My truck rides like shit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrothwell, Dec 2, 2014.
  1. Dec 2, 2014 at 8:58 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    200 lb Leer helped my truck. Losing the worn out BFG T/A KO brick tires and putting on some Michelin all seasons really helped it.
  2. Dec 2, 2014 at 9:02 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Would one not assume that Toyota set the U bolt torque to the OEM specs when they installed the TSB springs ?
  3. Dec 2, 2014 at 9:52 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ^^^who knows ?
    anyhow...here is a little link describing all the functions ubolts have in
    keeping the springs tight and fixed in place, or allowing some movement
    http://www.suspensionspecialists.com/tech0004.html#4
    Toyota must have decided the specs they use (which people think is way too low) are the sweet spot between centering pin wear and spring sliding, vs keeping it all tight and fixed in place, and ride quality. super tight will result in stiffer springs since they won't be able to slide as much and bend as much at the axle
  4. Dec 2, 2014 at 10:01 AM
    OZ-T
    Peter North
    British Columbia
    In your response you seemed to be assuming that his were higher that's all
  5. Dec 2, 2014 at 10:42 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I agree that adding a bit of weight in the back end does help the ride quality quite a bit. However, there are pros/cons with adding weight so to each their own!
  6. Dec 2, 2014 at 10:50 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Sensatrac shocks. My 3/4 ton diesel's shocks were shot when I got it and rode like an old hay wagon, put sensatracs under it and it rides like new. Doesn't jar me to hell and feels comfortable on the road, the shocks soak up the bumps with ease.
  7. Dec 2, 2014 at 10:57 AM
    mrothwell
    mrothwell [OP] Well-Known Member
    Raleigh, NC
    2014 4x4 V6 TRD Sport 6-Speed!
    Bone Stock.
    It's my understanding that the overload doesn't really do anything until you, well, overload it. I guess I'm wrong?
  8. Dec 2, 2014 at 10:59 AM
    OZ-T
    Peter North
    British Columbia
    The overload helps keep the leafs from going into negative arch and support them when loaded
  9. Dec 2, 2014 at 11:00 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you just dont have an opposite arched leaf fighting against the progressive leafs when articulating, flexing, etc. of course its most noticeable when loaded.. or over larger bumps like speed bumps.
  10. Dec 2, 2014 at 11:16 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    righto !
