My Truck Won't Start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cows Have Claws, Apr 9, 2020.
  1. Apr 9, 2020 at 8:07 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Found your problem ....its a 3rd gen:)
    BillsSR5 likes this.
  2. Apr 9, 2020 at 8:09 PM
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
    Even after sitting for a month, a battery that new shouldnt be THAT dead... And those Pros didnt sit on dealership lots for very long if im not mistaken. I'd roll by the dealer and show em the video, let them load test it. Batteries in the past 5-10 years have drastically gotten worse and worse
    Junkhead and shakerhood like this.
  3. Apr 9, 2020 at 8:27 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My car was just sitting for 2 months and 8 days and fired up as if it had only been sitting overnight, but it definitely does not have a shitload of electronics.
    Junkhead and Rockefelluh[QUOTED] like this.
  4. Apr 9, 2020 at 8:31 PM
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
    I work on fleet vehicles with lightbars, multiple high power 2way radios, camera equipment, laptop chargers, printers, you name it... sometimes they start after sitting for a month, sometimes they nuke a new battery in a matter of weeks. The only thing we could ever draw upon was inferior battery quality.
    Bleep100, shakerhood and Rockefelluh like this.
  5. Apr 9, 2020 at 8:47 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Check the battery levels. turn your headlights off when starting if the battery is low. Get a trickle charger, which is what a battery tender does. Some battery chargers have a trickle function. If it doesn't don't leave the charger on too long.
  6. Apr 10, 2020 at 6:26 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    RrmBWfm8GwDA-PHqQB13-f2FfijVvel4dK3dFSFP_cf0308c80df45aae9267816b6303f569e8f3b02b.jpg
    auskip07 likes this.
  7. Apr 10, 2020 at 7:01 AM
    Markc1024
    Markc1024 Well-Known Member
    Looking at your prior posts, you were going to install a CB radio and tap into other circuits. Did you go ahead? Is so, I'd revisit what you actually tapped into as that might be your source of drain.
  8. Apr 10, 2020 at 7:05 AM
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    Solid chance the battery is now unreliable/toast. Lead acid batteries do not do well with full or near full discharges.
  9. Apr 10, 2020 at 7:08 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Very good point!
  10. Apr 10, 2020 at 11:05 AM
    Herniator
    Edmonton
    Does your CB radio turn off with the ignition? Looks like it is taking power when the truck is parked. Try disconnecting the CB and see if your problem goes away.
  11. Apr 10, 2020 at 12:12 PM
    Cows Have Claws
    Cows Have Claws [OP] Well-Known Member
    Oregon
    2024 Tacoma Trailhunter 6ft
    I havent installed it yet! Still gotta get that tap-a-fuse. Right now its stock, no mods, nothing crazy. I did install some LED's to replace the factory cabin bulbs but thats it!
  12. Apr 10, 2020 at 12:21 PM
    FirsandFire
    FirsandFire Well-Known Member
    New York
    No more Taco. A 2500HD and a Bronco sport
    The OEM batteries in these trucks are garbage. Mine died with 5k on the clock. If you send the receipt to Toyota corporate they will reimburse you.
  13. Apr 10, 2020 at 12:34 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Woah!! . . . "I did install some LED's to replace the factory cabin bulbs but thats it!" You didn't say that at first.
    If you in ANY WAY screwed with the stock electrical system, the mystery deepens. That includes LED bulbs!
    Do a quick search to hear the heartbreak of LED's.
    G.
    Chew likes this.
  14. Apr 10, 2020 at 3:54 PM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    yeah if anything was changed out it is no longer stock. So switch those back out. Get a new battery to be safe. Stop cowering inside and go drive your truck. You aint getting the virus in your car.
    Chew and Garyji like this.
  15. Apr 10, 2020 at 4:00 PM
    #35
    DR TACO
    DR TACO Well-Known Member
    Denny
    Fort Mohave
    2019 Tacoma Off Road 4x4 Double Cab
    Pro grille, POD lights, SEMA wheels.
    Lol
  16. Apr 10, 2020 at 4:03 PM
    #36
    DR TACO
    Denny
    Fort Mohave
    A jump start won’t charge your battery. Mine is pretty new, and my battery has drained also, because of infrequent short trips. Slow drains, and use like I described is not good for your battery, and will kill it. Heat is not good either.
  17. Apr 10, 2020 at 5:37 PM
    #37
    B33
    B33 Well-Known Member
    2017 tacoma TRD Sport
    I would bet you have a bad battery my 2017 Died at the 24mo mark . I don't know what toyota is doing but there messing up
    my 2014 FJ went 4 years on the same Factory Battery both the FJ and the Tacoma sit 90 days at a time I know this is not the best for them but I don't have much of a choice I wish the Tacoma Battery was a Panasonic like the FJ
  18. Apr 10, 2020 at 6:06 PM
    #38
    JK2TACOma
    JK2TACOma Well-Known Member
    Michigan
    19 TRD Sport DCSB Super White
    Sliders, Roof Rack, Bed Rack, Clear Coated Frame(diy) & Waxed Alot!
    Yeah things are different on these Tacoma's. They have many items that do systems checks, fuel line pressure and leak checks all on there own.. have to keep on tender or drive to charge up.
  19. Apr 10, 2020 at 6:10 PM
    #39
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Can’t even deny this I’ve had my 2019 for a year I miss the fuck out of my 2010 such a better motor and trans I put that poor girl through hell.
  20. Apr 10, 2020 at 6:22 PM
    #40
    shakerhood
    Southern Ohio
    I had 2 prior 2nd Gens before my 3rd, as much as I liked those trucks I wouldn't go back.
    Chew, Herniator and Bleep100 like this.
