My truck threw TEN codes this morning.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RJALLDAY702, Feb 21, 2013.
  1. Feb 21, 2013 at 6:23 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I mentioned this before but will repeat. before you spent any money clean Charcoal Air filter. If this filter is clogged you will get random errors and yes bad fuel mileage will follow.
  2. Feb 21, 2013 at 7:03 PM
    sde780
    sde780 Well-Known Member
    EVAP canister is emissions BS that shouldn't affect how your car runs.
  3. Feb 21, 2013 at 8:10 PM
    RJALLDAY702
    RJALLDAY702 [OP] U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Where can I find this filter you speak of
  4. Feb 21, 2013 at 11:04 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Have you ever seen me cruzing around? youre the first TW member ive heard of down here!
  5. Feb 22, 2013 at 9:59 AM
    BlueT
    NorthEast
    I send you PM Taco'09 just cleaned his and it was dirty too. I would start with that before spending any money. Check al lthe hoses while you under there.
  6. Feb 22, 2013 at 7:35 PM
    Taco'09
    Taco'09 Well-Known Member
    BlueT is correct about this.
    I was doing the rear differential breather mod and dropped the spare tire for more room. There staring at me was that filter next to the charcoal canister. I PMd BlueT with a couple of questions about the filter and ended up taking it off and blowing air both directions through its two ports.
    WOW! :eek: What a dust bowl. I filled the atmosphere in my garage with all the dust collected in that thing. Don't spend big money on a charcoal canister until you check out whether that filter is restricted/full of dust. Hats off to BlueT. Check the hoses too.
  7. Feb 22, 2013 at 8:18 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Thank you! Time to check this tomorrow! Mine is throwing the codes when cold...
  8. Feb 22, 2013 at 10:44 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    But it will.
    Overfilling the tank will cause fuel to contaminate the charcoal canister.
    When the evap system opens the purge valve, rather than drawing vapor from the canister into the intake, it will draw raw fuel, causing it to run rich, which will generate additional codes and impact mileage.
  9. Feb 23, 2013 at 12:13 PM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    I crept on your taco build thread. Dont think i have seem your ride around. Ive got a swb taco with blacked out moto 951s and a 5' firestik in the bed.
  10. Mar 21, 2013 at 11:54 AM
    nfs257
    DFW
    She gone
    Hey RJ any solution yet? Still throwing mine... :pout:
  11. Mar 21, 2013 at 12:42 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Nope, Mine came back on too. My guess would just be put a new canister in there. Gonna be hard for me because Im going to have to drop the tank cause I am certainly not going to cut out my bed cage!
  12. Mar 21, 2013 at 12:46 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Do you have a pic of said filter? I'm under here right now and don't see any filter
  13. Mar 21, 2013 at 12:48 PM
    nfs257
    DFW
    She gone
    Run it dry and use a floor jack with 2x6 to lower it out.
    Im gonna try to clean the filter that was mentioned above...
  14. Mar 21, 2013 at 1:43 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    I would do the same if I knew where said filter was
  15. Mar 21, 2013 at 3:43 PM
    #35
    xyourlocaldjx
    damn you guys! now i want to go clean this filter too.
  16. Mar 21, 2013 at 3:54 PM
    #36
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Right?! So where is this infamous filter :mad:
  17. Mar 21, 2013 at 4:17 PM
    #37
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    its in the stock intake box
  18. Mar 21, 2013 at 4:39 PM
    #38
    xyourlocaldjx
    Thats a different one. I ripped mine out. We are talking about a canister.
  19. Mar 22, 2013 at 5:08 AM
    #39
    BlueT
    NorthEast
    Did you got my link I sent you. It shows location of the filter. I dont have picture just look at the document.
  20. Mar 22, 2013 at 5:10 AM
    #40
    BlueT
    NorthEast
    You dont need to remove the tank to clean Charcoal filter.
    Sendign you pdf that shows location of it. Its attached to Charcoal Canister which is next to tank.
    Np Sir :D
    That should save tons of money for people. Many think its overfilling of the tank, but I think overfilling only dumps fuel to charcoal if that charcoal filter is clogged.
