My truck rides like shit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrothwell, Dec 2, 2014.
  1. Dec 2, 2014 at 5:39 AM
    mrothwell
    mrothwell [OP] Well-Known Member
    Raleigh, NC
    2014 4x4 V6 TRD Sport 6-Speed!
    Bone Stock.
    Its a 2012 Access Cab with the updated leafs, I bought it that way. It rides like a 3/4 ton truck, the bed bounces when you go over any significant bumps. It rides a whole lot better with stuff in the back, but I'm thinking that carrying around sandbags just to make the ride better is not a good solution to the problem.
    What can I do to make the truck ride better but:
    -Not cost a fortune
    -Not lift the rear
    If the solution reduces load capacity, I'm okay with putting in air bags to level the truck when its loaded. I generally don't have more than ~500 pounds in the truck bed.
    So TacomaWorld, what do you suggest?
  2. Dec 2, 2014 at 5:45 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Better shocks and fuck it keep weight back there.
  3. Dec 2, 2014 at 5:58 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    welcome to the world of light trucks and leaf springs!
  4. Dec 2, 2014 at 6:03 AM
    mrothwell
    Raleigh, NC
    Bone Stock.
    Its the 3+1.
  5. Dec 2, 2014 at 6:03 AM
    mrothwell
    Raleigh, NC
    Bone Stock.
    Any suggestions?
  6. Dec 2, 2014 at 6:07 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    5100 on a budget. wheelers has the rear set for $143. and if u wanted to get matching front i think they are $170 for the adjustable ones if u wanted to level it out
  7. Dec 2, 2014 at 6:10 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    What tire pressure are you running? When I got my Duratracs I aired up to 42 and the backend was all over the place going over bumps (especially over bridges). Took the pressure back down to 34ish and it rode a lot better.
  8. Dec 2, 2014 at 7:21 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    set tires to 32 psi
    slacken ubolts to 44 foot lbs each
    it will soften the ride a tiny bit...but it's a truck and should drive like a truck
    I have the TSB leafs and it stiffened it up quite a bit but...truck, right ?
  9. Dec 2, 2014 at 7:30 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    OEM springs with Firestone RideRite air bags at 5 psi - rides great.
  10. Dec 2, 2014 at 7:30 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    you could take out a leaf if you don't haul much..
  11. Dec 2, 2014 at 7:40 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Ummmmm, what?
  12. Dec 2, 2014 at 7:43 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Use TW to find a local member who doesn't have the TSB leaf pack who'd like to swap with you.
  13. Dec 2, 2014 at 8:07 AM
    AG87BlkLX
    AG87BlkLX Well-Known Member
    Andy
    Greenbrier, TN
    How does this help the ride?
  14. Dec 2, 2014 at 8:09 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    remove the overload.. if thats too soft.. add a basic 3 leaf pack..
    note: you wont be able to haul much weight.. but you will have your soft ride.
  15. Dec 2, 2014 at 8:09 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Lower the air pressure in the tires (mostly the back ones)... that is the simplest and cheapest mod to improve your ride!
  16. Dec 2, 2014 at 8:12 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this as well..
    i think Im at 45 front, 30 rear
  17. Dec 2, 2014 at 8:20 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    44 foot lbs is the specification for ubolts on the 3+1
    if they are at 70 or 80 now, loosening to 44 will allow them to flex
    a tiny bit more and they will be a smidge more bendy and complaint
    crank the hell out of them to 80 and it stiffens the rear a bit
    so....going down to 44 allows a little more flex and remains inside the
    toyota spec. it may change the ride. it may not.
    anyhow that is what my idea is based on....
  18. Dec 2, 2014 at 8:25 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I think what you meant is to remove the additional third leaf.
    The "overload" is that short big flat one at the bottom that keeps the leaf pack from going into negative arch. Removing that won't help the ride.
  19. Dec 2, 2014 at 8:30 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    no I meant the overload.
    For example.. The Icon 3 leaf progressive pack.. I had that previously on my factory pack.. Icon says to remove the overload, and in its place, install their 3 leaf pack.. yields 1.5" of lift, smooths the ride, but decreases the payload capacity.
    it definitely was smooth.. but too smooth imo.. wouldnt hold weight for shit, but rode great.. that is until the entire pack wore out.. but.. thats because of no overload + plus me still carrying weight. If OP isnt carrying weight, he might be ok.
  20. Dec 2, 2014 at 8:42 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    just get a sick ass LEER shell and call it a day
