My yz250 build
Discussion in 'Other Builds' started by RenoTacoma, Sep 29, 2011.
  1. Sep 29, 2011 at 3:11 PM
    RenoTacoma
    RenoTacoma [OP] Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    I saw some else put there dirt bike here so I couldn't resist.
    2005 yz250
    Bike started life (with me) last year when I picked her up used in California.
    she stayed that way for a while until things took a turn for the worse.New top end went boom. Cracked the piston skirt off, caused by a bad crank/ bearings.
    So after a complete wiesco rebuild. Everything was replaced, I even rebuilt the shocks.
    I got bored of the look so, I upgraded.
    I then resprung it for my weight and picked up some fancy suspension subtanks.(awesome, I eat rocks with my front forks now)
    So far Ive left alone for a while but ill be getting a new pipe soon.
    Heres my list of upgrades/parts
    Eric gorr porting and head mods
    full wiesco engine
    Subtanks
    Re valved for mx/woods
    Black wheels with blue hubs
    Aftermarket reeds
    Cryca pro bend hand guards
    2010 450 fender
    Red bull graphics
    2006 number plate
    o ring chain
    renthal sprocket
    9oz fww
    carbon fiber chain guide
    works connection skid plate
    alot of powder coated/ anodized parts
    :cool: I think thats all
    :goingcrazy:
  2. Sep 29, 2011 at 3:12 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    can you explain what these are?? keep the oil cooler like a resi?
    sick bike btw.
    what made you choose 2 stroke over 4 stroke?
  3. Sep 29, 2011 at 3:17 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    http://www.framebreakerracing.com/
    "Quality that is guaranteed! Is your suspension as good as it can be?
    If not, you may want to check out our FVO System. A subtank system that requires no drilling or any other modification to your forks. It's no secret, that our suspensions are limited to how well our forks are working. Since, the shock can easily be adjusted to out perform the forks, we all have been limited to how plush the entire bike can be. Now, with the help of our FVO System, you can actually have forks plush enough to get the most out of your shock. You will no longer be limited to "It's as good as I can get it". Instead it will be " It's as good as I want it." Not only does the FVO System fit behind the number plate without the use of zip ties, it is the first and only 100% maintenance free, no drill system with a total weight of 9 ounces on the market.
    The FVO System uses an exclusive rebound by-pass valve, for a no surprise, no compromise performance. Other systems claim to be engineered to have a "Buffer", when in fact the so called "Buffer" is one of the major flaws that we have engineered out of the subtanks performance. Our system will work on any fork design, twin chamber or open bath types. Our system is engineered to control the air spring characteristic, that every fork has. All this means, you will have the plushest fork action possible, with no harsh buffering affects.
    Why settle for 20 year old technology for your late model equipment? A new design, for newly designed forks."
    It basicly makes the forks stiffer as you speed up and softer when you go slow. Speed sensitive, I love them.
    I choose 2-strokes for 3 main reasons. fun factor, cheaper maintenance, and easy to repair. 4 pokes just are boring to me, no hit :p
  4. Oct 10, 2011 at 7:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    sweet bike!
  5. Oct 10, 2011 at 7:48 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    thanks man!
