My USB port write-up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EEtaco, Aug 6, 2009.
  1. Aug 6, 2009 at 8:53 PM
    EEtaco
    EEtaco [OP] Well-Known Member
    North Carolina
    09 V6 Prerunner
    Problem: Not enough 12v outlets.
    Solution: Consolidate any devices drawing power from a USB port to have its own port.
    What I used:
    12v to USB adapter (See end of post for information on picking out an adapter)
    22AWG Stranded wire or better
    Crimped Eyelet
    Add-A-Circuit
    Fuses (stock fuses didn't fit in AAC)
    Dremel, soldering iron, etc.
    Finding a fuse to tap into was easy. Since I have a Prerunner I could tap into the 4x4 circuit without affecting anything.
    Fuse choice:
    AACs have two fuse slots, one for the primary circuit you're tapping in to and one for the circuit you're adding. It isn't usually well documented which slot is which, so you will have to do a little figuring on you're part. (It is important that you don't use the wrong slots!) I would suggest that for this mod you try and use a 3A fuse for the USB charging circuit and use the standard fuse rated for the original circuit in the second slot of the AAC. Also note that the fuses that normally fit in the truck WILL NOT fit in the AAC.
    I gutted a 12v to USB car adapter so that I could fit it in one of the buttons below the radio. I was getting impatient as my dremel was low on charge so it's not as prefessional looking as I would have liked.
    Another picture showing the amount of wire used. The red crimp shown is where I connected the ground later.
    The most time consuming part was feeding the wire through the back of the dash.
    Once that wire was complete I went back and connected the ground to the radio mount.
    Then just push the button back in.
    The USB port is actually sitting flush unlike how it was in the earlier pictures. I could have taken it slower while fitting it and make it look more professional, but due to it's position you don't pay much attention to it. This mod works great if you have a mp3 player since it's right next to your Aux jack, but it could be placed anywhere.
    If you plan to use this with an Iphone or Ipod please take note of the following:
    Suggestion: ElectronMan did the same mod, however takes a different approach and mounts a fully fuctional USB port with the ability to hook the port to an aftermarket HU should the need arise. I recommend reading his thread which is located HERE.
  2. Aug 6, 2009 at 8:58 PM
    EEtaco
    North Carolina
    09 V6 Prerunner
    Found it at radioshack, but it would most likely by cheaper at either of those places.
  3. Aug 6, 2009 at 9:05 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    good job!
    we did something simmilar on my friends first gen. tapped in to a cig outlet and hid the usb in the center console
  4. Aug 6, 2009 at 9:19 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Nice job man! Good writeup!
  5. Aug 6, 2009 at 10:09 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Nice i need something like this when can you come over?
  6. Aug 6, 2009 at 10:15 PM
    EEtaco
    North Carolina
    09 V6 Prerunner
    When the plane ticket comes in the mail. :D
  7. Aug 31, 2009 at 7:50 AM
    Stewie
    Stewie Damn you, vile woman!
    Roseville, CA
    09 DC 4x4 TRD Sport
    with P265/65R17 Dunlop GrandTrek AT Tires and a tow package.
    Nice work! I need to get on that!
  8. Aug 31, 2009 at 10:58 AM
    irshliquor
    irshliquor Member
    Bakersfield, CA
    2009 PreRunner TRD Sport
    This is exactly what I have been wanting! I don't have much experience doing this kind of stuff though, did you have to solder the wire onto the USB adapter?
    Also, how did you feed the wire behind the dash? Did you have to disassemble anything at all? I have a 2 port USB adapter that I would be completely willing to disassemble and put inside the dash if I could figure out how to get this done exactly...
  9. Aug 31, 2009 at 1:42 PM
    EEtaco
    North Carolina
    09 V6 Prerunner
    Yes, I soldered the positive wire to the USB adapter and crimped the ground to the existing wire on it due to the lack of soldering space on the USB adapter. You could crimp both, but I just prefer soldering when possible. As far as feeding the wire goes you just need to remove the climate controls. Removing the plastic piece below the left console vent (where the 4x4 switch is usually located) is optional, but it provides you a good view of guiding the wire. The wire actually snakes up from the switch to the climate controls, left through a support bracket to behind the 4x4 switch, then down towards the pedals where it can be grabbed and pulled across to the fuse box.
