My U-Bolts were loose after warranty work and 1.2 years time!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Feb 23, 2011.
  1. Feb 23, 2011 at 2:50 PM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    While fueling up my truck this Monday I did my usual walk around and inspected the truck. My jaw dropped when I found a U-bolt about to come off the last threads of the bolt! They were all loose! I tightened them by hand and then drove to a parking lot and wrenched on them with a socket set I had with me.
    The next day I bought a torque wrench and torqued them down to 80 ft/lbs. The drivers side was extremely loose. The passenger side was not torqued correctly, and they turned several rotations before hitting 80 ft/lbs. I don't know if 80 ft/lbs is tight enough but I'll check them again in 100 miles.
    I had the rear spring TSB work done in late 2009. I wonder if the mechanic who did the work followed the erroneous data in the Toyota Factory Service manual (FSM). The FSM calls for a U-Bolt Torque limit of an amazingly low 37 ft/lbs. This is WRONG!!! If you have the rear TSB springs installed by your dealer, please consider checking your U-Bolts and torque them if necessary.
    Here is a little video I made after hand tightening the bolts and driving to an empty parking lot.
    http://www.youtube.com/watch?v=JSw7a1obpYw
  2. Feb 23, 2011 at 2:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    75# is the correct torque value for the U bolts.
  3. Feb 23, 2011 at 3:04 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Chris, Thanks.
    A while ago the best theory was that the 37 was a typo and it should have been 73 instead. Did we just round the 73 to 75? Or did Toyota correct it in their manual?
    About a year ago the typo was still in the 2010 FSM IIRC.
  4. Feb 23, 2011 at 3:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For some reason, its still listed as 37. I havent checked the newest manuals yet, but I was told it was a typo. Kind of a big typo if you ask me. You would think it would be corrected ASAP. As for the 75#, I round it up :eek:
  5. Feb 23, 2011 at 3:06 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Good to know. Thanks for the heads up, I'll check mine when I get home.
  6. Feb 23, 2011 at 3:08 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks Chris. Yeah round up is good. :) easier to remember that way.
  7. Feb 23, 2011 at 3:18 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    My routine inspection while filling my tank consists:
    1. getting boxers out of ass crack
    2. readjusting of man parts
    3. emptying nostrils via finger
    4. finding a hot chick to look at until the lever clicks
    I am impressed you found that. I should do more for your type "routine inspections"
  8. Feb 23, 2011 at 3:22 PM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    are they lock nuts?
    the rule is "once a locknut is removed, its not a locknut anymore"
    I would suggest to install new nuts and use "Lock Tite" and torque to specs
  9. Feb 23, 2011 at 5:32 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    That's the off road model. U bolts loose for more flex.
    I imagine under load they kind of cinched up so you didn't hear the jingle eh?
  10. Feb 23, 2011 at 6:27 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Not necessary. The nuts for the U-bolts are reusable. I'll check them after 100 miles to insure they are still torqued up.
    Recently there was some noise when going over speed bumps but I thought it was something else. The noise is gone now so it was definitely the leafs separating from the axle. I am glad it's all fixed up. Hopefully others will not be as unlucky as I was.
