my window wont roll up!
Discussion in '1st Gen. Tacomas (1995-2004)' started by davestaco, Sep 12, 2010.
  1. Sep 12, 2010 at 12:16 PM
    davestaco
    davestaco [OP] TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    As the title states, my driver side window will not roll up. The motor isnt even turning on. Any ideas on what it could be? Ill be fixing it tomorrow.
  2. Sep 12, 2010 at 12:17 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Turn your key on....
    hahaha have you checked fuses?
  3. Sep 12, 2010 at 12:19 PM
    joes06tacoma
    Joe
    Central Coast, CA
    No tacoma experience, but on all the window issues I've had with other vehicles, the switches seem to go out first.
  4. Sep 12, 2010 at 1:01 PM
    davestaco
    David
    Schofield Barracks
    hahaha ya key is on........im a newb to tacomas. is there a second fuse box? i know there is the one under the hood, but is there one inside the cab or anything?
  5. Sep 12, 2010 at 1:02 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Yes behind the drawer. Hmm On a second gen... Fuse 5 fuse box 30 amp. It could also be the power window relay. Yes there is one fuse box on the inside too and the power window relay is or seems to be behind it, near the kick plate drivers side.
