My turn!
Discussion in 'Wheels & Tires' started by DanGer, Jun 21, 2009.
  1. Jun 21, 2009 at 6:51 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I have read all I can on wheels, but when it comes down to it I am still fuzzy on the bs vs offset relationship. Do I need the first or the second option? I want to match, or come as close to the stock specs as possible
    They are both 16x7 and it comes down to
    4" BS, 0mm offset vs.
    4.5" BS, 13mm offset
  2. Jun 21, 2009 at 7:23 PM
    DanGer
    That is what I thought. In my research I saw that stock was 4.5" bs with 12mm offset, then I read the 12mm offset cancels out the bs and wound up :goingcrazy::annoyed:
    So I sucked up my pride and decided to ask!
    Thanks for the reply!
  3. Jun 21, 2009 at 9:18 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    i got the trd wheels...they are 16x8 with 4.5 bs and 1mm offset....i have no idea of the offset and bs of the stock steel wheels.....but the wheels i got fit perfectly with 265/70/16 tires...keeps the same diameter as stock so your speedo is right...just gives you a wider tread and looks way better...zero rubbing...no lift needed
  4. Jun 21, 2009 at 9:27 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    backspace is the distance between the back lip of the wheel and the mounting surface.
    Offset is the distance of the mounting surface from the centerline of the wheel. neg offset will push the wheel out, positive will tuck the wheel into the fenderwell closer.
  5. Jun 21, 2009 at 9:32 PM
    RelentlessFab
    Eric
    Sparks, NV
    a while back I asked Chris what the specs were of the factory wheels and he said it was 5.5" BS, and they're 7" wide iirc.
    The closest to stock of the ones you had listed is the 16x7 and +13 offset, 4.5" BS
  6. Jun 22, 2009 at 10:30 AM
    DanGer
    Thank you all for your responses! This will move my secret wheel project along nicely :spy:
    All I need is to sell my FJ wheels so I can buy these, and wait for my stocker tires to wear down a wee bit more!
  7. Jun 22, 2009 at 11:05 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I hate suprises! :D Be sure to post pics when everything is done!
  8. Jun 22, 2009 at 12:47 PM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    alright dgerm, you need to spill the beans on the project. It has been 1 hour and 16 minutes since you stated you have a secret project and my patience has been tested.
  9. Jun 22, 2009 at 12:52 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    this goes well with ur wheel spacer thread. u ask ur professor and made it seem like wheel spacers are bad, but now your getting -4.5" backspacing, which is not that much of a difference than the wheel spacers, the spidertrax will equal to a -4.25" backspacing
  10. Jun 22, 2009 at 1:09 PM
    DanGer
    Yes, but the engineers of the truck used factory wheels with backspacing. The point of my post is to find the wheel specs closest to stock---closest to how our trucks were designed to perform
  11. Jun 22, 2009 at 1:17 PM
    tacoskim
    Los Angeles, CA
    Stock
    i know im not hating, but im just saying its kinda funny that u were proving the "dangers of wheel spacers" and now ur pretty much doing the same thing, thats all
  12. Jun 22, 2009 at 1:24 PM
    DanGer
    I am not doing anything like wheel spacers. The entire point of me asking my question is to get wheels that are closest to the factory specs...Not try and increase the load on my hub in order to get a better look. I want the exact opposite of wheel spacers
  13. Jun 22, 2009 at 1:26 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea u getting wheels with -4.5 backspacing is pretty much the same thing as getting wheel spacers that equal to -4.25 backspace.... factory is 5.5
  14. Jun 22, 2009 at 3:13 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea i see what your saying, the spidertrax is more like an adapter than a spacer so not worried bout extra stress since its got its own lugs and torqued to spec
    EDIT: The Spidertrax ones get torqued in place and the wheels are attached using built-in wheel studs, which is the right way to do it. It eliminates potential slop and keeps bad things from happening.
  15. Jun 22, 2009 at 3:29 PM
    tacoskim
    Los Angeles, CA
    Stock
    all im simply stating is that with the OP new wheels with -4.5 backspacing is still gonna cause pre mature wear to the wheel bearings (as he was stating in his other thread) the same as the spidertrax spacers with -4.25 backspacing will
  16. Jun 22, 2009 at 3:54 PM
    DanGer
    Thank you tacoskim! I was under the impression that factory were 4.5 BS, thats where we I was misunderstanding and we were not seeing eye to eye on it
  17. Jun 22, 2009 at 3:57 PM
    tacoskim
    Los Angeles, CA
    Stock
    All good! its hard to communicate on forums
  18. Jun 22, 2009 at 8:07 PM
    DanGer
    Haha, You will have to wait about 10-20 K miles until my tires are worn out, or if I sell my FJ wheels. Whichever comes first
  19. Jun 23, 2009 at 6:44 AM
    TacoTycoon
    Justin
    Hayes, VA
    Epic Fail for me haha
