My truck Wont Drive When in D!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by mendezvinner, Mar 17, 2017.
  1. Mar 17, 2017 at 7:56 AM
    mendezvinner
    mendezvinner [OP] Member
    Vinner
    2001 Toyota Tacoma 4X4
    Hello Guys, So I have a very unusual problem. I just bought a 2001 Toyota Tacoma and it has driven fine for the last two weeks. One day when I was leaving work, I backed out and then put it in Drive, hit the gas, and it felt as it was just in neutral and the truck barely moved. Tranny Fluid level is good. I then turned my truck off, turned it back on, put it in drive and it took off perfectly fine. It has been doing this for about a week now and I have to turn it on, turn it off, ad turn it back on for the truck to actually drive!! This is driving me nuts because I cannot figure it out!
    Someone Help Please!!!!!
  2. Mar 17, 2017 at 8:15 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
  3. Mar 17, 2017 at 8:25 AM
    KevinTaco98
    KevinTaco98 Well-Known Member
    Kevin
    1997 3.4L Tacoma
    None yet :D
    I have a silly But it happened to me in my manual trans when I was learning how to drive and caused me to stall a few times.
    Just to rule this out, was your ebrake on?
  4. Mar 17, 2017 at 9:33 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Fluid level is good? What's the color/consistency?
  5. Mar 17, 2017 at 10:34 AM
    mendezvinner
    Vinner
    My fluid was pink and it was not low, my handbrake was off and I didn't feel anything stopping it, it just feels like its in neutral. When I hit the gas, the rpm's go up but the truck barely rolls.....
  6. Mar 17, 2017 at 10:37 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Sounds like your shifter lever is loose.
  7. Mar 17, 2017 at 10:38 AM
    cruiserguy
    Elijah
    SEKS
    And then you turn off and restart the truck and it accelerates like normal? If so, I'm thinking it's gotta be something electronic or electrical.
  8. Mar 17, 2017 at 10:39 AM
    mendezvinner
    Vinner
    Yes, when I turn it off and then turn it back on, it runs perfect. Its just irritating having to start it up twice.
  9. Mar 17, 2017 at 10:40 AM
    cruiserguy
    Elijah
    SEKS
    Yeah man of course, that's definitely not normal and would be irritating. Plus the additional wear on the starter.
  10. Mar 17, 2017 at 1:56 PM
    mendezvinner
    Vinner
    Do you think it would be the transmission at all?
  11. Mar 17, 2017 at 2:42 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Try moving the shifter slightly, maybe it's not engaged in the gear showing in the prndl
  12. Mar 17, 2017 at 6:05 PM
    03tacobull
    03tacobull Member
    Georgia
    2003 Prerunner
    I'm having a similar issue with mine. It seems to get stuck in D2 and revs high but won't go over 45. I usually just have to go into neutral and back to drive.
  13. Mar 17, 2017 at 6:11 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    have u tried running thru the gears before you turn it off then back on again? play with the shifter a little see if theres a sweet spot to get it to engage? I would be leaning towards more like what @Hondah said. loose shifter lever maybe?
