My windshield fluid pump went out...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xguntherc, Nov 4, 2017.
  1. Nov 4, 2017 at 12:00 PM
    xguntherc
    xguntherc [OP] Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Hey guys this week my windshield washing fluid stop coming out. I topped it off thinking it was just empty but it's not..
    It makes no noise. The pump or whatever appears broken. Maybe a fuze, or does anyone have any advice on where to start troubleshooting?
    Thanks
  2. Nov 4, 2017 at 12:10 PM
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    Mine stopped working when a little rubber hose under the hood that connected the pump to the washer fluid resevoir came off. Its on the left side of the engine bay I think, I just ziptied the hose back onto the plastic fitting that it went onto. have somebody spray the washer fluid while you look under the hood for a loose hose, maybe its as simple as that :)
    WNYTACOMA, theredofshaw and TacoCat like this.
  3. Nov 4, 2017 at 12:15 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I had a similar issue years ago. Mine turned out to be the washer hose was getting pinched by the rubber seal on the hood. I cut a small chunk out to give clearance and it worked perfectly
  4. Nov 4, 2017 at 12:19 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Find the pump; should be attached to the bottom of the washer fluid reservoir. Test the connectors for power, if your getting power then your pump is in need or replacing, if your not getting power then its time to start tracing wires and checking fuses.
  5. Nov 4, 2017 at 12:32 PM
    TacoCat
    Johnny-5
    Chantilly, VA
  6. Nov 4, 2017 at 12:53 PM
    xguntherc
    Cory
    East Dallas
    Well mine runs under the hood plastic... Which makes sense. But then routes back and gets hit by the seal. Really silly. But with the hood open it's not getting pinched and it still doesn't work so something else is wrong.. still looking
    TacoCat[QUOTED] likes this.
  7. Nov 4, 2017 at 1:34 PM
    xguntherc
    Cory
    East Dallas
    Motor appears to be attached to the Reservoir... All the wires look okay that I can see. So my next step is probably a fuse
  8. Nov 4, 2017 at 2:23 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    They look ok, or you pulled out a tester and tested them?
  9. Nov 4, 2017 at 2:42 PM
    xguntherc
    Cory
    East Dallas
    They just look ok. I don't think I have a tester. Probably go get something from AutoZone or O'Riley's. What kind of tester is best
  10. Nov 4, 2017 at 3:29 PM
    HawkShot99
    Kingston, NY
    Even a basic electric tester is fine for that type of job. I have a large collection of the free Harbour Freight ones lying around.
    A tester will tell you if power is getting to the motor or not. If it is getting juice the motor is bad.
    xxTacocaTxx likes this.
  11. Nov 4, 2017 at 3:31 PM
    coma toy
    coma toy Off Road Taco
    Shit happens....
  12. Nov 4, 2017 at 3:31 PM
    xguntherc
    Cory
    East Dallas
  13. Nov 4, 2017 at 3:52 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
  14. Nov 5, 2017 at 5:47 PM
    TRD 4.0
    TRD 4.0 Well-Known Member
    Jorge
    CA
    06 4x4
    Bilstein 5100, BFG KO2 265/70/17, BHLM, 4th gen 4runner SE 17s
    Mine went out, too. I checked the hoses and fuse and they seemed fine. I bought it at NAPA for $20 and replaced it. The original pump required a bit of force to get out.
  15. Nov 5, 2017 at 5:58 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Yes, that tester is good.
    No, don't tap into the wire, unhook the connection from the pump, connect the clip end to the negative post on the battery or a hood bolt, have somebody actuate the lever to turn on the pump, take the probe end and test each of the (probably 3, possibly 2) contacts on the wiring that attaches to the pump, if you have light on one of the contacts you have power, if not start tracing the wire back and try to find the fuse.
  16. Nov 5, 2017 at 7:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The washer pump fuse is a 10 amp fuse in the dash fuse box to the left of the steering wheel labeled
    10A WSH.
    Thomasf94, xxTacocaTxx and REDdawn6 like this.
  17. Nov 5, 2017 at 7:48 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I recommend taking the washer resivoir out and pulling apart the connector that goes into the bottom of the tank (its a round connector that is at the very bottom of the resivoir that you can use a flat head screwdriver to take apart).
    I had this problem recently and it ended up being corroded on the two contacts inside there. I cleaned them up with a small wire brush, some scotch brite, and then hit them with a little wd-40 and that got mine going again
    You can also take an air compressor and blow out the lines to verify that there arent any obstructions in the tubing. I did this before what i described above and narrowed it down to an electrical problem
  18. Nov 8, 2017 at 4:50 PM
    xguntherc
    Cory
    East Dallas
    Ah ok. Thanks everyone. I need to have someone push the lever to see if it's even making noise. Then I'll start testing everything else
  19. Dec 23, 2017 at 12:34 PM
    xguntherc
    Cory
    East Dallas
    Ok so my fuze isn't blown.. but the metal connectors are scorched and look burnt a tiny bit. But the connector is good inside. Worth replacing real quick?
  20. Dec 23, 2017 at 3:47 PM
    xguntherc
    Cory
    East Dallas
    Hey @TRD 4.0 was the process pretty simple. Mine is 3/4 full of fluid too. So I'm worried about that. You just unplug wire, unhook from cables, unscrew from body and lift the entire reservior out? Then just replace and put back.
    I'll try that next