    Modifying your 2 port USB adapter could prove tricky as I had just enough space in the spare switch to mount my one port, but I'm sure it could be done.
  10. Aug 31, 2009 at 1:56 PM
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    This is a great idea and write up. Nice job!!
  11. Sep 6, 2009 at 11:26 PM
    digit748
    digit748 Member
    4x4, USB, more to come, less than 100mi on truck and already addicted
    EETaco, thanks for the idea- great mod! I did change it up bit though to fit my needs. I used a double USB car adapter from Best Buy (19.99), I know a bit more expensive but I couldn't wait. More importantly I placed the "Mini Add-A-Circuit" in the #6 Slot (Door Lock System) so that the the USB ports would have constant power. Great for charging iPhones, Mp3 Players, etc when the truck is off!! I am a newbie so if someone knows of a reason I shouldn't do this I'm all ears. 2009 4x4 DBL CAB TRD OFF-ROAD
  12. Sep 29, 2009 at 5:12 AM
    calfire88
    calfire88 WHITE TACO
    Jeremy
    so cal
    09 trd SPORT long bed
    BHLM, satoshi grille with K/C long range daylighters behind, 2 1/2'' procomp spacer lift on front, multiple aux lights, yellow fogs, black stock trd sport rims
    the idea of hardwiring the plug in is a great one actually. i took a 3 plug cigarette lighter 12 volt adapter and did the same thing so i can charge my ipod and phone if either one dies and im not driving. its awesome
  13. Sep 30, 2009 at 4:42 PM
    glandnut
    glandnut Grease Monkey
    Florida
    09' MGM TRD DC Sport LB(gone), 16' 4Runner Trail
    secret stuff.
    OK, so I have a question. Wouldn't this just provide an output voltage of 12V? I was looking at the 120v to usb plug and cable that comes with all iPhones, and it converts that wall current to an output of 5v. Someone unknowingly just taking a usb to ipod cable and plugging it up to this mod would possibly fry the device, right? The actual cables don't regulate or convert voltage.
  14. Sep 30, 2009 at 5:46 PM
    EEtaco
    North Carolina
    09 V6 Prerunner
    The 12v USB adapter is what converts the 12v to 5v. This mod just simply hard-wires the adapter so that it is not taking up one of the accessory plugs. Unless you're using some non-certified adapter or something unknown, USB is spec'd to carry 5v.
  15. Sep 30, 2009 at 6:05 PM
    glandnut
    Florida
    secret stuff.
    Cool, thanks for the clarification. Great idea as I was wondering what useful item I could place in those blank switch covers.
  16. Sep 30, 2009 at 6:06 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
  17. Sep 30, 2009 at 10:11 PM
    huntingr
    huntingr Member
    California
    09 Prerunner SR5 TRD Double Cab
    That's a great idea! I have been thinking about what to do with thos blank switch plates; thanks for planting that seed in my mind! I also like the double USB port idea. I think I will use a separate dual port connector and solder it directly to the adapter board (instead of trying to mount the adapter bd. to the switch plate). I am going to do the 12V accessory plug mod (to make the 12V plugs always active), and then connect the USB adapter to the wires going to the 12V accessory plugs. 2 mods at once!
    Question: is there a 5VDC source on the electrical panel that can be tapped in to (trying to plant another seed here)?
  18. Sep 30, 2009 at 11:01 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Hardybob likes this.
  19. Oct 1, 2009 at 12:48 AM
    frankrizzo1
    frankrizzo1 Well-Known Member
    San Diego
    05 Access Cab TRD Prerunner
    5100's at 1.75, Firestone Destination AT 265/75/16
    I think the original poster was trying to keep his 12v power outlets available.... which is why he hardwired. But that gizmo is definately the way to go for me! Nice find, especially for 24 bucks!:proposetoast:
  20. Oct 1, 2009 at 8:10 AM
    huntingr
    huntingr Member
    California
    I like it Viet, but as Frank stated, It would be nice to keep the 12V ACC plugs available. Besides, hacking is more fun. I plan to make mine a bit more presentable though.
