the Beast
    ^Probably why robbie2013 is in paid-for rental.
  13. Jul 4, 2014 at 2:59 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Those are pretty basic parts not to keep in stock....
  14. Jul 4, 2014 at 3:14 PM
    KenLyns
    Belly of the Beast
    ^You'll be surprised how poorly stocked most Toyota dealers are. When I got my steel braided brake lines installed, I wanted to get new clips - a universal part used on every Toyota since the 1980s, yet the dealer had to order it with next-day ETA.
  15. Jul 4, 2014 at 3:23 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Thats crazy.
  16. Jul 5, 2014 at 7:46 AM
    robbie2013
    Yep, the truck is under warranty but its Toyota Canada warranty and we are broke down in America. The guys at the dealership walked me through how to deal with it. I pay for everything down hear and then submit the bill when I get home. Hopefully it will all be take care of.
    I was also shocked that they did not have the parts. But they how must go on…..
  17. Jul 5, 2014 at 8:50 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Glad it's nothing major...but u can drive the hell out of the rental car :)
