My truck scared the shit out of me
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiemsnox, Oct 29, 2011.
  1. Oct 29, 2011 at 7:33 PM
    Hiemsnox
    Hiemsnox [OP] Well-Known Member
    Dan
    Beavercreek, OH
    06 DCSB TRD Offroad Indigo Ink
    So i recently did the Fog Light anytime mod, its been a couple of weeks now and so I'm at my friends house for a few hours now and someone comes up to me and tells me my lights are on... i walk outside and my fogs are on.... my truck is locked and i haven't touched it for a few hours.
    the only thing that i can think of is temperature drop, i did the mod which moves the pin in the fuse box.
    im a little freaked out how the lights got power cause it is on a switched power supply, i unlocked my truck and pushed the switch and the lights turned off, then tried turning them on again. they didn't turn on like they should..
    HELP!!! lol
  2. Oct 29, 2011 at 7:36 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Its one of the things you chance with this mod.
  3. Oct 29, 2011 at 7:38 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Did they turn on momentarily? If so then it's a normal result of this mod. (search: there are other ways of doing it so this doesn't happen)
    If they came on and stayed on, then maybe go back and retrace your wires.
  4. Oct 29, 2011 at 7:39 PM
    Hiemsnox
    Dan
    Beavercreek, OH
    this is the first time this has happened, the mod has been done for a while
  5. Oct 29, 2011 at 7:45 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    If you leave the fog light switch on the "on" position. You're fog lights will turn on when your truck does its fuel system check after sitting for a few hrs.
    Just depress the fog switch. to "off" when you exit your truck and you'll be fine.
  6. Oct 29, 2011 at 7:45 PM
    Bishop2Queens6
    SoCal
    2009 DCSB MGM
    ^^^This is a result of the fog light anytime mod.
  7. Oct 29, 2011 at 7:48 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    A little strange that it happened once. There is a wire you can easily confuse when you do this that results in the fogs LITERALLY being on all the time where you have to turn the switch off every time you turn the truck off or they would just stay on. But since this is the first time it's happened it's obviously not that. I've had mine done for nearly 2 years and I've never noticed mine randomly coming on. Then again, I guess I wouldn't since I don't keep the switch on.
    But, as the others have mentioned, apparently this is "normal" if you keep the button pressed in all the time. Just keep it off and push it when you want to use them.
  8. Oct 29, 2011 at 7:48 PM
    Hiemsnox
    Dan
    Beavercreek, OH
    thank you, i guess ill have to leave the switch off,, i liked being lazy and have them on all the time :)
  9. Oct 29, 2011 at 7:52 PM
    FY01CPO
    FY01CPO Well-Known Member
    Jeremy
    CT
    SR5 4x4
    black tube steps, side marker turn signals, 15% tint and window strip, EGR vent shades, fighter pilot/cockpit mod, console and glove box auto on LED, anytime fog light mod, 3000k HID fogs, bed mat wing nut mod, locking bed storage bin mod, smoked tail lights, plasti-dipped rims, blacked out emblems, black tail pipe, tail gate hose clamp, rear seat utility/dog shelf with rear center console access door.
    The fog light anytime mod where you bend a prong of a relay and use about 6" of wire to connect to a power source under the hood can do this? I guess I will have to start turning mine off too if so.
  10. Oct 29, 2011 at 7:52 PM
    ouyin2000
    Arlington, Virginia
    '11 DCSB TRD Sport
    Only if you do it "a la caribe" style
  11. Oct 29, 2011 at 7:57 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    No, this method does not have the same problems. Mines been done for several months this way with no problems, and yes I do leave my switch on sometimes with no worries.
  12. Oct 29, 2011 at 7:59 PM
    FY01CPO
    Jeremy
    CT
    SR5 4x4
    Phew.
  13. Oct 29, 2011 at 8:06 PM
    Nubes
    Nubes Tacoma Addict
    Texas
    2011 Silver TRD O/R DCSB PreRunner
    Gray WeatherTech's front and back, DeeZee bed mat, Foglight Mod, Magnaflow 12256, Debadged, Ammo Can Storage Boxes, Shrockworks Sliders.
    Also if you do the version where you tie into the towing relay they wont come on, but the downside to that is that you have to turn on your parking lights to have the fogs on. It's not exactly a "anytime fog" b/c fogs won't come on without at least the parking lights but I prefer it because its fused and as soon as my lights go off the fogs are off and will stay off.
    http://www.tacomaworld.com/forum/lighting/132862-fog-lights-w-parking-low-beam-high-beam.html
  14. Oct 30, 2011 at 12:09 AM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    I have the relay bending with 5amp fuse moddy thingy done... I never turn my switch off and a few times I caught the fog lights turning themselves on for a minute or two. It doesn't bother me since it would take more then 60-120 seconds of fog lights on to drain the battery, especially since it's daily driven. But I can imagine if I'm going to park it for a week or so to turn off the switch...
    On a side note, The first time I did catch it was when I was having a cig in my garage (don't smoke in the house) and they turned on... I had a deer in the headlights reaction (thinking "aw crap!") since I forgot about the side affect for a second.
  15. Oct 30, 2011 at 2:45 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    One thing it could be and I found out my truck does this (I do not have the anytime mod).
    If your truck is running and the drivers side door is closed. If you open the passenger door, turn your truck off with the lights still on, close the passenger door, lock the truck but never open your driver side door the lights never turn off and will sit there with all your lights on draining the battery.
    Is it possible you did this?
  16. Oct 30, 2011 at 4:07 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    As said before this is a side effect of doing it a la caribe style. The truck sends power to the ignition rail for 1-2 minutes doing a fuel check or whatever. After that time they will go off. The power drained from the battery during this time is very little, and I wouldn't worry about it unless you have a bad battery/alternator, or rarely drive the truck. I leave mine on all the time and have yet to have an issue.
  17. Oct 30, 2011 at 7:13 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    It never happen on mt truck, and I do that mod more than two years.
  18. Oct 30, 2011 at 7:23 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    A crappy side effect from the mod, by using the emissions\ fuel circuit to trick the fog relay. If you use the green wire (ignition circuit) instead this will not happen.
