My version of the Free airbox Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by sportsterchop200, May 2, 2013.
  1. May 2, 2013 at 5:24 PM
    sportsterchop200
    sportsterchop200 [OP] Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    Just another take on the airbox mod, I haven't seen anyone else do it this way. I took the fenderwell elbow off then rather than do the deck plate I used the elbow. It only makes for about a 2 3/4" hole but seems to fit and work well. The elbow had to be modified to fit around the headlight plug and the lower air box bolt. Other than that and the crapy grey JB weld it looks pretty good I think.
  2. May 2, 2013 at 5:31 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    :worthless:
    Interested to see this.
  3. May 2, 2013 at 5:35 PM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    I had to redo, the pictures didn't attach the first time.
  4. May 2, 2013 at 5:43 PM
    History
    History Well-Known Member
    Whats the mod for? I guess there is a thread somewhere about, Short answer?
  5. May 2, 2013 at 5:46 PM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    It just opens up the airbox a little. Search free air box mods and you should find alot about the elbow mod and deck plate mode. This is just my version after doing it.
  6. May 2, 2013 at 5:52 PM
    History
    Thanks
  7. May 3, 2013 at 7:13 AM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    Heres a good read thats also listed in the sticky section.
    http://www.gadgetonline.com/AirInduction.htm#K&N and AMSOIL drop in air filter:
  8. May 3, 2013 at 7:23 PM
    MEDICDUDE423
    MEDICDUDE423 Well-Known Member
    East TN
    03 Tacoma Limited X-Cab 4WD
    Good looking mod!
  9. May 4, 2013 at 8:50 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    what was the reason that you attached the elbow to the front of the box instead of just cutting a hole ?
  10. May 4, 2013 at 9:14 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Honestly the way you have it now is the elbow is blocking a rush of air you could normally get had you of just left a hole in the front. It's counter productive.
  11. May 4, 2013 at 11:56 AM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    The elbow offers splash protection which is probably minimal because it's directley behind the headlight, but in comparison to an open hole it's offers substantialy more protection.
  12. May 4, 2013 at 12:02 PM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    The only difference between this and the average deck plate mode is the hole is only 2 3/4" versus 4 or 6" that some others use and you can't close it at will. This is basically like having a box with two elbow mods. Both holes seem to be taking in the same amount of air just based on placing my hand by the two openings. The box itself is definately getting more air. Whether it's any better or worse than any other air box mode I don't know, this is just the way I chose to do it.
  13. May 4, 2013 at 12:35 PM
    TIPICOTACO
    Tyler
    nw nj
    Gotcha.. I'v got a 4" deck plate and was initially concerned w/ water/mud getting in there but after some time I'v realized that it stays pretty protected. The biggest thing that gets my filter dirty is dust!! there's not much that can be done about that though..
